Toyota Tundra may be recalled (Expresses regret on forums about camshaft failures)
#31
No, it's not, but it will generally lead to some sort of failure along those lines in at least SOME of the trucks, if it's actually an issue. Obviously it's not, at least so far. Just because the frame is stiffer doesn't mean it's going to suffer more fatigue. In fact it may suffer less, because, well, it's BENDING less.
A stiff frame is possibly more susceptible to traumatic failure (cracking) but in terms of long term fatigue, shouldn't necessarily see any more, if not possibly less, than a less stiff frame.
True, but those frames are flat out MASSIVE. Using a fully boxed frame has the primary advantage of increasing the performance to weight and size ratio of a truck frame. This is more important with smaller sized trucks like the half tons. Furthermore - there's only so much stiffness that you NEED to incorporate into a truck frame for practical purposes. I'm not here to tell you that the Tundra's frame isn't stiff enough to 'get the job done'... if that was the case then trucks from 10 and 20 years ago would have had some serious issues with their frames when used in a work environment. At the point we are at, like I already mentioned above, frame rigidity is like chassis rigidity in cars... it primarily affects ride quality, as well as associated factors like reducing squeaks and rattles, improving handling, etc.
Obviously your average half ton truck buyers will have ride quality far higher on their list of priorities than your average commercial / super duty truck buyer.
The Navistar diesels have not had any excess of failures. Ford is suing navistar for failing to live up to their end of their contractual agreement, which is to reimburse ford for the warranty costs that they DO incur. Navistar is refusing to pay up because they say what problems they ARE having are Ford's fault for pinching their budget too much, which in the end is hurting their budget even more by causing them to contractually pay out a portion of the warranty costs.
Ford Powerstrokes are still very reliable motors - this issue is not about that. It's about a bad relationship between a supplier and manufacturer and the contract that stands between them.
fact is Ford used a fully boxed frame, while using an open C-channel on their Superduty trucks. The exact same design used on semi-trucks.
http://www.detnews.com/apps/pbcs.dll...02/1148/AUTO01
Ford is suing Navistar for failing to cover warrenty costs related to Power Stroke diesel repairs.
Did a Ford spokesperson ever publically say that their diesels had a high-failure rate? Certainly not. Because Ford will only reveal quality problems under extreme circumstances like opening up a lawsuit
I'd rather see Toyota fess up to errors then pretend they never existed.
#32
Super Moderator
Engine trouble on new Texas-made pickup could hurt quality reputation.
Christine Tierney / The Detroit News
Toyota Motor Corp. faces a costly setback in the biggest U.S. vehicle launch in its history after owners of its new Tundra pickup reported engine failures.
The Japanese automaker may recall Tundras equipped with 5.7-liter V-8s to replace the engines, a company spokesman said Wednesday.
The trouble with the Tundra's 5.7-liter engines, the most powerful engine available on the new pickup, is the latest in a series of recalls and problems that have dented Toyota's reputation.
The automaker set the industry standards for vehicle quality, but now seems to be straining to maintain top quality as it expands overseas, builds factories and hires thousands of new workers.
"It's really tough," said Karl Brauer, editor of Edmunds.com, an automotive research Web site. "Engine failure kills a car's ability to run and it's not a simple thing to fix."
Such a problem is also likely to affect residual values, he said.
Industry experts say Toyota is extremely vulnerable to negative publicity because of its prominence in the industry.
In the first quarter of 2007, Toyota overtook General Motors Corp. to become the world's leading automaker in terms of sales.
With the launch of the Tundra earlier this year, Toyota aims to double its share of the lucrative full-size pickup market, one of the few segments still dominated by the U.S. automakers.
Toyota officials characterize the Tundra launch as the most important introduction in the company's history in the United States.
The rollout has suffered delays and disappointments. For instance, the Tundra earned lower frontal crash scores than domestic rivals such as the Ford F-150 and Dodge Ram.
But the engine problem is more damaging and could slow the vehicle's brisk sales momentum.
Company spokesman Bill Kwong said Toyota realized in February that there was a problem with the camshafts delivered by a supplier for the 5.7-liter engine, and the automaker ordered the necessary changes to production.
Still, Toyota has seen 20 cases of engine failure in trucks equipped with 5.7-liter engines, although no injuries have been reported.
Toyota is now studying how many of the 30,000 5.7-liter engines it built are affected.
