Toyota/Subaru/Scion Lightweight Sports Car: Toyota GT86, Subaru BRZ, Scion FRS!
Old 12-03-11, 07:29 PM
  #1786
Motor
Motor's Avatar
2013 Subaru BRZ - First Drive Review
Hype, validated: This rear-drive Subaru has the goods.
Some things just don’t make sense. Why is the food at Outback Steakhouse mostly Cajun-style? Why can’t Jennifer Aniston find true love? And why would Subaru and Toyota, two companies whose fortunes are built on mainstream sedan sales, collaborate on a rear-drive sports car?
The latter question is a bit easier to answer from the Subaru BRZ perspective. For one, Subaru has a currently breathing reputation for building sporty cars: They may sell in limited volumes, but the WRX and STI are nevertheless Subarus. And Subaru says that the engine in its BRZ, a 2.0-liter flat-four making its first public appearance in this car, will form the basis of its next turbo motor. For its part, Toyota says that its version of the car—to be sold as the Toyota 86 in Japan, as the GT 86 in at least the U.K., and as the Scion FR-S here—makes sense as a first thrust in its plan to again build sporty, fun-to-drive vehicles. Still, this isn’t a car that most people saw coming from either manufacturer.
Cheese Fries, Please!
Then again, regardless of the boomerangs mounted on the walls and the “Chaze Frois, Plaze!” coasters, Outback Steakhouse’s Alice Springs chicken is delicious—and devastatingly unhealthy, but that’s beside the point. The BRZ is likewise delectable; our only gripe about the way it drives is a chassis that leads to understeer at the limit. That, however, is much less likely to give you a heart attack than a jumbo honey-mustard-marinated chicken bosom hidden under a pile of bacon and smothered in melted cheese. Indeed, right up until the nose starts to chatter off line, Subaru’s new coupe is gifted with exceptional balance and clairvoyant reflexes.
The understeer isn’t a deal-breaker; with perfectly timed and moderated inputs (or with huge, pimp-slap jerks on the wheel and heavy stomps on the go pedal), it is possible to avoid it all together and turn it into delicious oversteer. When the rear end goes, even in the wet, the BRZ slides slowly and progressively. It’s so easy to catch that you might find yourself fishing in your pocket for spare change with one hand while the other meters yaw around an off-ramp. (Subaru says that Toyota’s suspension tune will vary slightly, a tad softer in the front and stiffer out back.) The brake pedal feels a little less wired than the rest of the car, but the binders wind the speedo back toward 0 in a hurry.
Conducting the chassis is steering that is more immediate than anything this side of the Lotus factory. Its heft is perfect for resisting unintentional inputs at the limit. Feedback falls short of perfection, but only slightly; blame the electric steering if you must. The electric motor assisting the BRZ’s rack is mounted high up on the firewall, contributing to a slightly higher center of gravity but simultaneously shifting the front/rear weight balance a touch rearward.
Weight Watchers
In developing the BRZ, Subaru took an almost maniacal approach to weight and its management, keeping it low and evenly distributed between the car’s axles. The company claims that 54 percent of this car’s mass rides on the front wheels and 46 over the rear, and says that its center of gravity is right around 18 inches high. That latter figure rivals or beats the measurements for the Porsche Cayman and Mazda RX-8, among others.
Helping keep the mass snug against Mother Earth is the FA flat-four. Compared to the FB four found in other Subies, the FA’s intake is 2.6 inches lower and the oil pan clings closer to the crankcase, allowing it to be mounted with its crankshaft centerline 2.4 inches lower. Amazingly, the engine is mounted 9.4 inches farther back in the chassis than an Impreza’s four. A Subaru spokesman says the two engines share “maybe a few screws,” but are otherwise completely separate pieces. We’re told the weight difference between the two is negligibly in favor of the A. Placing the engine so far rearward of course helps balance the car, but it also precludes Subaru from fitting an all-wheel-drive system. The company says that it has no room for a turbocharger either, but after peering under the hood, we disagree. Besides, Subaru desperately needs something to tie this car to the rest of its lineup, and a turbocharged STI model would be the perfect solution. Although the BRZ doesn’t need more power, it certainly could handle more. We’re guessing that a turbo will be part of whatever mid-cycle updates this car sees in two or three years.
Despite a displacement difference of just 3 cc, the naturally aspirated FA and FB fours have dramatically different outputs. The B’s 148 hp and 145 lb-ft of torque (as installed in the Impreza) lag 52 and 6 behind the A’s 200 and 151—Subaru’s stated output—while the A’s 7400-rpm redline is 800 higher. Thank Toyota’s fuel-injection setup, which squirts both via intake ports and directly into the cylinder—the system is Big T’s lone contribution to the engine—and allows a crushing compression ratio of 12.5:1. “Crushing” is not a descriptor we’d employ for the acceleration, although we estimate a 0-to-60-mph time of around six seconds flat with the six-speed manual; add a couple of tenths with the six-speed auto. Top speed is said to be 143 mph. A resonator pipes sound into the cabin, and above 5000 rpm, there’s enough noise inside the car that you’ll need to scream to talk. Not that you’ll be having much conversation. That said, we wouldn’t call the quality of the sound unmistakable; it could be taken for a number of undesirable things. Having heard what aftermarket exhaust companies do for other Subaru flat-fours, though, we’re confident that they can coax a better voice out of this 7400-rpm screamer.
In spite of its higher output, the FA should still manage 30 mpg on the highway, according to Subaru. Underbody paneling helps keep a clean aerodynamic profile, although the company still hasn’t decided if the treatment will be standard on all U.S. cars or only on higher trim levels.
