Toyota/Subaru/Scion Lightweight Sports Car: Toyota GT86, Subaru BRZ, Scion FRS!
#2207
Dyno #'s out from IL. That 4k torque hiccup is nasty....too bad they didn't run it on an inertially loaded dyno....
http://blogs.insideline.com/straight...cion-fr-s.html
#2209
K20 for instance had 100lbs torque at 4500rpm... FR-S has 100lbs at less than 2000 rpm it seems, and 140lbs at wheels at 2500 rpm.
It means when driving it, it will race through revs for 5000 rpm without feel of letting you down, unlike K20 that was 3000 rpm, or 2ZZGE which was 2000 rpm albeit crazy 2000 rpm... or GTI with turbo which has 2500rpm of full torque.
#2211
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
The 2013 Scion FR-S doesn't have the kind of power that results in jaw-dropping dyno numbers, but any naturally aspirated 2.0-liter four cylinder that promises 200 horsepower and 151 pound-feet of torque needs to be vetted out.
The good people at Edmunds did the vetting, and the hotly anticipated Scion model performed, well, predictably. The FR-S delivered what Edmunds called "the most repeatable runs on the dyno of any car in recent memory," with peak wheel power measuring 173 horsepower at 7,000 RPM and 143 pound-feet of torque at 2,500 revolutions. Keep in mind that these numbers are at the wheels, not at the crankshaft where factory numbers are recorded.
One interesting stat that showed up on the line graph was a 14% drop in torque between 3,200 and 4,500 RPM. This was reportedly done by engineers on purpose to increase driving pleasure lower in the rev range, which sounds like a solid compromise to us. Hit the jump to watch the video, and make sure to turn up your speakers for optimal boxer four enjoyment.
#2215
Interesting video on Subaru.com shows the BRZ on a 4 wheel dyno....hmmmm....
This engine will certainly find its way into the rest of the Subaru lineup. The 2013 AWD Legacy boasts 32 MPG. It can only go up from here. Perhaps we might see a 2.0L turbo IS in the future....maybe.
#2216
But there is no space for awd there, nor need.
#2219
#fiveaxiskitfail - looks terrible.
completely unnecessary - hey lets throw a bunch of plastic on here that will scrape on the ground and slow the car down?
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
#2220