Toyota builds the Tundra pickup at assembly plants in Princeton, Ind., and San Antonio, Texas, and makes the engines in Alabama.
The automaker hopes to sell 200,000 new Tundras this year, compared with 124,508 previous-generation Tundras in 2006.
But U.S. automakers are holding their own in the pickup market, and GM has been successful with its new Chevrolet Silverado and GMC Sierra trucks.
In contrast to their performance in the car market, where they have been pushed back by Japanese nameplates, American manufacturers account for more than 90 percent of full-size pickup sales, which totaled 2.2 million units in 2006.
#33
https://www.clublexus.com/forums/sho...d.php?t=284741
Different article with extra content, but thread Merged
#34
Speaks French in Russian
Toyota expresses regret for Tundra camshaft failures on internet forums
Our good buddy Mike Levine over at Pickuptruck.com has updated his report on the story surrounding the failure of 20 camshaft in the 2007 Toyota Tundra's 5.7L V8 engine. Levine noticed that Toyota has already posted on two internet forums expressing regret to Tundra owners over the incident. Though the author's name was not provided, identical posts were published by "TMSUSA" on ToyotaNation.com and TundraSolutions.com that address customer concerns and provide this expression of remorse:
"Although the number of affected Tundras is very small, we very much regret that even one of our trucks was manufactured with a camshaft processing flaw and certainly any inconvenience caused to our customers."
Meanwhile, Levine also tracked down a consultant who confirms the estimate we originally reported that it will cost $5,000 to swap out each engine that experiences a failed camshaft. Toyota will certainly pay the estimated $100,000 to repair the 20 trucks already known to have experienced a camshaft failure, but the looming question that's yet to be answered is how many more trucks might need to have their engine replaced? Toyota Spokesperson Bill Kwong told Levine, "Our dealers have approximately 1,600 new Tundras nationwide for disposal as a loaner vehicle while a customer's truck is being repaired, and that doesn't include older Tundras and Tacomas." While meant more as an assurance that the company will do whatever it can to help out customers who find themselves with an affected engine, that statement also implies Toyota is at least prepared for the number to grow.
Playing down the imminence of a recall, Toyota spokesperson Bill Kwong tells PickupTruck.com that, "It's still too early to tell if a recall is necessary, but if it is, we'll initiate it."
But even a limited recall could turn into a very expensive proposition for the OEM. Jim Hossack, vice president and head of the pickup truck consulting practice at AutoPacific, a West Coast marketing and consulting firm, estimates the costs at upwards of $5000 per truck to replace a broken 5.7-liter i-Force V8 motor.
"At this point, they'll probably issue a TSB (Technical Service Bulletin) to their dealers, instead of doing a recall," says Hossack.
$5000 for each engine swap could be a relative bargain though versus the short term cost that this incident has caused Toyota's reputation for building high quality automobiles.
Still, Hossack thinks both Toyota and the Tundra will be fine in the long run because of Toyota's relatively unblemished quality record.
"Toyota will be forgiven and will come out of this unscathed, as long as there are no other major problems after this, but if the same situation had happened to a company like Hyundai, they'd be skewered," says Hossack."
Tundra owners impacted by a failed camshaft will face their own costs, especially if they depend on their truck for their livelihood. In this case, Bill Kwong says Toyota dealers will do what they can to help.
"Our dealers have approximately 1,600 new Tundras nationwide for disposal as a loaner vehicle while a customer's truck is being repaired," says Kwong, "and that doesn't include older Tundras and Tacomas."
Toyota has also been proactively managing the camshaft problem with some of its most loyal fans. Toyota communications and public relations reps have posted apologies and responses to comments in online discussion forums at ToyotaNation.com, a general Toyota news and community website, and at TundraSolutions.com, an online neighborhood of Tundra and other Toyota vehicle owners.
#36
Yep. This is one of the reasons why Toyota is the world's top auto manufacturer today.....and for standing behind the 3.0L V6's sludging and gelling as long as the owners could prove MINIMAL oil changes......once a year. Take a company like Daimler-Chrysler, for instance.......just LOOK at what some of those owners of defective vehicles (and there are plenty of them ) go through. And.....I'm sad to say it as a Subaru fan, but Subaru could have done a better job than they did on the 2.5L non-turbo H4's years of head gasket issues (finally dealt with in 2002).
jason60050
05-22-10 05:27 PM