Even the Weenies are Treated Well
As mentioned, two six-speeds are available, a manual and an automatic. Following our drive of the BRZ in Japan, the manual had us seeking a temple at which we might make an offering of thanks. The clutch pedal is a touch light—and a touch light on feel—but snaps to attention right off the floor and engages smoothly, and the stubby shifter snicks between gates with ease. Heretics who buy their sports cars with automatics will at least get a good unit. There are two modes in the Subaru: Drive and Sport. Wheel-mounted paddles are standard; in D, the transmission allows them to make gearchange suggestions but still upshifts at redline and downshifts when the driver floors the accelerator. In Sport mode, however, paddle commands are gospel—the way God’s lazy, automatic-driving half-brother intended.
While most of the engineering and chassis work is Subaru’s doing, the styling fell to Toyota. It apparently drew a basic coupe shape and—well, it must have seen it created something less than sultry but stuck with it anyway. It’s good enough. The view from abaft is actually fairly exciting, with the slope of the greenhouse hesitating just slightly to form a decklid before tumbling into the rear fascia. Only the front fascia, badges, and maybe wheels separate the BRZ from its Toyota—and Scion—sibling. The suggestion of flares on the front fenders merely alludes to the muscular (some might say exaggerated) styling of the various concept cars, but the U-shaped view from the driver’s seat over the scooped-out hood is at least unique. Visibility in all directions is much better than most sports cars.
Interior space, on the other hand, is just about par. It’s fine up front, and average/shortish adults might even be happy in the back for shorter trips. Subie touts this as the shortest rear-drive 2+2 on the market. So it is. It also says that the car can accommodate a forward-facing child seat in the back. A rear-facing seat, on the other hand, would probably only fit if the parent riding shotgun rides shotgun in a car following behind. The trunk will hold just seven cubic feet of stuff, although both halves of the rear seatback fold for larger loads. According to Subaru, the space was designed from the beginning to hold a set of racing tires and a toolbox in this configuration, although that claim coincided with a PowerPoint slide entitled “Unexpected Utility”; we suspect that’s probably the real story behind the tire-hauling ability. Or maybe that’s why the tires are just 215 millimeters wide, as fitting a set in the car requires a two-tire stack.
The BRZ goes on sale in spring of 2012 as an early ’13 model, at a base price we’re now told will be around $25,000. Asked to make sense of the BRZ, a Subaru representative says, “It makes sense if you sell enough of them.” In the U.S., Subaru thinks that 5000* to 7000 per year would be enough. Ultimately, though, a car this good doesn’t need to make sense: Its brilliance is all the explanation we need.
Finally: TTAC Gets Its Hands On The 86. And Its Chief Engineer
Today was the day Toyota’s FT86 was officially revealed. Actually, it will be officially revealed at the Tokyo Motor Show, which will open its doors to the public on December 3. Today, the international media had a sneak preview of the car. Us, and maybe 20,000 people who lined the galleries of the Fuji Raceway where Toyota and Gazoo Racing held its TGRF (Toyota Gazoo Racing Festival). The masses could witness from afar as Akio Toyoda climbed out of an orange sports car, removed his helmet and waved at the adoring crowds.
The press corps had a chance to drive the car. That opportunity that was immediately turned into hoonery by a rough and tumble contingent from Australia. One of them drove the car with so much enthusiasm that it spun out , did a few twirls and had a near-miss with an Australian cohort. We immediately had proof that the car provided only the barest necessities in computer control, and that one has to know how to drive, unless a rendition of Swan Lake is desired.
Before we get to that, the essentials. The name of the car had been the target of endless speculation. Until yesterday evening, Toyota steadfastly referred to the car as nothing else than a “compact real-wheel-drive sports car.”
Some at TTAC had recommended that the car should get a Japanese name. Toyota listens to its customers and complied.
The car will be called “Hachiroku.”
This is Japanese and means 86.
Yes, Toyota simply dropped the “FT”. It also wants to carry on the spirit of the AE86 of lore.
For me, the most interesting part of today was to sit in a quiet room with Tetsuya Tada, and a handpicked group of journalists. (The man on the right is Hans Greimel of Automotive News.) We could listen to Tada’s comments about the car. We had talked before, in August, but this time, the Chief Engineer of the 86 could be less circumspect and was able to talk openly. He sure did. For starters, I learn that Toyota’s test drivers had given him a very hard time:
“Mr. Toyoda almost continuously participated in the development of this car. Not as President, but as a test driver. Usually, when they say that the president of a company is test driving a prototype car, then it is mostly ceremonial. Mr. Toyoda’s participation was not simply ceremonial. He was a serious test driver and had some pretty tough comments. In some phases of the development. he said: “If that is the best you can do, why not quit now.” One by one, we overcame these problems.”
In the grand scheme of things, Akio Toyoda had been polite. Stronger words came from Hiromu Naruse, Toyota’s chief test driver who found an untimely death by crashing his LFA into a BMW 3series on a rural highway close to the Nürburgring. Tada remembers:
“When Naruse-san was still alive, he participated in the tests many time and gave us some quite harsh comments, like: ‘This is a miserable car. You are doing very poorly.’
We tested this car at the Nürburgring. Naruse-san died very close to the Nürburgring, and each time we testdrove the car later, we made sure to pass by the memorial of Naruse-san. We tried to keep Naruse-san’s spirit alive.”
One by one, the challenges thrown up by the test drivers were met. But there were other people, Tada had to contend with.
“We visited with car enthusiasts in Japan, America and Europe. The feedback we received was almost always the same. They said there are a lot of sports cars with high horsepower that are very fast, but these are not the sports cars that they want to have. They want small compact cars that are controllable, that they can tune themselves. However, that kind of sports car is not on the market. Therefore, these sports car enthusiasts are forced to continue to use older cars from a long time ago, because there is no new alterative on the market.”
