Any 'Speculation' about the next generation ES 350?
Do you guys think the AVS is really worth what it costs? I ask because I have never test-driven an ES with it that I can remember....so I have never experienced it first-hand. Consumer Reports advised against it.....they said that it basically stiffened up the ride without noticeably improving the handling much.
Originally Posted by EDGE2
AVS on the ES, what is that
Well, whatever you want to call it or initials you give it, it is more-or-less the same idea that other manufacturers offer....a system, usually electronic or multi-valve shock-based, that varies shock damping, spring compression, and in some cases anti-roll-bar activation. GM has what is perhaps the most sophisticated system of all, called Magna-Ride, used on Corvettes and the Cadillac XLR. It uses magnetically variable aligned iron particles in special shock fluid to control the damping. It automatically stiffens up on curves and relaxes on straights.
These devices can be great or a PITA, depending on reliability and quality of engineering...........just ask a Cadillac DeVille, STS, or Eldorado owner what those pre-Magna-Ride electronic struts cost to replace when they fail....apparantly you cannot just repair them.
i was at school looking at motor trend on the computer and they metioned the 2006 or 2007 w/e year it is ES 350 and said that the engine layout thing will be of course a 3.5 V6 producing 245 bhp (around there). i thought it would get the samy thing as the avalon, but like someone else said on club lexus, the es and camry are the same thing, and what would a camry do with 280hp under the hood. but 245 is not thing much of a leap in my opinion as with the 3 Generation GS the V6 and V8 model
boe
ES - 5th Gen (2007-2012)
20
08-02-11 08:44 AM
