View Poll Results: Will my oil be in "good" condition?
Yes! Your oil will be good. Changing every 3k miles or 3 months is stupid!
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
14.71%
No! Your oil will beyond recognition. So full of metal it won't even be able to be analyzed!
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
29
85.29%
Voters: 34. You may not vote on this poll
1st oil change - 3 years after delivery...
#62
Super Moderator
The RX300 uses a Type-IV as the stock fluid, but I have never heard of a single issue from using the Amsoil ATF in the tranny in our vehicles, in fact I have seen nothing but positive comments. I change mine out at least once a year (because I race my little RX).
#64
BUT, I want to get an "analysis" of the numbers/TBN from the knowledgeable people on the forum, because I might be mistaken...
#65
IMHO, your UOA showed 2 interesting things. Assuming the factory fill was dino oil, contrary to popular opinions - dino oil *can* be used for longer OCIs, especially since your TBN was decent. But since your oil had such high mineral content, it's probably prudent to change out the factory fill at the recommended interval, just to purge the break-in debris from the motor. Not sure which oil your mechanic used, but it would be interesting to see what your next UOA looks like on the jag - knowing you, it'll be 5 yrs and 15k miles from now . . .
#66
My guess is that Blackstone will say that any results are "as expected" when it is a break-in oil that is changed within the recommended mileage. The only thing that was reported as "strong" was the TBN. That doesn't necessarily mean that the engine is in as good of shape as it would be if you changed the oil each year.
#67
socal and gernby: I agree with both of you... I think the moral of this story is that oil can definitely go longer than most people think...
As far as the 2nd oil change on the jag, well, I am probably going to turn the car in at the end of the lease at the end of the summer, but if I keep it, well, I wouldn't change the oil till 20k mile at least, which is probably like 10 years from now :-)
I'll post a similar thread when I change the oil in my IS350... That will be at least 12 months, and close to 15k miles on the break-in oil... The following change after that will probably be another 12 months and the odo will be close to 30k...
Of course, I'll have the analysis+TBN done
#68
It doesn't sound like you really agreed with me. My opinion was that just because Blackstone said the results were as the expected, I don't think your engine is in as good of shape as if you changed it earlier. If you look at the metals in your oil, some of them are WAY higher than mine were.
#69
Tech Info Resource
I am really surprised the TBN was so high. You could have gone even longer. Wow!
#70
The factory fill for Jaguar, Landrover is Castrol SLX sold in the UK.
http://www.castrol.com/castrol/produ...tentId=7008962
#71
However, I think the difference is almost trivial.. Meaning... How much better shape would my engine have been in? The answer is "who knows"? How do you measure such things? Really, I think maybe we're talking a few percent difference at best...
So I do agree that it would have helped a little, but the end result might be engine failure at 300,000 miles instead of 280,000 miles... or something like that...
#72
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Anyway, I hope this has been a good experiment... I think the final verdict of this episode of mythbusters is that regular dino oil, in low mileage environments that are considered "severe driving", can go several years without being changed...
Myth busted!
k_dizzle
09-07-06 09:48 AM
