Horrible Audi RS6 crash!!
Not another one of these... guys, these things are staged. There's no way that a car could hit a tree with enough impact to split in half, but the tree survives without a scratch. That tree would be lying on its side. Also, you can see countless clues on the car that prove someone took a sawzall and air chisel to it.
Not a real accident.
Cars don't snap in half, leaving clean and sharp cut lines. This is the another in a series of similarly staged accidents. The car was originally in a real accident and totalled. Someone cuts it up to look like a gruesome, horrific tragedy, and then leaves it on the side of the road somewhere. Probably trying to make a point about the dangers of speed in modern cars.
Look at the undamaged tree. Look at the roof panel that's in amazing condition, get peeled away perfectly along its edge. Look closely at all the areas of separation where the cut is perfectly clean and straight. Look at the wires routed to the rear end that somehow didn't snap under all that force. It doesn't happen this way in real life.
Look at the undamaged tree. Look at the roof panel that's in amazing condition, get peeled away perfectly along its edge. Look closely at all the areas of separation where the cut is perfectly clean and straight. It doesn't happen this way in real life.
Have to disagree with that. I have seen numerous crashes where the results are similar to the above. Trees do not topple in a vast majority of the cases as they are pretty darn tough. Plus, why select a $$$$ car to stage this? Even so, it was still involved in a serious accident. The actual tree or damage to the tree just many not be visible in the pics. The tree with the white stripe is the obvious answer based on what we are given. There may be other factors that are not in the pics.
Hmmmmm... looks real, but it's pretty amazing to me that the force it would take to cut that car so cleanly only put the car ~ 6 feet from the tree he hit at....what .... 100+MPH?? hmmmmm......
Registered User
Details of what actually happened is to difficult to determine from a few pictures only. That tree with the white band obviously was not hit. The band looks to be a marker of some sort but if you look closely you'll notice the bark has absolutely no visual damage although there are tire marks directly in front of it. Its possible that theres another tree near by that was struck and stopped short of the marked tree. Yes Its possible that its a fake, it wouldn't be the first after all its the internet I've learned to take everything in it with a grain of salt. Its also possible its real, that wouldn't be the first either. Nevertheless it all makes for a good topic for discussion, continue on....
Maybe he hit a tree before the one in question.
Ever see a Mustang fly into the woods?
I have. It was destroyed into literally a 1000 pieces and the only thing wrong with the tree was there was a slight mar in the bark but you could hardly tell. Trees are stronger than your think, roots run deep.
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
I have personally seen and touched a tree that demoilished a Mistu Eclipse and the tree looked like it had not been involved. The marks are there... you just can't see them from a photo over the web.
That must have been one hellova crash...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Someone made a very valid point in this thread.
I see a few things that just don't add up.
No flat tire whatsoever from a 100mph+ crash?
No glass shattered/broken other than the windshield from a 100mph+ crash?
The interior looks pretty clean for a car that's been splits in half from this crash.
The exterior mirrors are all intact, as well as all the interior pieces/trims. Heck even the license plates are still mounted straight.
Unless Audi utilizes some wonderful technology on its vehicles, I don't believe the headlights and taillights can withstand the vibrations/shocks from the impact without breaking either.
The law of physics simply doesn't work this way. It doesn't take a forensic expert to raise these suspicions.
Jon
Jon
