Suggestions on how to remove rust?
I have a truck rack which is about 17 years old and has a nice coat of rust all around. Are there any suggestions on how i should remove the rust and what to paint with? Thanks.
You might want to get a wire brush to try to clean off some of that rust or maybe a soft steel wool brush. Then you would want to treat the exposed metal to prevent continued corrosion, then paint.
Where in MD are you?
A wire brush may not be strong enough to get all of the rust off. It may be sufficient for the surface/flaky stuff though.
I'd suggest you get a electric palm sander and go at it at all angles with that... (low cost solution)
If you have more money then I'd get it sandblasted/stripped until its bare metal. Then paint it with a nice coat of primer, a couple layers of paint (tremclad would be good for this), and a few coats of clear coat.
I'm sure if you too it to a body shop, they would spray it down for you charging only a small fee.
How long do you plan to keep the 17 yr old truck? If it's not a structural problem, is it worth the effort / cost?
As for effort and time, i am on summer break and a little diy project to start it off.
So far i purchased a wire brush blade for use with a drill. I started getting the rust off but it doesn't strip to bare metal.
Mabe ill post up a diy writeup when im done.
Naval Jelly and a steel brush.
(no....not the gunk from your belly button)
http://www.shorechemical.com/Section...aval_jelly.htm
Used this stuff on some pretty bad rust.....works great.
leinadmiih
Automotive Care & Detailing
04-16-13 02:06 PM
bagwell
03-05-10 02:03 PM
