lol, using mouth, that's kind of gross isn't it? i guess putting in a hose, and use a pump to keep on pumping on the other end until gas comes out, then siphon will just keep on drawing gas out huh?
if that's the case, it brings another question. on some cars, you can easily lift off the gas door (not like lexus where you have to open from inside the car). if that's the case, doesn't it make it easy for some people to steal gas that way?
we had to get a lock installed on our ford excursion, which holds 44 gallons. God its like the jackpot of all gas tanks.
lol, but if water get into the tank.... that's disastrous?
RON, that sounds scary. that means if the hose is stuck then i am in trouble?
Well, you're removing the liquid from the tank anyway. The water will be the first liquid to come out out of the tank.
I have no idea about filters or valves or any of this stuff to prevent removal of fuel, although I suppose it makes sense to have it (for that and other purposes).