Their requirements clashed with another group: Toyota’s board. The board wanted a car that goes faster than other cars. Tada’s colleagues at other car companies had to contend with the same problem:
“We also went to competitors and asked them: “Why do you focus on fast cars?” The response almost always was: ‘Actually, we really don’t want to develop these kinds of cars. But once we bring a plan to develop that car to our board, the first question the directors of the company would ask is: How much faster is that car compared to what the competition has? How many seconds faster around the Nürburgring? What about the acceleration? These questions always come up because numerical performance is the easiest to understand.
Now how did we get the permission from our board? The only reason was that among the directors, there was a person called Akio Toyoda, who is a car enthusiast himself.”
Tada not only had to convince a board that was fixated on numbers. He also had to do something highly risqué: Ditch the Toyota Way of developing cars:
“There is a Toyota standard for designing new cars. This standard was to a large extent ignored. Why did we do this? There are cars that are accepted by a lot of people. Practical cars that are easy to drive and that do not break easily. These are standard Toyota cars. The 86 is not a car like that. We had to change our design approach for this car. We may have to do this again for other cars.
It is impossible to develop a sports car that appeals to everybody. If you try to please everybody, the car would be half-baked for everybody, and not particularly good for anybody. This car is not developed by a committee, or by consensus.”
And would you believe that even Toyota’s advertising department did not like the car?
“When we first presented this idea to our advertising people, they were drastically opposed to this idea. They complained that the car doesn’t have a particularly fast time on the circuit, it does not use any new technology. They also could not think of a catchy headline for the catalogue.”
Someone should have a chat with that advertising department.
The word of mouth enthusiasm for this car is so strong, maybe it doesn’t need any advertising. Thousands of grassroots racers around the world are looking forward to a car they can tinker with. Tada built it for them:
“To make the car customizable, we did away with computers to the highest extent possible. A lot of the cars on the market today are controlled by computers. People have the feeling that they are driven by the car instead of them driving the car. That makes for a boring experience. That is why we decided to go back to the basics of car making. With the low center of gravity, the driver now is in personal touch with the road again.”
How much will this car cost? This remains a state secret. All Toyota says is that it will be “affordably priced.” Asked what that means, Tada launches into a dangerous discourse, with his press handlers getting visibly nervous:
“30 to 40 years ago, there was an AE86, and the price of this car was 1.5 million yen. At the time, that was the starting salary was for a university graduate. We kept that in mind when we priced the car. In the meantime, there has been a rise in prices, and the starting salaries rose also.”
The starting salary of a university graduate in Japan is around 2.5 million yen. In today’s undervalued dollars, this would be around $32,000. We will have to wait until early 2012 when the car is officially released. There will be no pricing announcement at the Auto Show.
All the specs that are available can be downloaded here.
Ah, the test-drive.
I drove the same 86 the Aussie hoons pirouetted through a sharp turn. All I did was make the tires chirp. At a test drive, I like to return the car as I found it. It drove very nicely. It does not press you into the bucket seat with jet fighter g-forces. I am told it will do 230 km/h (143 mph) and will go 0-100 km/h (0-62 mph) in 6 seconds.
Would I buy it?
Yes.
Motor is offline
Old 12-04-11, 11:47 AM
  #1787
spwolf
spwolf's Avatar
Originally Posted by Kostamojen
Question for the Lexus experts here:
This is the FRS/BRZ rear diff, its the same case as an IS apparently but with the Torsen diff (IS-F?)
My question is this:
What kind of differential is this? R180, R190, R200 or a different nomenclature all together?
Toyota owns JTEKT thats makes/owns Torsen, so it can be any of their units. It is probably T2 based:
http://www.torsen.com/files/Torsen%2...al%20Sheet.pdf
Latest publicized application for T2 was for Mustang Boss 302 / Laguna Seca edition.
JTEKT is also one of the biggest world producers of EPS, so EPS is quite likely theirs. They just introduced new type of DP-EPS in 2010, and reports suggest that EPS in FRS is steering rack mounted, which is exactly what DP-EPS is.
Toyota also owns AISIN which makes both manual and AT transmissions for FRS.
spwolf is offline
Old 12-04-11, 05:55 PM
  #1788
Motor
Motor's Avatar
http://youtu.be/xBrdFQux7nE
FORMULA D TOYOTA 86 RENDERING
You will have to forgive us if we seem to be going a little 86/BRZ/FR-S crazy lately. But come on, we've been waiting so long, can you blame us? This latest post however is of the computer generated variety, a really impressive rendering made by Italian up and coming car designer Lorenzo Oujeili. Lorenzo has put some thought into what a possible 86-based drift car could look like. Check out the little details like the Volk Racing TE37 SLs, the reversed Speedhunters windscreen banner, Fatlace and illest stickers and of course the Fujiwara Tofu Ten on the side.
Motor is offline
Old 12-05-11, 01:59 PM
  #1789
Motor
Motor's Avatar
Subaru BRZ Convertible Rendering
There have already been rumors of a convertible version of the BRZ and now a rendering of the model has been released on theophiluschin.com. This looks interesting ,even though, if you ask us, the vehicle now comes with a much softer image. But there’s nothing a few braces and a decent body kit can’t fix.
Two thumbs down.
A bad idea just like this one:
First Drive: Subaru’s new BRZ coupe
Yes, we’ve finally got behind the wheel. Ollie Marriage reports back from Subaru’s Japanese test track
First of all, let’s solve the mystery of the name. BRZ stands for Boxer, Rear-wheel drive, Zenith. That’s pretty clear isn’t it? Well, the first two parts are, and as for Zenith, that’s just Subaru’s way of saying this is the best it can do. Personally I think Subaru Zenith has more of a ring to it than Subaru BRZ which, let’s face it, isn’t exactly a dynamic name.
And this is a shame for a rather dynamic car. That’s right, we’ve finally, finally driven the BRZ. We had to go all the way to Subaru’s test track, two hours north of Tokyo to do so, but it was worth it.
