And so, which of the 3.5 v6 engines will make it into the GS350?
Originally Posted by Och
Also, what was the point for Lexus to even make the current 3.0 V6 in the GS300 - it is not found in any other model, and it's lifespan was relatively short. It doesn't seem like it will see the daylight in any fugure models. IMO they should have just kept the old I6.
I believe there was a post somewhere which stated that the IS250 will become IS300 <with that 3.0 v6 > after everyone gets their new engines
I'd say 5.4 is a bit too optimistic, the GS will not have such agressive throttle responce and tranny as the IS, honestly I doubt it will even make it into 5's. How fast are M35 and RL running anyway?
Given the above, I still think I have reasons to be optimistic.
The best estimate of the GS350 0-60 performance can be based off the latests performace data from the 268HP Avalon that weigh's 3560lbs for the XLS and 3600lbs of the Limited. I don't know which model was tested in that review posted elsewhere, but the Avalon does a 0-60 in 6.2 seeconds with FWD. Surely a RWD GS350 close weight about the same making 38 more HP can shave off at least 0.3 seconds right?
Originally Posted by XeroK00L
Hmm and why would Avalon, with a different drivetrain layout, different number of gears, and a quite different torque curve be a better comparison basis than the IS350, which is basically just a shortened GS350, with just about everything else being constant and only the weight being the variable?
You are right. I totally forgot about the gear ratio. I was just basing it off the power to weight.
OK...after I cooled off a bit and looked back, I realized that gear changes really can't be disregarded, as the time it takes to make a shift will remain the same regardless of horsepower increases, so the acceleration time need to be subtracted by the shift time (1x or 2x, depending on whether the car reaches 60mph on the 2nd gear or the 3rd) first before it can be considered linearly proportional to the car's weight.
So by fuzzy math I say the final number should be closer to 5.5s instead.
Originally Posted by LexArazzo
If the GS350 can do 5.5 or even 5.6 sec. 0-60, then the GS460 better be able to achieve at least 4.9 sec. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
By the way, if the 460 gets into 4 second territory, I'm gonna crap my pants.
Super Moderator
Originally Posted by rominl
would be nice, but i am already very happy if the car can do low 5 just like the is350. that probably make more sense, with the gs350 doing mid to high 5. anything sub 5? leave it to the performance version (if it comes, hahah)
Why don't you do some 0-60 estimations for the GS460 as well ?
making some assumptions about it's weight, hp ..380 ? 388 ? 400 ?
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Hopefully when Lexus says <5.5 for the LS460 they really mean something like 5.1s.
