Engines: W vs. V
Actually a car is simple enough to properly understand; if you know how to work on them or are just into that kind of thing; not all of us are.
Typical, but you completely missed the point of my post. A better analogy would have been if you said: "Kinda like the idea of a car with 6 wheels, one pair behind perpendicular to the other 4 and only used for doing 360 degree turns...naw that just too complicated."
Show me the benefit of a W12 over a V12. You think Ferrari wouldnt be using them if they had a point? They spare no expense and still use V12s.
So we arrive at my original statement about overengineering being the epitome of German car development. Though now, through your folly of the attempted use of sarcasm, we have added a bit more strength.
Actually its very simple. Much like RISC processors function; we break things down to make them simpler to work on, understand, and sometimes have added benefits. 4 valve and 2 cam heads allow for a nice positioning of the valves within the combustion chamber for example. There is less valvetrain mass and allows for reliable higher-rpm use. Ever wonder why bikes use DOHC motors? ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Not a good example, bit. I can show why DOHC designs are superior to SOHC and pushrod motors in various ways; but you can show me nothing benefitting a W motor? Packaging? well we got high power V6s and most V8s are pretty compact these days (other than the modular from Ford), and a W motor has VERY wide heads. Economy? Uh no. Power? Try again.
Guest
Posts: n/a
W12 over V12 for VW b/c of cost. It costs less to just put two V-6s together than develop a brand new V-12 from the ground.
From a sales perspective, you can "offer" the benefits of a W12 or 8 (in the Passat).
W12 is also very compact. The hood of the A8 is much shorter than that of a S-class or 7 series, I believe its as wide as long....
What about the idea of the gas/electric car as a means to save the world? Over complicated? Yes. Somewhat dangerous considering the equivalent a high voltage power line running underneath your bum. Absolutely. Are they very fuel efficient? Not nearly as fuel efficient as a modern diesel engine. Environmentally friendly? Not when you take into account what happens to the toxic chemicals in those batteries when the car must be disposed of. Do they make sense financially for those who buy them or the company that produces them? Ask any accountant and they will tell you, no. Just one example of an idea thats overly complicated that "gasp" doesn't come from Germany. BTW this idea is Japanese.
Now do I think the Japanese are ridiculous and try to make things too complicated needlessly? no. Again, just pointing out the ridiculousness of your logic given all the good ideas, designs and inventions that have come from Germany.
Nice on mavericck... hybrids - not the right solution so far.
Bean, as 1sicklex said, the W12 was done for cost reasons, slap two narrow angle V6's together to get a big power engine. It does have some packaging advantages too, but the main reason was development cost.
I believe BMW basically did the same thing with their earlier V12 750i/850i engine which was essentially two BMW I6's.
![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
moskiter
11-05-09 02:30 PM
