Toyota/Subaru/Scion Lightweight Sports Car: Toyota GT86, Subaru BRZ, Scion FRS!
#2131
#2133
Guest
Posts: n/a
Considering a much heavier 300hp V-6 Camaro gets 29 or 30 MPG highway, yeah its not great. The 34 MPG rating though is fantastic for the automatic only 3 MPG less than a 1.5 liter hybrid CR-Z.
Also didn't realize Scion offers 2 year/25k maintenance which helps add more value to the car.
Overall I hope this flies off shelves, all the triplets.
#2134
6MT
1st gear - 3.626
2nd gear - 2.188
3rd gear - 1.541
4th gear - 1.213
5th gear - 1.000
6th gear - 0.767
Reverse - 3.437
Final gear ratio - 3.727 (cheaper model) / 4.100 (upper trim)
6AT
1st gear - 3.538
2nd gear - 2.060
3rd gear - 1.404
4th gear - 1.000
5th gear - 0.713
6th gear - 0.582
Reverse - 3.168
Final gear ratio - 4.100
It is all in the gearing, manual is meant for the track and hence short gears that should work well there... AT is for regular people.
1st gear - 3.626
2nd gear - 2.188
3rd gear - 1.541
4th gear - 1.213
5th gear - 1.000
6th gear - 0.767
Reverse - 3.437
6AT
1st gear - 3.538
2nd gear - 2.060
3rd gear - 1.404
4th gear - 1.000
5th gear - 0.713
6th gear - 0.582
Reverse - 3.168
#2137
Where are you guys getting the 35 mpg number? Yesterday Autoblog reported 22/30 for the manual model and 25/34 for the automatic. If it does get 35, then that is more than enough.
#2141
Scion has good equipment, everything you need. $25k is high because everyone talked about it as $20k car for a while. When you compare it to Miata, it is actually cheaper and faster.
#2142
That pricing is incorrect. I just got the email from SCION now.
It is $24,930 MSRP for the 6M. Which makes the Auto around $26k. Quite a bit higher than i expected....
http://hosted.verticalresponse.com/2...07/2923861121/
#2143
#2144
FWIW - I tried to bypass the "delivery fees" one time since I live by the now defunct NUMMI plant. No way to circumvent it and so i think it's stupid to cite a "base" price without it..
