Ford to use Capless Fuel Filler on entire model line
This change has little to nothing to do with customer convenience.
It has everything to do with cost reduction. Every penny count in this industry and removing a cap and tether are going to save $.xx per vehicle. Add that up over the entire lineup and you have significant savings. ( I would bet that the entire "system" has been modified to reduce the number of parts).
I'm sure there is a flapper in the opening that will close to eliminate fumes escaping.
But seriously..I dont know why some of you are looking down at this idea as if Ford wanted to put hubcaps on the Ford GT. I dont see any negative about it, only positives. Perhaps if Lexus is the one to start this trend, this whole forum would have different opinions. I can definitely see this as one of the future things that will become standard on most, if not all cars.
Sure you may save maybe 5 seconds with this capless system, but why complain about saving time at all? It's a good thing.
__________________
1999 Lexus GS400
-Stock
Your user account may not have sufficient privileges to access this page.
__________________
1999 Lexus GS400
-Stock
If anything, this capless system should have more parts than the traditional cap system. If you look at both systems, they're very similar. The Cap system has a cap (obviously), and that's just one removeable part. The Capless system will need at least 2 parts to work, so essentially, the capless system isn't really saving in number of parts.
__________________
1999 Lexus GS400
-Stock
__________________
1999 Lexus GS400
-Stock
When making the gas door there is at least one extra step to add either a cap holder or a tether holder. Typically it's a stamped and bent piece of metal that is tack welded to the door. This also will cause additional dwell time in the painting process as the painting arm will have to make an extra turn (at least one).
Now look at the system above. Obviously they have eliminated the cap, tether, plastic flap, additional metal piece inside the door to hold the cap, etc... Look how clean the door is now. It's a simple one piece design. Imagine the rest of the lineup. They can now just stamp a simple flapper. I bet most of the new ones aren't a racing style flapper, just a one piece stamped and painted piece of metal.
Odds are there is a simple flap inside the filler neck that has enough pressure to direct overflow to the evap canister.
Trust me on this. No matter how neato or green it looks, it's not made for the customer. This wasn't dreamed up to save some namby pamby person 2 seconds removing the cap, or keeping their hands off a dirty gas cap. (it's not like it's deisel fuel!) It's made to reduce costs and if it makes a customer happy, thats only a bonus.
I've been selling direct tierI and tier II for 10+ years now and the only thing that makes an auto manufacturer change direction is $$.
Costs are taken out of the strangest things. Take Nissan. They saved a significant amount of money by not painting the B pillars of their cars. They now use a black decal. It allowed them to reduce passes in the painting stage which reduced paint emissions which in turn saved them significant coin. There is no other benefit to using a decal beyond $$.
Guest
Posts: n/a
A typical system has a door, cap, tether, welded piece in the door to hang the cap, metal flap inside the filler neck, Plastic shroud around the neck to direct spillage, evap hoses and evap canister.
And with a username like "cheap skate" why wouldn't I?
Gojirra99
05-13-07 02:48 PM
