Best engine oil!?
Old 08-12-07, 07:54 PM
redkingjoe
redkingjoe's Avatar
Default Best engine oil!?
Hi guys,
Do you know which brand(with model) of engine oil is the best?
Which brands are of the highest price-performance?
Someone said that they use a certain brand(very expensive) once in a while to clear the engine, than switch back to a cheaper one...is it a good strategy?
I heard that using better engine oil will have a lot of benefits.
redkingjoe is offline
Old 08-12-07, 08:01 PM
GSteg
GSteg's Avatar
Originally Posted by redkingjoe
Hi guys,
hi.
There are no best. Engine oil is like deodorant. Some people prefer one over the other. Each applications requires different oil. Some of the better brands out there are German castrol, amsoil, redline, royal purple, etc. Theres too many to list.
see above
A good strategy would be to change your oil on time to avoid sludging. If you change your oil the way you're suppose to (forget the older toyota sludge problem), then there is no reason why you should change to a more expensive oil to 'clean' the engine. If it's clean from the start, it shouldn't need cleaning later on.
going from regular dino oil to synthetic will give you benefits such as better engine protection in extreme climates. But going from one brand name to another isn't going to give you any real benefits.
If the Toyota/Honda guys can get 300k+ miles out of their engine with regular oil, then its good enough. Pick what you like and stick with it.
I'm sure you're expecting some concrete answers, but in reality, choosing oil is mostly preference. I'm running pennzoil just because it's cheaper than my amsoil setup, and my car drives the same.
GSteg is offline
Old 08-12-07, 09:03 PM
MGS4
MGS4's Avatar
if money's no object
Lubro moly synthetic racing 0W40
Shell Helix Ultra 5w30/5w40
Motul 300V 5w30/5w40
MGS4 is offline
Old 08-13-07, 07:21 AM
cpone
There can only be One
cpone's Avatar
Never heard of those. Where do you get them?
I put quakerstate in my GS sythemtic. 5w30.
But I switched recently to Penzoil Platinum 5w30.
Knocks on wood.
cpone is offline
Old 08-13-07, 10:32 AM
MGS4
MGS4's Avatar
I live in vancouver and some racing shops carry Lubro and Motul. As for Shell Helix Ultra, I have to either order it online or buy it from a Ferrari/Maserati dealership.
MGS4 is offline
Old 08-13-07, 10:38 AM
Lexmex
Super Moderator
Lexmex's Avatar
Lubro Moly also goes by the name Liqui Moly. I am experimenting with their 5W30 at the moment (since German Castrol is no longer sold down here, just the American Castrol 0W30).
Lexmex is offline
Old 08-13-07, 10:41 AM
DASHOCKER
DASHOCKER's Avatar
I say German Castrol, Amsoil, & Agip are the best sythetics available.
DASHOCKER is offline
Old 08-13-07, 10:43 AM
Lexmex
Super Moderator
Lexmex's Avatar
There are some RX300 owners I talked to in Brazil that love the Shell Helix oil.
Lexmex is offline
Old 08-13-07, 10:49 AM
mmarshall's Avatar
Can't speak for synthetics, but for regular petroleum oil, it's hard to beat Castrol GTX. Right behind Castrol is Valvoline, Penzoil, and Kendall (if you can still find Kendall). In general, use what the Owners' Manual and the auto manufacturer recommends. For older cars, you can use a newer and later oil grade signified by higher alphabet letters (I believe the latest is SM) but NEVER use an older grade of oil on a newer car. Older engines with worn rings, bearings, and valve seals (within reason) can sometimes benefit from "High-Mileage" oil that is a little thicker than oil recommended for new engines and has a different additive package...it helps seal up worn tolerances and won't leak or burn as fast as the thin oils recommended for new engines. But, obviously, with time, don't expect it to replace a needed engine rebuild....high mileage oils cannot replace worn parts.
mmarshall is offline
Old 08-13-07, 11:07 AM
UberNoob
UberNoob's Avatar
how is Motul's 5w30?
i know they are good @ motorcycle stuff but i havent heard much about them in the car world
i do have one friend that says their motor oil for car doesnt show up a good UOA on BITOG
Benjamin T's and my mechanic in richmond has barrels of this motul stuff so im curious as how good it is
UberNoob is offline
Old 08-13-07, 11:43 AM
Benjamin T
Benjamin T's Avatar
that's because the motul distributor is literally next door to him in complex his shop is in eh
Benjamin T is offline
Old 08-13-07, 06:07 PM
AzNMpower
AzNMpower's Avatar
Using any of a decent-quality motor oil will yield about the same results. Some people use Redline, Royal Purple, and Mobil1. I've stuck with the German Castrol, which works fine.
AzNMpower is offline
Old 08-13-07, 06:11 PM
mmarshall's Avatar
What's the differnce between the German Castrol and the Castrol sold here?
Old 08-13-07, 06:28 PM
UberNoob
UberNoob's Avatar
made in germany castrol oil (0W30) pwns the quality of US made castrol oil
big difference
UberNoob is offline
Old 08-13-07, 06:58 PM
CK6Speed
CK6Speed's Avatar
big difference
How exactly? I haven't used Castrol in years so I'm just curious. Does the box or bottle say made in Germany or someting? How do you tell the difference?
CK6Speed is offline
Quick Reply: Best engine oil!?
