TWIN TURBO vs SINGLE TURBO
all depends on what you want to do, how much power you want to make, what car....etc...
pretty general question, can't say one's better. It really depends on the application.
what are you plan's?
a single larger aftermarket turbo is more useful for a few different reasons...
1) Less Complicated:
---The less plumbing the better, and with a single, there's half of that which you'd have with the twins.
2) Cost
3) Configuration of the motor -- an inline 6 inherently lends itself to a single turbo setup because there is one bank of exhaust headers. A V8 & a V6 both have two banks...
The 3000GT & Dodge Stealth (same thing basically) have a V6, Twin Turbo.
the 300ZX -- Twins
It's also not uncommon to see TT kits for LS1 motors, and big block/crate motors.
(IIRC the viper has a few different TT manufacturers)
4) Just a guess here...
Due to the improving technology surrounding turbochargers, I think that twins on a small 3.0 liter engine lacks efficiency. A small single can spool just as fast as the stock twins of the MKIV and develop more HP.
2) Cost
the 300ZX -- Twins
Originally Posted by /Aerostar\
Single turbo is all about power, thats why all the big-HP supras are single. Single will always spool up slower than 2 smaller turboes, but will have much more potential for power
but the bigger the turbo the more the lag, and that's the problem. also the drivability of the car becomes a problem coz' it's either no turbo or when the turbo kicks in, it's like stupid power.
that's why (i beleive) most cars (supra tt, skyline gtr, 300z tt, etc...) they have tt setup. one big and one small turbo. so the car drives better and smoother... but if you go to supraforums or so and take a look at the owners who have supra tt, if they wanna have good power, just take out the tt and snap on a big one
Originally Posted by TTurboPimp
Actually that is wrong......if you look at the Supra TT for example, alot of guys do a mod to the stock twins to make them operate like true twins rather than sequential.......its just a play on words.
What do supra guys do to make them true twin from sequential?
Originally Posted by ChronoJ1
Is sequential turbo different from twin turbo?
correct me if i'm wrong.
-sequential= one spools first then the other spools.
-twin= both spool at the same time.
You are right, the Supra operates on sequential twin turbos, meaning one turbo is always running and the other just kicks in at a certaim time. There is no such thing as an aftermarket sequential twin turbo setup, that I've heard of. I think it is best to always go single (less weight) definitely more practical. The only reason I'd ever go twins would be for show and/or bragging rights.
So, moral of this thread...go single.
So what's the difference between sequential and true twin turbos.
From reading what's been put up so far my understanding is that Single Turboes are bigger and are able to make more boost. The twins are smaller and spool faster making less boost because of size. Also twins have more piping and are more complicated. Also I think that if there is less piping then there's less of a chance for lossing pressure produced by the turboes.
You can't make an absolute like "twins are always better" or "singles are always better". You have to look at the application as well. On something like a Vette or Viper you can run twins that are as large as a single on a Supra. Obviously no one will be running twin 88s on a Supra. If I were to have a V configured engine I'd prefer twins (technically biturbos) just for a more even spool.
James
James
In a sequential setup one turbo feeds the second turbo. The first turbo is ussually smaller and spools at a lower rpm as you get to the higher rpms the second larger turbo starts spooling.
I think when people talk about aftermarket twins setups most of the time they mean one for the left cylinders and one for the right bank of cylinders.
