And so, which of the 3.5 v6 engines will make it into the GS350?
#32
Guest
Posts: n/a
Originally Posted by XeroK00L
Actually, the 430 has an official 0-60mph time of 5.7s.
Now regarding the 0-60mph time for the GS350, here's my calculation:
FACTS
1. The IS250's curb weight = 3,435lbs.
2. The IS350's curb weight = 3,527lbs.
3. The GS300's curb weight = 3,536 lbs.
4. The IS350 has an official 0-60mph time of 5.3s.
ASSUMPTIONS
1. The weight difference between the IS350 and the IS250 is solely due to the difference in engine displacements (i.e. port injectors and VDIM-related mechanism weigh nothing).
2. The GS350 will have the same horsepower output as the IS350 (even though according to lexus.jp the GS350 produces 3ps less than the IS350).
3. Torque remains FLAT throughout the accelerations (obviously this isn't true, but the GR engines have a torque curve broad and flat enough to make this assumption OK for a rough estimate). This also means no gear change is taken into account.
CALCULATIONS
1. Each liter of displacement in the GR-series engine weighs (IS350's weight - IS250's weight) / (IS350's displacement - IS250's displacement) = (3,527lbs. - 3,435lbs.) / (3.5L - 2.5L) = 92lbs./L
2. From 1., GS350's weight = GS300's weight + 0.5L's worth of weight of the GR-series engines = 3,536lbs. + 0.5L x 92lbs./L = 3,582lbs.
3. Since weight is inversely proportional to acceleration (F = ma), and acceleration is inversely proportional to acceleration time given the same target velocity (v = at), weight is proportional to acceleration time; therefore, the 0-60mph accerlation time for the GS350 = IS350's accleration time x (GS350's weight / IS350's weight) = 5.3s x (3,582lbs. / 3,527lbs.) =~ 5.38s =~ 5.4s
This actually makes sense since the GS350 will be barely heavier than the IS350 (heck the GS300 is only 9lbs. heavier than the IS350) and the GS430 doesn't have a torque curve nearly as flat as the 3.5L's, so in terms of 0-60 time the GS350 can win GS430 easily with more horsepower.
Remember you heard it here first.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
FACTS
ASSUMPTIONS
CALCULATIONS
Is the gearing the same in both cars though?
#33
Originally Posted by Faraaz23
Does anyone know for a fact that gearing is the same on the GS350 and IS350... that could make a marked difference in the 0-60 and 1/4 times...
Originally Posted by 1SICKLEX
Dude that was freaking beautiful. I mean beautiful.
http://lexus.jp/models/gs/spec/spec.html (see lower right of the table)
#34
5.4s... wow... if that ends up being true, thats one heckuva bargain for slightly under $50,000. The BMW 550i which is about $10,000 more is no faster than that (0-60).
#37
Super Moderator
Originally Posted by rominl
yup, that's why i said i would be surprised if the gs460 enters the sub 5 category ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Another Q : 6 speed or 8 speed tranny for the GS460 initially ?
#38
Super Moderator
Haha thanks, I should've looked it up before I even made the calculation post. It's all there in lexus.jp's spec page for the GS350. So the answer is yes, the gear ratios are indeed identical to those of the IS350.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#39
Guest
Posts: n/a
Originally Posted by LexArazzo
Yes, I think mid 5 is realistic, I really don't see why the GS350 cannot be within 0.2 or 0.3 sec. of the IS350 for 0-60 if gear ratios & hp are the same if the weight difference is only 88 lb. . . . . . put 1Sick in an IS350 & Henry in a GS350 & the race will be dead even
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#41
after reading all the analysis, mid 5 is indeed very possible. that would be sweet!!!!!! in that case, the gs460 better do low 5
