Toyota Develops Next-generation Engine Valve Mechanism
#46
You're right, the 6.0L BMW V12 does have both. It works in that engine because there is enough room in the cylinder head, since the V12 is a physically large engine. You don't see Valvetronic and direct injection in other BMW engines though. The V12 looks to be an exception within BMW's engine range.
#47
A thought Just crossed my mind. With the discovery that the 5.0 in the IS-F will have 'G' series heads (2UR-GSE), I think its pretty certain that this engine will utilize this new technology to better performance and help the IS-F have anywhere from acceptable to class leading fuel mileage. Why? VVT technology debuted in the 4AGE, VVT-i in the 3SGE BEAMS engine and VVTL-i in the 2ZZ-GE... all engines with G series heads. With Yahmaha in the mix doing the tuning, and this being the next step, it's my guess that we will see valvematic in the IS-F after the technology debuts in a few months on whatever 2.0 engine they plan on premiering it with.
What do you guys think?
#48
#49
Whatever the reason is, we simply do not see direct injection and Valvetronic paired together in BMW engines, with the exception of the V12.
What is another possibility is that the IS-F could feature continously variable valve lift on both the intake and exhaust cams. Valvematic and Valvetronic both function only on the intake cam.
#50
A surprising update from Japan:
http://www.toyota.co.jp/en/news/07/0627.html
Two redesigned vans, the Noah and Voxy have been released in Japan, and both vehicles feature two engine choices; a 2.0L 3ZR-FE making 141HP and 143 lb-ft, and a 2.0L 3ZR-FAE Valvematic engine, making 156HP and 145 lb-ft. That's about a 10% HP increase, and a small torque increase just by adding Valvematic on an identical engine. Not only that, but based on the Japanese test cycle, fuel economy is increased by about 6% on the Valvematic engine.
The 3ZR-FAE was originally rumoured to first appear this winter on the Premio/Allion sedans in Japan, but looks like Toyota surprised everyone, as this 2.0L Valvematic is available now in Japan on the Noah and Voxy.
With this in mind, there is a high chance we will see a Valvematic engine available on the upcoming USDM Corolla.
#51
#52
Now that Nissan and Toyota both have their variable valve lift systems on the market, the pressure is on Honda to get it's own A-VTEC system to the market soon.
Lvangundy
14
12-18-02 04:34 PM