So where to start? As suspected, both Subaru and Toyota have had specific tasks within this joint project. Toyota has been responsible for the design (certainly not the most dynamic aspect of the BRZ), and has lent its direct injection technology to the engine. Subaru has done pretty much everything else. Talking to the engineers you get the sense this is very much Subaru’s car – the first development prototype was a cut n’ shut Legacy, the next an Impreza. This is good news, as we know Subaru can build great cars. The BRZ clearly has potential.
It’s a brand new car from scratch – a rare thing these days. The engine is mounted so low, Subaru believes it has a lower centre of gravity than a Ferrari 458. And a low engine is not only good for handling, but also means the driver can be sat low, yet still see over the bonnet. It’s snug inside, the design largely functional, the colour scheme mostly grey. It’s no Audi TT, but the impression is good because you’ve dropped so low into a wrap-around seat and your hands are clasping a small, feelsome wheel.
The driver’s seat is definitely the place to be. Subaru boasts that this is the world’s smallest four seat rear-wheel drive coupe, so you can guess what that means for those travelling in the back. And the boot seems to be a complete afterthought.
But enough of that, it’s the driving that counts. The 2.0-litre flat four is naturally aspirated, revs to 7,400rpm and develops 200bhp and 151lb ft of torque. These, you don’t need me to point out, aren’t massively impressive figures these days. And the BRZ isn’t a massively fast car. Final homologation happens next month, the expectation being a 0-62mph time of around 6.8secs with the CO2 target being 160g/km. I’d guess at a top speed of around 145mph, and 42mpg on the combined cycle.
It’s light though (1,220kg), and Subaru has worked the torque hard, so although the peak is between 6,400-6,600rpm, you have almost all of that before 3,000rpm. Put your foot down at low revs and it picks up healthily, aided by super-quick throttle response. But it tails off a bit through the mid-range, meaning you have to head for the high numbers to get your kicks. And that’s where the BRZ is at its best. It zips through the final 2,000rpm, feels keen and energetic and then, well, and then there’s the noise. We have high hopes…
Of course, it sounds different. This Boxer doesn’t chunter and warble like an old Impreza, it’s a smoother note than that, still slightly off-beat and noisy enough without being intrusive. It’s not Honda Type-R addictive, but it’s a plus, a whack more interesting to listen to than any four cylinder turbo you care to mention (VW Scirocco? Renaultsport Megane? Mini Cooper S?). It makes this a fun engine to use, but it’s not the best thing about the car.
Because the best thing is the handling. The BRZ steers like it has no weight to deal with. It doesn’t appear to roll, pitch or dive. It’s neither nose nor tail heavy, just a sense of the front and rear working in perfect harmony. You steer, it goes and when the grip runs out (it was pouring with rain in Japan), the BRZ is almost totally neutral. And you get so much warning of when that’s about to happen. I was nervous when I found out it had electric power steering, but this has to be about the best system I’ve tried – the springy weighting is lovely and real sensations are fed back into your hands.
How best to describe it as an overall package? Keen. Eager. It’s not puppy-ish in its enthusiasm, it’s a bit more measured than that, but it’s a lot of fun. Easily better to drive than a VW Scirocco; more agile and rewarding than any Audi TT. It may not have the lungs on a Nissan 370Z, but it’s way more dextrous and I can’t think of any hot hatch except possibly the Renaultsport Clio that provides as much satisfaction.
You can still tell that it’s a Subaru at heart – not just in the engine, but the steering and manual gearbox – but it’s like they’ve let Lotus loose on the chassis. Well, almost. The light frame does get a bit thrown by big bumps, but it never feels unnerving, instead it inspires confidence.
The manual gearbox is really good – mechanical and precise – and the six-speed auto is better than expected. It’s not a double clutch, but it’s just fast enough and intelligent enough to justify its presence in a sports car.
Any other criticisms? Well, being honest, the BRZ seems slightly out of step with other rivals. Subaru has ditched the turbo just as others have adopted it, it’s available with an unfashionable auto rather than a double clutch, the biggest wheels are likely to be 17s, there’s no adaptive damping or any other chassis trickery. But does this matter? It will to some buyers, just as the styling is too plain to tempt others. But if you enjoy driving, if you relish the thought of a compact rear-drive coupe, this is the car for you. Roughly 1,000 per year will come to the UK, starting in June, with prices from around £26,000-28,000.
First Drive > 2013 Subaru BRZ
The Masters Of AWD Nail RWD
A couple of years ago we passed the point at which there were no more truly bad cars. If someone asked us, "Which car should we definitely avoid," it was hard to give a categorical answer. Sure, there were cars we didn't (and still don't) like, but no matter how personally averse we might be to even some current cars, we can't name one that's objectively awful.
Naturally, then, if everything is decent then the only place to go is... better. That's how you get to a brand like Subaru deciding to make a sports car and using, as a guide, the Porsche Cayman. And we do mean literal guide. During testing, Subaru engineers took a white Cayman on their international travels. We don't blame them. When the brief is to build "a pure handling sports car," where better to start than with the company that practically wrote and constantly revises the bible of handling, Porsche?
As a brief for a company like Subaru to have – a company not known for sports cars and that hasn't sold a two-wheel-drive car in the U.S. since the last millennium, which were front-wheel-drive wagons – that's impressive enough. What's more impressive is that they actually did it.
Subaru head of Corporate Communications Michael McHale started off his presentation with these sound bites: "The type of engine and where it is, those are the two things about the car. Everything else comes from there... The engine is as low down and far back as it can possibly be," and "We didn't start by saying it had to be rear-wheel drive, we started by saying it had to have the engine in a certain place. Handling first, RWD second."
