Article about how to PROPERLY break in...
Old 09-29-06 | 08:08 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
reset efi and ecu (ur on ur own figuring out how on a new bmw) and it will make the car perform basically the way it was built.
basically makes the motor run a lil rich and the trans not shift so early.
Old 09-30-06 | 06:51 AM
doug_999's Avatar
doug_999
Originally Posted by Technique
How much was your 550 OTD? What's the 0-60? I am thinking of getting one next year...
Check your PM
Old 09-30-06 | 07:46 AM
Technique's Avatar
Technique
CL Folding 500000
Originally Posted by doug_999
Check your PM
Didn't get any PMs...
Old 09-30-06 | 08:01 AM
doug_999's Avatar
doug_999
That's cause I sent it to PureDrifter... doh....
Try now!
Old 09-30-06 | 08:21 AM
mmarshall's Avatar
I agree with Motoman about not generally using synthetics during the first couple of thousand miles...(their extremely low friction will delay the ring and valve stem friction required for a proper break-in, although some cars like the Corvette and Viper have synthetic put in at the factory because it resists heat build-up better ). He is also correct that engine metal alloys, casting and honing methods, and clearances are much different today than in the past. ( Also not mentioned is the fact that Honda / Acura uses special break-in oil at the factory and does NOT want it changed for at least the first 3000 miles.....usually, on other nameplates, it is beneficial to change oil and filter at the first 1000 miles to get the shavings out).
But the rest of his article, in my opinion, sounds like old-fashioned snake oil tactics. First of all, although, of course, a well-broken in engine will give more power and better mileage than one that is not because of better compression, the main purpose of breaking in an engine on a street car is NOT necessarily power but to get a good seal on the moving parts ( rings, bearings, valve stems and seals, etc....) and to prolong engine life and keep it from being an oil user. On a racing engine that is only going to be run a few hundred or thousand miles and then rebuilt or junked, that is a different matter, but the engine in a street car is going to have to last for years and run 150,000-200,000 miles.
Second, I think you can take the word of the people who actually design and build these engines at the factory more than someone who is just trying to sell an alternative technique on the Internet....like I said, snake oil people are a dime a dozen. The auto manufacturer, as long as the new-car owner does not abuse the car and breaks it in according to factory instructions, is going to have to stand behind that engine warranty for anywhere for 3 to 10 years and do an overhaul or replace it if it starts to use an excessive amount of oil ( usually around one quart every 1000 miles is the threshold ). If what Motoman says is correct, in my opinion his methods would be recommended by auto manufacturers, and of course, in many places with dense traffic and pedestrians it is not only unwise but dangerous to use full-throttle methods as well,
Third, as most of you know from my auto reviews, I test-drive a lot of new cars, and I'm not about to start slamming brand-new engines around just because Motoman thinks it is more efficient to do so....I strictly adhere to the 4000-RPM limit and no 100% full-throttle stuff...though I accelerate hard enough to get a good idea of what the engine is capable of. Even Gung-Ho auto enthusiast magazines like CAR and DRIVER and ROAD and TRACK take it easy for the first 1000 miles or so on their test cars....and these guys are professionals who do it for a living, as do the slightly milder-driving people at Consumer Reports as well.
Old 09-30-06 | 08:41 AM
PureDrifter
BahHumBug
CL Folding 100000
Try now!
lol, if i need to pick up a bimmer any time soon il be sure to hit u up
might take a while as im only just about to graduate from highschool
Old 09-30-06 | 08:55 AM
doug_999's Avatar
doug_999
I agree with Motoman about not generally using synthetics during the first couple of thousand miles...(their extremely low friction will delay the ring and valve stem friction required for a proper break-in, although some cars like the Corvette and Viper have synthetic put in at the factory because it resists heat build-up better ). He is also correct that engine metal alloys, casting and honing methods, and clearances are much different today than in the past. ( Also not mentioned is the fact that Honda / Acura uses special break-in oil at the factory and do NOT want it changed for at least the first 3000 miles.....usually, on other nameplates, it is beneficial to change oil and filter at thre first 1000 miles to get the shavings out).
Except that they (Honda) don't do this in their bikes - very strange. Friend of mine picked up a Goldwing and there was no mention of this in the manual.
Old 09-30-06 | 11:35 AM
chuckb's Avatar
chuckb
I've always taken it easy on my new motors at first and I'm a firm believer in the oil change at 1k to get out shavings. the heat cycle method and running at varying rpms is what I've pretty much gone with too.
btw-when a ferrari engine is built, it's tested to 7500rpm before going in the car
you can see at the end of this amazing vid...
http://www.autoblog.com/2006/09/12/a...a-ferrari-v12/
Old 09-30-06 | 12:08 PM
clubfoot's Avatar
clubfoot
In this day and age I would think bedding the brake pads so they don't squeal and perform their best is more important than engine break in now.
Old 09-30-06 | 08:58 PM
Irishfan's Avatar
Irishfan
Well, if anyone's curious, I just picked up my IS350 from the dealer with 12 miles on the odo, and have put 30 miles on it according to "Motoman's" break-in tactics.
Old 10-02-06 | 10:26 PM
bruce van's Avatar
bruce van
I'ved read the article a couple times a year ago and think he may be onto something. I'm going with this technique if I ever buy a new car.
Changing the oil within 1000 is probably key too.
You should revisit this thread every 10,000 miles and let us know how you're car is doing. Good luck!
Old 10-03-06 | 05:06 AM
mmarshall's Avatar
If you use Motoman's technique, be sure to always keep a couple of extra quarts of oil in the trunk with you.
super400
Performance & Maintenance
08-12-14 01:12 PM
Jayson
11-16-07 08:56 PM
roughrider
06-17-03 12:24 AM
ShowDiscipline
SC- 1st Gen (1992-2000)
13
03-08-02 07:02 PM
