Water 4 Gas?
Old 04-15-08, 11:45 AM
Lexiss_sc430
Lexiss_sc430's Avatar
Default Water 4 Gas?
Have any of you guys heard of this? I cannot imagine anything like this actually working, but what do you guys think.
Is it feasible?
http://water4gas.com/2books.htm
Lexiss_sc430 is offline
Old 04-15-08, 11:47 AM
RXSF
RXSF's Avatar
last time i checked, water was not combustable.
RXSF is online now
Old 04-15-08, 11:50 AM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
It takes extensive energy to break down H2O into H2 and O2, than it is to make it.
Therefore, it would not be energy efficient.
PhilipMSPT is offline
Old 04-15-08, 11:53 AM
Lexiss_sc430
lol I know that, did you read the site?
Old 04-15-08, 12:01 PM
4TehNguyen
4TehNguyen's Avatar
electrolysis adds another step that robs efficiency in the overall energy balance. I'd rather use that electricity to directly charge a battery and run an electric motor of which is 90% efficient. Not to mention the abyssmal energy density of hydrogen. Youd have to fill up every 1-2 days, annoying
4TehNguyen is offline
Old 04-15-08, 12:59 PM
milky
milky's Avatar
Wouldn't mind filling up every single day to save $4/gallon
milky is offline
Old 04-15-08, 02:23 PM
gengar
gengar's Avatar
When I read the title, my initial thought was that Jesus had pulled another miracle off...
gengar is offline
Old 04-15-08, 03:32 PM
Vlad_Stein
Vlad_Stein's Avatar
I am no scientist, but it sounds like a scam to me.
HHO is not really a gas - it is a mixture of two gases H2 and O2.
To obtain H2 and O2 from water, you must use electrolysis, which is very energy-intensive. The resulting gas can be burned, but you will not obtain net energy from this (you will invest more energy to obtain HHO than you will obtain from burning it).
If you think about it (even in non-scientific terms), it make sense. You started with water and ended up with water (after burning the gas), so at best, you can break even. In the real world, there is an energy penalty for energy transfer. And since we're not dealing with fission or fusion here, but just a chemical reaction, there is no conversion of mass into energy.
If you could do that and obtain energy from it, you could also walk around a block downhill all the way, all the time - that's just not how it works.
Vlad_Stein is offline
Old 04-15-08, 08:43 PM
tuan92129
tuan92129's Avatar
yeah...thats like splitting water into hydrogen and oxygen and using hydrogen as a fuel....
tuan92129 is offline
Old 07-15-08, 11:44 PM
Mistical
Mistical's Avatar
Default Science or Marketing?
This seams interesting and if BrownGas (HHO) actually makes gasoline more combustible, I would think this would be beneficial in many cars. I think that the issue we would have in a lexus is that the sensors would register the air/fuel mixture as having too much oxygen and therefore add more gas, resulting in less fuel economy, but maybe more power. Again, assuming that adding HHO to the air/fuel mixture is beneficial. I guess that would be the first thing to test.
The quality of systems recommended by sites like water4gas do not seem to be on par with the quality of a lexus, but the general idea sounds feasible. Add Hydrogen and Oxygen gas to the air/fuel mixture to lower the amount of gas needed to generate clean power. "Giving you more bang for you buck".
If the electricity demands to generate HHO on the fly are to great for the car, you might be able to upgrade the alternator & battery to accommodate. Again, this is all assuming that you can mix fuels to achieve a benefit. What would happen if you added small amounts of NOS to the combustion process? Would that too allow you to use less gasoline, achieving better MPG, power and/or cleaner emissions? What about a NOS like system using hydrogen and/or oxygen instead?
I am sure very few of us would be willing to try this on our Lexus's without proper testing and verification, but this is either interesting science or good marketing....
Mistical is offline
Old 07-16-08, 12:10 AM
darkdream
darkdream's Avatar
haha.... this is funny...
darkdream is offline
Old 07-16-08, 01:11 AM
LexT
LexT's Avatar
I donno,...
Seems like its working for some people, take a look see....
http://www.fuel-saver.org/Forum/forumdisplay.php?fid=15
LexT is offline
Old 07-24-08, 06:52 PM
Mistical
Mistical's Avatar
I think this is the same thing...
http://www.autoblog.com/2008/07/24/r...to-the-gallon/
Mistical is offline
Old 07-24-08, 07:03 PM
basketthis
basketthis's Avatar
There is a method to this. It has been proven to work. I've done extensive research and eventually decided to not do it on my Lexus. But, it can improve mpg with the right setup and some experimentation. I am including a download for one of the more known HHO setups for vehicles. It's called a Smack's Booster. You can watch his videos on Youtube. Apparently he gets great results...
ENJOY!!
basketthis is offline
Old 07-24-08, 10:03 PM
Received 2,394 Likes on 1,568 Posts
ENJOY!!
If so great why have you decided not to do it to your Lexus?
bitkahuna is offline
Quick Reply: Water 4 Gas?