The result, as we know by now, is the BRZ – B is for Boxer, R is for Rear-wheel drive, Z is for Zenith, as in the best. The quest was to "get a new level of driving confidence," and that resulted in traditional sports car themes: low, with short overhangs, a compact engine and a low center of gravity. The CoG is lower than a Ferrari 458 Italia, and at 18.1 inches it's also lower than the Cayman, the Mazda Miata and RX-8, and the BMW M3.
Low weight was also a priority. Subaru said the target was 2,700 pounds, and according to the numbers we were given, they beat it by about half a sack of potatoes, coming in at 2,689. Although that's 100 pounds less than a Civic SI and 600 less than a Mustang, it's better to judge the BRZ against a more natural competitor: the BRZ is 10 hp and 73 lb-ft down on the Hyundai Genesis Coupe, but is about 600 pounds lighter.
The engine is an all-new design called the FA, with a perfectly square stroke of 86x86 and a variable-valve control system that Subaru calls AVCS, for active valve control system. The FA was developed for and only used in this car, "at least for the time being." On the required premium gas, Subaru's numbers are 200 horsepower and 150 pound-feet, with reps at a loss to explain why Toyota rates the same engine – that Subaru builds – at 197 horsepower. The FA is smaller than the Impreza's FB engine, achieved with items such as a shorter and lower intake manifold, a shallower bottom on the transmission, and revised, more compact lubrication system. Subaru then placed components in different places to get the engine further back in its bay, like making the intake manifold front-facing and placing the crankshaft 60 mm lower. The induction system was shorted to reduce overhangs, and the radiator was tilted 17 degrees to improve the center of gravity. Compared to the Impreza, the BRZ's engine is placed 120 mm lower and 240 mm further back.
And that's why there's no turbo, and no plans to include one – the engine occupies the space where Subaru would normally bolt one on. They moved so many things around, we don't know why they couldn't have been just as creative with some forced induction, but the company's traditional placement of the intercooler atop the engine simply wouldn't have worked. Subaru plans a longer life-cycle for the car, six to seven years instead of four to five, and it was strongly hinted that we would see a power bump during a mid-cycle refresh – but not a turbocharged bump. We were told as well, though, that this engine will be the base of Subaru's next-generation turbocharged engine.
The engine placement necessitated changes to the front suspension: the MacPherson struts needed to be revised in order to maintain the low profile of the aluminum hood and keep the desired stroke, and the A-arms are reversed, pointing forward. The mounting point has been strengthened by adding an aluminum box section. That aluminum hood saves 15 pounds over the Impreza hood, and of the 400 materials used for the body, there is more high-strength steel on this car than on an Impreza in order to keep weight where it's wanted.
The final numbers: overall height is 50.6 inches with a ground clearance of 4.9 inches, length is 167 inches and wheelbase 101.2 inches, the width is 69.9 inches with a track of 59.8 inches in front and 60.6 inches in the rear. Balance is estimated to be around 53 percent in front, 47 percent in the rear. The company doesn't have official numbers on gas mileage but predicts 30 on the highway.
It's a good looking car, its most poignant ornamentation being the two bulges over the front and rear wheels, its stretched (and non-functional) hood vent a nice touch. The lightweight aluminum wheels are about the only visual cue that strikes us as a little off, or rather, the 245/45 R 17 tires: They're so skinny. Other markets will be offered 16-inch wheels, but we'll only get the 17s. We were told that the BRZ can handle 18-inch, 45-aspect-ratio tires, and we won't be surprised to see them quickly bolted on. On the matter of bolt-ons, though, Subaru won't be offering much alteration to the car off the dealer floor, but we were informed that the STI division is already at work on a host of parts.
The rear wing is optional, part of a performance package that also expands the underfloor treatment. Yet another reversal on this car, the spoiler is only for aerodynamics, not to reduce lift. With the wing in place, the coefficient of drag is actually reduced by less than a point, to 0.27.
Subaru has plenty of experience making the most of black plastic, and the BRZ cabin doesn't let down, with various textures and minor bits of trim like metal-look finishing on the center console and (Legacy) door handles, and contrasting stitching on the shift boot and (Legacy) handbrake handle being enough to break things up. On top of that, the seats are excellent. Large bolsters hug the driver properly, and the canted, adjustable headrest doesn't jut into the back of your head. Specifically designed for this car, they save 2-3 kilos compared to the seats in the Impreza. Base spec will be cloth, which really means cloth bolsters with a "sporty fabric" on the facings, and leather and Alcantra, with leather being on the bolsters. Both of them are nice to behold. The BRZ is classified as a 2+2, and even the back seats are serviceable for passengers of decent height, due to the smaller, saddle-shaped fuel tank they sit atop – if you must, you can fit a front-facing child seat in the rear.
You can also lower the rear seatback, making more room for the 6.9-cubic-foot trunk. With the seats down the cargo bay will hold two standard golf bags, and with the front passenger seat down as well the BRZ can hold a set of racing tires, a helmet and basic tools. Another concession to racers: the instrument panel was designed so that a roll cage could be installed without having to cut through any metal.
We got short stints behind the wheel of both the six-speed manual and the automatic at Subaru's Test and Development Center in Tochigi prefecture, two loops on the high-speed oval (limited to the middle lane) and a couple of blasts around the handling course. The handling course, as one might expect, is tight, and so not really made to show off the BRZ, which we were told was designed for high-speed corners. There was also a short section with two different surfaces imitating American roads, one a typical highway and one a California highway.
We bemoan the lack of manuals in high-end sports cars, but this price segment is wonderfully thick with them and many are delightfully good. The BRZ is no exception. The transmission is from Aisin (the automatic, too), but 80 percent of its components were swapped to enhance feel and quicken shifts, and it was given triple-cone syncros on gears 1 and 3. It has shorter spacing and quicker throws, and runs through its six speeds smartly. Another nod to manual operation is that the pedal rake is different for either transmission, and the pedal throw is shorter on the manual to make heeling-and-toeing easier.
