Toyota Production System Terms
Guest
Posts: n/a
http://www.toyotageorgetown.com/terms.asp
In order to produce world-class, quality automobiles at competitive price levels, Toyota has developed an integrated approach to production which manages equipment, materials, and people in the most efficient manner while ensuring a healthy and safe work environment.
The Toyota Production System is built on two main principles: "Just-In-Time" production and "Jidoka." Underlying this management philosophy and the entire Toyota production process is the concept that "Good Thinking Means Good Product."
Andon
A type of visual control that displays the current state of work (i.e., abnormal conditions, work instructions, and job progress information). It is one of the main tools of Jidoka.
Genchi Genbutsu
Go see the problem. This is the belief that practical experience is valued over theoretical knowledge. You must see the problem to know the problem.
Heijunka
The overall leveling, in the production schedule, of the volume and variety of items produced in given time periods. Heijunka is a pre-requisite for Just-in-time delivery.
Hoshin
Goals (with targets) and means for achieving it to address business priorities to move the organization to a new level of performance; variable from year-to-year; could also be multi-year; and is developed by executive management.
Jidoka
One of the two main pillars of TPS. It refers to the ability to stop production lines, by man or machine, in the event of problems such as equipment malfunction, quality issues, or late work. Jidoka helps prevent the passing of defects, helps identify and correct problem areas using localization and isolation, and makes it possible to “build” quality at the production process.
Jishuken
Management driven kaizen activity where management members identify areas in need of continuous improvement and spread information through the organization to stimulate kaizen activity.
Just-In-Time
One of the two main pillars of TPS. It refers to the manufacturing and conveyance of only “what is needed, when it is needed, and in the amount needed.” It is built upon three basic principles:
The Pull System
Continuous Flow Processing
Takt time
Kanban
A small sign that is the key control for the Just-In-Time production; it serves as:
Instruction for production and conveyance
Visual control tool to check for over production and to detect irregular processing speeds
Tool to perform kaizen
Kaizen
A system of continuous improvement in which instances of Muda (waste) are eliminated one-by-one at minimal cost. This is performed by all employees rather than by specialists.
Muda
Non-value added. Muda is translated as waste. There are seven types of muda: (Overproduction, waiting, conveyance, processing, inventory, motion, correction).
Nemawashi
Preliminary work to involve other sections/departments in discussions to seek input, information and/or support for a proposal or change (policy, etc.) that would affect them.
Pokayoke
Low cost, highly reliable devices, used in the jidoka system, that will stop processes in order to prevent the production of defective parts.
Standardized Work
The Toyota Production System organizes all jobs around human motion and creates an efficient production sequence without any "Muda." Work organized in such a way is called standardized work. It consists of three elements: Takt-Time, Working Sequence, and Standard In-Process Stock.
Takt-Time
"Takt-Time" is the time which should be taken to produce a component on one vehicle. This timing mechanism is based on the monthly production schedule. Daily total operating time is figured on the basis of all machinery operating at 100% efficiency during regular working hours. The takt time allows us to produce many parts of many different types for use in vehicles on the production schedule and to supply those parts to each process on the assembly line at the proper time. This keeps production on schedule and permits flexible response to change in sales.
Takt Time =
Straight Time Work Time (Seconds)
Required Number of Production based on Demand
Working Sequence
Working Sequence refers to the sequence of operations in a single process which leads a floor worker to produce quality goods efficiently and in a manner which reduces overburden and minimizes the threat of injury or illness.
This is the minimum quantity of parts always on hand for processing on and between sub-processes. It allows the worker to do his job continuously in a set sequence of sub-processes, repeating the same operation over and over in the same order.
Yokaten
Across everywhere. (Plant related activities and/or countermeasures that are communicated plant wide and with other company affiliates.
Andon
Genchi Genbutsu
Heijunka
Hoshin
Jidoka
Jishuken
Just-In-Time
The Pull System
Takt time
Kanban
Kaizen
Muda
Nemawashi
Pokayoke
Standardized Work
Takt-Time
Takt Time =
Working Sequence
Yokaten
GFerg
07-11-06 10:06 PM
