Toyota to provide Subaru car maker with hybrid vehicle technology
Guest
Posts: n/a
http://www.channelnewsasia.com/stori...130381/1/.html
OKYO : Japan's top automaker Toyota Motor will provide hybrid-vehicle technology to Subaru-brand carmaker Fuji Heavy Industries, helping it exploit the key North American market, a report said.
Toyota plans to supply its hybrid power system to Fuji Heavy, which will use it to make hybrids a mainline product in the North American market, which accounts for 35 percent of its group sales, the Nihon Keizai Shimbun said.
Fuji Heavy on its part is considering supplying Toyota technology with lithium-ion batteries it has developed with electronics maker NEC for use in hybrid vehicles, the economic daily said without citing sources.
Working-level talks on the technical cooperation have already been taking place, with Toyota president Cho Fujio and his Fuji Heavy counterpart Kyoji Takenaka set to enter negotiation soon, it said.
No immediate comment on the report was available from Toyota.
Hybrids run on either its gasoline engine or on its electric motor depending on driving conditions, making them much more economical and environmentally-friendly than conventional gasoline engines.
Toyota has pioneered the use of green technologies with its Prius, the world's first mass-produced hybrid car.
US auto giant General Motors, the top shareholder in Fuji Heavy with a 20 percent stake, has formed a partnership with German-US DaimlerChrysler to jointly develop hybrid vehicle technology.
But the Nihon Keizai said that the alliance was likely to focus on technology for use in large vehicles rather than vehicles with engine displacements of around three liters, Fuji Heavy's strength.
this is good, i like it when companies share technology...
just like how mercedes shares traction control, ABS, and other safety patents with other companies to create a world of safer cars.
Originally Posted by 1SICKLEX
[url]
US.
US.
However, with either the Toyota or the Hondas, of course, the gasoline engine HAS to run enough to keep the oil and coolant warm, combustion temperatures up, emissions down, (they go up as engine temperature drops), and the electric motor's battery pack charged up.
You bring up an interesting (and debatable) topic about the Prius being the world's first mass-produced hybrid. As I stated, it was the first TRUE ( parallel ) hybrid HERE in the U.S., but both Toyota and Honda had gas-electric cars for sale in Japan before they did here. Hard to tell which was actually first........and whether a series-system will also qualify as a parallel-system does in the sense that you are using it.
Originally Posted by talgrl626
does IMA mean that the gas mileage is poorer than prius since it's only motor "assistant?"
An interesting quirk of ALL hybrids, both series and parallel-type, is that the EPA city mileage is higher than highway. This is contrary to almost every other type of vehicle and occurs because in both types of hybrids the gasoline engine runs less in the city, with its start-and-stop cycles, than it does on the open road....even considering the fact that in the city the gas engine is running up and down through separate transmission gears or a Continuously Variable Transmission where on the highway the engine is usually in top gear.
1 Post
Using the definition of a hybrid as parallel systems where the car that will run on EITHER the gas or electric motor independently, yes, you are correct....the Prius was the first mass-produced true hybrid vehicle in the American market. However, the Honda Insight, a 2-seater smaller than the Prius and with a series-system gas-electric powertrain, actually beat the Prius to the American market by about 6-8 months. ( I was fortunate enough to be one of the first test-drivers in the general, non-auto-media public to try out the Insight when it first reached East Coast dealerships here ). The Insight and the larger Civic Hybrid, with what Honda calls the IMA ( Integrated Motor Assist ) can operate on electric power but only as an assist to the gasoline engine....not independent of it. The gas engine only shuts off at a full stop (when warm).
1 Post
Originally Posted by wantAnewLex
Generally speaking, yes. Toyota's Synergy Drive system is much more advanced than Honda's IMA.
I would agree with you that the 2nd-generation Prius has more advanced engineering.
GFerg
10-27-05 06:41 PM