We pulled out onto the oval and worked up to speed. Two hundred horsepower is enough for the sub-2,700-pound coupe, with the urgent-enough grunt, plentiful road feedback and engine noises making it feel like things were happening, but we wouldn't complain about more, a fact which shouldn't surprise you (the BRZ GT's 300 hp, anyone?). We aren't alone: One of the engineers, when asked what how he might alter the coupe, said "For the handling there's nothing to do, but yes, maybe a little more power."
The MT BRZ also sounds like a sports car – it's what the English would call "rorty," with an engine note that fills the cabin whenever you call for action, getting a little help from the sound amplifier. When you get into the meat of the power band beyond 3,000 rpm, the boxer four is asking for attention, at 4,500 rpm it's intense, at 5,500 rpm it's telling you "We gotta make something happen here," and at 7,000 it's a 12-banshee wail. With one hand on the shift **** and the accompanying acoustics, you'll never wonder what gear you're in. Even so, it is mild when you're not pushing it, whether that's puttering around a parking lot or cruising at 90.
In spite of what McHale said were the two handles for getting a grip on the car – "What kind of engine and where it is" – we think the BRZ only needs this one, another McHale statement: "It's about handling." No, make that three: handling, handling, handling. Engine compactness and placement might be how they got to it, but what the BRZ meant to us was the way it dealt with the road.
The stiffness of the BRZ's body and low center of gravity allow the suspension to focus on dealing effectively with the tarmac while also not killing the ride quality. Side benefits of that stiff body, and the help it gives to the suspension, are in details like the tires, which don't need ultra-stiff sidewalls to fight cornering forces. That helps general comfort, too.
There is but a tiny amount of body roll when making quick lane changes at 70 mph, and when in the middle lane of the banked corner at 100 we felt the entire coupe settle – thanks to centrifugal force – but there was no sensation of the passenger's side taking a dive. More telling was lapping the oval in the bottom, flat lane, where we could do 100 miles an hour just as easily as on the bank. The electronic power steering is sorted, with a dash of give so you're not constantly tweaking the wheel but also not sloppy in the least; without the assistance of the banking the steering never called attention to itself. Once we had the wheel set for the radius, there was no concern about getting around at triple-digit speeds – just a hint of the suspension compressing with such little fuss that we were certain we could have gone faster.
Brake dive has also been minimized – in fact, there's practically none. The double-wishbone rear suspension uses the same components as the Impreza WRX STI, but with different geometry and detailing: pillow-ball joints replace rubber bushings on the wishbone arms (the WRX STI has pillow-ball joints on the front, not the rear, while the BRZ doesn't have them up front), hard rubber bushings are used on the trailing arm to keep the rear down, and a special valving was developed for the dampers to provide a suitable compromise between highway hop (over frequent expansion joints as on California highways), roll, maneuverability and stability. Of note, we were told that the Toyota/Scion version has softer suspension settings up front, harder settings in the rear.
The handling course had a top speed of 30 mph through the corners and 45 mph on the straights, which we're not sure if we should admit we broke, but... we did. The BRZ acquitted itself well, the zero-dive braking and turning letting one focus on timing and getting the wheels placed where we wished and keeping them there, which made it easier to get out of the corner – because with "just" 200 hp to play with, every bit of momentum you can maintain is precious gold. The eminently grippable steering wheel is the smallest Subaru makes, at 14.4 inches it's ¾-inch smaller than the next size up, and its 13:1 ratio doesn't demand much sawing to get through hairpins. Pushed as much as we could (noting the Subaru engineers posted at every corner), even with VDC off we were getting to the point of admitting "Now we're just getting crazy" before the front or back end stepped out of line. And yes, you can turn VDC completely off.
In keeping with being told that the car is meant for high-speed cornering, however, the brakes might also see some upgrades before long. They're two-piston up front, single-piston in the rear, and they get a workout even with the car's light weight. Go for broke on a turny, tight course and it won't take long to fill the air with the tangy perfume of hot discs and pads.
The only odd note here was the speedometer. It is placed to the left of the center-position tachometer, with zero at the bottom, and the needle swings clockwise. It has so many hashmarks and numbers that it took too much effort to read, so, à la any Aston Martin, we only looked at the digital speedo inside the tachometer.
Because the BRZ is about handling and does that job so well, we knew we'd be happy in the automatic-equipped version as long as it shifted properly. And ye gods, it did. The Aisin unit is a conventional autobox, reworked by 20 percent to improve its clutches, shift times, gear-holding response and even alterations to its mapping if you're driving uphill or downhill. In both normal and sport modes, it will be happy to stay in the fat of the power band, it will hold gears during cornering and rev-match on the way down. It doesn't always allow downshift multiple gears at once, but there are times when you can hop down two gears instantly depending on engine and car speed.
It has paddle shifters and a manual mode, and if you don't shift at all it will automatically upshift when you're in the overrev. Otherwise, in Sport it will upshift at about 5,500, and you get quicker shifting. The in-cabin sound amplification is set up differently on the automatic, so the cabin is quieter than in the manual. You don't notice it down low or when cruising, but push it some and it's noticeably less raucous inside. It is quick to work the gears when we wanted more juice on the oval, and it did a good job when we left it to shift on the handling course. We probably could get another 15 percent out of it during the artificially limited running, but we suffered no "Hey tranny, what are you doing?" moments. It never let the coupe down, and the package worked well enough that, taking into account its quieter cabin, we can fully admit that the auto will make perfect sense even for people who want a part-time sports car.
To you in Southern California, though, if Subaru's concrete samples were accurate, then you will find that those nasty, grooved highways like the 10 and 405 are not kind when it comes to cabin noise.
