Toyota Develops Next-generation Engine Valve Mechanism
Old 06-12-07, 12:20 PM
XeroK00L
XeroK00L's Avatar
Default Toyota Develops Next-generation Engine Valve Mechanism
Can't wait to see this implemented on future production cars.
http://www.toyota.co.jp/en/news/07/0612.html
— 'Valvematic' Achieves High Fuel Efficiency and Dynamic Performance —
June 12, 2007
Tokyo — TOYOTA MOTOR CORPORATION (TMC) announced today that it has developed Valvematic*, a variable valve lift mechanism created through combining VVT-i (Variable Valve Timing-intelligent), which continuously controls intake valve opening/closing timing, with a new mechanism that continuously controls the intake valve lift volume.
While conventional engines control air intake using a throttle valve, Valvematic adjusts the volume of air taken in by continuously controlling the intake valve lift volume and timing of valve opening and closing. This ensures optimal performance based on the engine's operational condition, thus helping vehicles achieve both high fuel efficiency and dynamic performance.
In the case of a new 2.0-liter engine developed by Toyota, Valvematic—which further evolves the gasoline engine—improves fuel efficiency by 5% to 10% (depending on driving conditions), reduces CO2 emissions, boosts output by at least 10% and enhances acceleration responsiveness. TMC plans to introduce Valvematic shortly, starting with a new vehicle model featuring a 2.0-liter engine.
TMC positions global environmental preservation and initiatives toward energy diversification as a priority management issue in terms of its corporate social responsibility. As a part of its efforts to reduce CO2 emissions through high fuel efficiency and to achieve cleaner exhaust emissions, TMC plans to completely revamp its gasoline engine and transmission lineup by 2010.
XeroK00L is offline
Old 06-12-07, 12:53 PM
Threxx
Threxx's Avatar
The concept of virtually infinite valve timing profiles instead of just 2 or 3 is pretty neat. Kinda like CVT transmissions. Instead of having a few cam profiles, there's virtually an unlimited number.
But at the same time, this is not a new idea or benefit. It may be a new way of going about it - kinda like how VVT-i and VTEC and so on all accomplish very similar things but in slightly different ways.
I still think the ultimate would be electromagnetically actuated valves.
Threxx is offline
Old 06-12-07, 01:01 PM
ff_
ff_'s Avatar
You beat me to it. Until they figure out a way to make this work, all the other VVT news is pretty unremarkable (basically, just a small advance on a technology that's now 19+ years old). As far as I know, the only thing keeping mfg's from developing electronical valves, is figuring out how to generate enough electrical power to actuate them. disclaimer: I won't pretend to really know what I'm talking about there, so I'm just regurgitating what I've heard before.
ff_ is offline
Old 06-12-07, 01:24 PM
MR_F1
MR_F1's Avatar
Will we see this technology in Lexus' F-division engines?
also, this part got me..
Hachiroku?
MR_F1 is offline
Old 06-12-07, 01:37 PM
Threxx
Threxx's Avatar
I believe it has been said that the hop to a 48 volt automotive electrical system will be necessary before full blown electromagnetically actuated valves can be used. I'm already amazed that adaptive variable suspension systems and all of these other technogadgets haven't forced them to move past standard 12-14 volt systems.
The thought of a manufacturer redesigning its entire parts bin of electronics to run reliably and durably on 48 volts is pretty daunting.
Threxx is offline
Old 06-12-07, 02:26 PM
MR_F1
MR_F1's Avatar
couldn't an efficient transformer solve that problem?
MR_F1 is offline
Old 06-12-07, 03:00 PM
LexFather
Guest
Posts: n/a
It might be a supplier issue, not a technology issue.
Old 06-12-07, 03:15 PM
Bean
Bean's Avatar
You guys missed it. There's no throttle body either. NO ONE has done that yet. Don't want the motor to breath? Well close the valves. This is far more precise than using one single drive-by-wire throttle body. Its even better than individual throttle bodies. I suspect, we're going to see some big power come out of the Toyota camp
I'm betting this might be in the LFA engine too (and was created in-part during the R&D phase for that particular motor)
Bean is offline
Old 06-12-07, 03:27 PM
LexFather
Guest
Posts: n/a
Wow, great point!! This is big news!
Old 06-12-07, 03:28 PM
MR_F1
MR_F1's Avatar
I'm not sure, but I believe that this is how BMW's Valvetronic works.. I stand to be corrected.
As for if the LF-A engine uses this, maybe not. Now that you brought it to my attention that it does not use throttle bodies, I rmember seeing a pic of the LF-A engine and it has 10 individual throttle bodies.
Maybe Yahmaha will integate it into the 2UR-GSE ?
MR_F1 is offline
Old 06-12-07, 04:14 PM
Nextourer
Nextourer's Avatar
Perhaps a hybrid will work? The **** is only on the LS600h L and GS450h because it needs the HV battery to supply the power.
If so, Toyota can use the HV battery to supply power to that electromagnetic thing you guys are talking about.
Nextourer is offline
Old 06-12-07, 04:16 PM
kit cat
kit cat's Avatar
wait, whats different from BMW's valvetronic?
kit cat is offline
Old 06-12-07, 04:28 PM
Threxx
Threxx's Avatar
BMW Valvetronic uses the valves to actuate as the throttle, rather than a traditional throttle body/butterfly valve.
It has been around for quite some time now, too. 6 years available to the public.
Threxx is offline
Old 06-12-07, 05:04 PM
XeroK00L
XeroK00L's Avatar
Not really. The **** is an option available to the GS430 as well.
XeroK00L is offline
Old 06-12-07, 05:33 PM
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
They should make it available for at least the LS460L Touring model . . .
Gojirra99 is offline
Quick Reply: Toyota Develops Next-generation Engine Valve Mechanism