When the BRZ goes on sale next March it will come standard with navigation, the 6.1-inch display, 196-watt AM/FM/single CD stereo, iPod and USB connections and Bluetooth, and heated mirrors. Options will be few, namely convenience items like the leather and Alcantara buckets, heated seats, dual-zone climate control and keyless access.
Subaru doesn't expect high volumes for the car, just 5,000 to 7,000 per year. The Cayman comparisons aren't out of place, nor is the suggestion – again made by McHale – that Subaru built a car that feels like a sports car from 20 or 30 years ago. True, it isn't a Cayman, but it will cost easily 20 grand less than a Cayman* and yet provides easily more than seven-tenths of the Cayman's pure cornering ability, and that's probably closer to eight-tenths, but we won't know until we get more time with the car. And it does bring back happy days of yore passed on Midwestern back roads in '80s Celica Supras and Preludes and first-gen Miatas. Those were good times, and so is the BRZ.
The asterisk is because we still don't know pricing, which we were told should come sometime around next February's Chicago Auto Show, and we think price will play an exceptionally heavy role in this car's fate. We heard every number from $22,000 to "somewhere around the WRX," which is $25,595, to $28,000. Of the broad competitive set Subaru listed, a 210-hp Genesis 2.0T Coupe starts at $22,250, a 300-hp V6 Mustang is $23,105, the Mazda Miata is $23,190 and the RX-8 is $26,795.
There is no doubt about whether the car does what it was built to do – it handles terrifically, it sounds great especially if you're a fan of high-revving fours, it's a solid shifter with either transmission and a pleasant cabin. Yet Subaru hasn't played in this space before and they're expecting this to be a conquest vehicle. We think in order to give it the attention it deserves it needs to have a price that makes it impossible to ignore, at least for a test drive and serious think. Having not driven its biggest competitor and close twin yet, the Scion FR-S, we'll say for now that if Subaru can put a good sticker on the BRZ's window, then – as the engineer suggested to us – it needs nothing else.
Except maybe a little more power, because we're greedy like that.
Motor is offline
Old 12-05-11, 06:37 PM
  #1790
4TehNguyen
4TehNguyen's Avatar
http://www.topgear.com/uk/car-news/s...iew-2011-12-03
See all the pictures from the Subaru BRZ first drive
4TehNguyen is offline
Old 12-06-11, 11:09 AM
  #1791
spwolf
spwolf's Avatar
it looks stunning in red and that kit.
spwolf is offline
Old 12-06-11, 11:30 AM
  #1792
jwong77
jwong77's Avatar
Two thumbs up for this one! Nice!
jwong77 is offline
Old 12-06-11, 12:14 PM
  #1793
Hoovey689
Hoovey689's Avatar
wow is that OEM or aftermarket? either way
Hoovey689 is offline
Old 12-06-11, 01:37 PM
  #1794
Motor
Motor's Avatar
Repost - it's the post right above yours.
[it looks stunning in red and that kit.
And is that red the same 3PO "Absolutely Red" that was used on the Celica? It looks great.
Motor is offline
Old 12-06-11, 02:22 PM
  #1795
Motor
Motor's Avatar
2013 Subaru BRZ First Drive
A Back-to-Basics Coupe for the Serious Enthusiast
First Impression:
An enthusiast-focused sport coupe that forgoes big horsepower in favor of precise handling.
It's cold, gray and damp at Subaru's proving grounds about an hour north of Tokyo. Perfect weather for wringing out an all-wheel-drive WRX maybe, but today we're behind the wheel of the new 2013 Subaru BRZ Coupe. Lighter, less powerful and rear-wheel drive, the BRZ promises something very different from Subaru's bigger and heavier Impreza-based sedans.
As on most test tracks, there are various rules we were asked to follow. No more than 100 mph on the oval, no more than a few laps on the infield handling course, the usual preservationist restrictions. It's not surprising given there are only two U.S.-spec cars on hand, one a six-speed manual, the other a six-speed automatic, and there are no spares around if someone detours into the weeds.
We try not to think about that as we accelerate onto the straightaway with the gas pedal pinned to the floor. Sure, there are rules, but we've been waiting to drive this car for a couple years now and we're not about to leave until we see if the 2013 Subaru BRZ lives up to the hype.
Yep, It'll Spin the Tires
A firm yank of the shifter into 2nd gear and the BRZ lays a small stripe with a chirp. There may only be a 2.0-liter, four-cylinder under the aluminum hood, but it definitely has some kick. In fact, the all-new flat-4, or "FA" engine as Subaru calls it, can deliver nearly all of its 150 pound-feet of torque at just 2,800 rpm.
It's only a momentary burst of torque, though, as it falls off a bit before rising again at 4,800 rpm. It then peaks at 6,300 rpm and stays flat right through 7,000 rpm. That's where the 200-horsepower peak sits, too, and the redline is another 400 rpm after that.
Building speed down the straight, the engine spins smoothly but sounds gravelly. Even with a sound-induction tube plumbed into the cabin for added effect, the 2013 Subaru BRZ isn't going to win over any converts with the noises it makes.
When we snap the gearbox into 3rd there's yet another chirp from the tires. There's no doubt about it now, the BRZ gets its power to the ground very efficiently. Subaru says it uses more than 400 different variations of high-strength steel in the body of the BRZ to give it plenty of rigidity while keeping the curb weight in check. The result is a BRZ that came in under its target weight at 2,690 pounds according to Subaru. That's about 100 pounds less than a Honda Civic Si, and it feels like it, too.
Two Great Transmissions
After a few laps at varying speeds, the biggest eye-opener is the BRZ's new six-speed manual gearbox. Compared to the rubbery vagueness of the shifters in the WRX and WRX STI, the BRZ's Aisin unit feels far more precise. We have no trouble finding the gates and it moves with a mechanical feel that makes ripping gears in the BRZ more satisfying than any Subaru we've ever driven.
We swap into the automatic car for a few laps and it's shockingly good, too. It's a conventional automatic with paddle shifters and two driving modes. We leave it in Sport and watch as the tachometer swings right to redline and then shifts with an instantaneous pop. There's probably a dual-clutch setup out there that's faster, but not by much.
Under hard braking it pulls off rev-matched downshifts, too, sometimes dropping more than one gear at a time. And in manual mode it'll let you bounce off the rev limiter all day without slapping your hand by upshifting for you. Other than the plastic shift paddles, there's little room for improvement.
The Big Test
Throughout our introduction to the car, Subaru officials insisted that everything in the BRZ was geared toward making it handle well. This meant getting the engine mounted as low and as far back in the chassis as possible to drop the BRZ's center of gravity.
To get there they first designed the engine to be as shallow as possible from front to back so it could nestle up to the firewall tightly. Then they flipped the lower control arms of the MacPherson strut front suspension used in the Impreza to open up even more room down low. They also moved the electric steering box from the rack to the top of the column to get it out of the way. Even the battery was relocated to a space behind the strut towers to get its weight farther back in the chassis.
To see how it all feels, we dive down into the tight infield handling course for a few laps. After the first dozen turns or so, the most obvious handling trait is the BRZ's buttoned-down chassis. It doesn't dive under braking and barely tilts when we turn. It feels much more tightly wound than the WRX, which has plenty of give to it before it really starts to dig in.
The steering is also noticeably quick. There's instant response off center and never any sense that the electric-assist system is falling behind. With the stability control turned completely off (just hold the button for 3 seconds) the BRZ understeers just a little bit before starting to swing its tail out.
Absolute road feel is the biggest drawback here, as it's hard to get a good sense what the tires are really doing. The tires themselves are 215/45R17 Michelin Primacy HPs, which are certainly not overly big or sticky. We asked Hiroyuki Nakada, chassis engineer for the 2013 Subaru BRZ, why they didn't use more aggressive tires similar to those on the WRX. He said the BRZ's low weight means it doesn't rely on grip as much as heavier cars like the WRX, so it simply doesn't need that much rubber on the road. That said, he also mentioned that the Primacy tires deliver better mileage and comfort, so there's obviously some room for improvement here.
It's the same story with the brakes. They're not overly large and use only two-piston calipers in front and single pistons in back. On paper they're not very aggressive, but when we get into them hard from around 100 mph they bite just fine and have little trouble stopping the BRZ.
It's Easy To Overlook the Rest of the Car
With hardly enough time to get a sense of the BRZ on the track, we barely even notice the interior, mostly because it's a very straightforward setup with few options. There are two trim levels — Premium and Limited — and both get a fairly extensive list of features.
There's a standard navigation system, Bluetooth, satellite radio, HID headlights and a limited slip on all Premium models, while the Limited adds leather seats with Alcantara trim, auto climate control, seat heaters, push-button start and the all-important foglights.
Yes, there are backseats and no, they are not very comfortable. Subaru went to great lengths to open up the interior space but there just isn't much room to work with. It's a smaller car than you think, with a wheelbase of just 101 inches. The fact that there's still a trunk with 6.9 cubic feet of usable space is a pretty remarkable piece of packaging.
The Takeaway
This 2013 Subaru BRZ is not for lightweights. Anyone who picks one up merely because it's nice-looking and gets decent mileage (estimated 30 mpg highway) will likely end up hating it. The ride is too stiff, the engine is too noisy and the tires are too loud. In other words, this is a car for true enthusiasts.
Granted, it's not terribly fast and probably won't lay down eye-popping track numbers, but it gets the basics right. A lively, predictable chassis, plenty of usable power and two different transmissions that both work exactly the way they should. Not to mention fully defeatable stability and traction control.
Subaru hasn't said exactly how much it expects enthusiasts to pay for the BRZ, but officials have hinted that it will fall closely in line with the pricing of the Impreza WRX. That means a base price of around $25,000 when the BRZ goes on sale in May of next year. Expect to see them clogging up track days all over the country by the end of the summer.
One more review.
Motor is offline
Old 12-06-11, 03:11 PM
  #1796
spwolf
spwolf's Avatar
nah, 3P0 looks washed out these days... it is still around as toyota's non-metallic color, together with 068 white. But they just got a bunch of brand new colors - darker shade of red looks great on new yaris (3N8) and new 2013 GS.
although, specs sheet from toyota japan had completely different color codes which i assumed that would be subaru one, so they might be using subaru colors or subaru naming, who knows... in any case, for these new cars, it seems that they significantly changed them.
spwolf is offline
Old 12-06-11, 03:12 PM
  #1797
spwolf
spwolf's Avatar
its JDM OEM... toyota had them at Fuji introductions... these are the ones we saw camoed at ring as well.
spwolf is offline
Old 12-06-11, 04:35 PM
  #1798
ST430
ST430's Avatar
a couple of quick questions:
- is this 87 octane or 91 required (no info released)
- is it full size spare or mini?
btw - Taiwan rocks a lot off Toycos, I mean a lot everywhere, especially the cabs!
ST430 is offline
Old 12-06-11, 04:37 PM
  #1799
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
I like this size comparison:
PhilipMSPT is offline
Old 12-06-11, 05:00 PM
  #1800
ydooby
ydooby's Avatar
1. Premium fuel required, given such a high compression ratio.
2. Comes with a donut spare, at least in the prototype that C&D tested.
http://www.caranddriver.com/reviews/...pockets-page-1
An organizer can be had instead if you choose to have no spare, it seems.
ydooby is offline
Quick Reply: Toyota/Subaru/Scion Lightweight Sports Car: Toyota GT86, Subaru BRZ, Scion FRS!
