Air Suspension report
Old 04-14-09, 05:26 PM
Solo_D33A
Solo_D33A's Avatar
should've made a vid of you doing the presentation then show it to us. lol
Solo_D33A is offline
Old 04-14-09, 07:55 PM
mmarshall's Avatar
With a typical air suspension, an air pump supplies compressed air to bladders in the suspension to keep the car (particularly the rear end) at a pre-determined level, regardless of vehicle load. In other words, the vehicle is kept from sagging.
In general, though, I don't recommend air suspensions, for two main reasons. First, since they don't allow the car to sag with a heavy load, they can (and do) tempt drivers to load up the car past safe limits.....or what the manufacturer rates the car for. Second, they often are not as reliable as conventional suspensions (especially the Cadillac and Lincoln air suspensions), and the components are quite expensive to replace when they do fail (sometimes several thousand dollars). What some owners do when they fail is simply replace them with conventional struts and shocks, which are much cheaper and will often fit.
mmarshall is offline
Old 04-15-09, 04:36 AM
DriftGirl
DriftGirl's Avatar
Originally Posted by LiCelsior
woohoo, thanks to Emeralds help, i got a 85 .
THATS AWESOME!!! CONGRATS!
DriftGirl is offline
Old 04-15-09, 07:23 AM
LiCelsior
Retired
LiCelsior's Avatar
lol ooo no. reason i got a 85 was cuz i talked for like 5 mins then showed 2 clips. ill take that for a 1 credit class!
yep i talked about the pros and cons of using air suspension systems.
thanks to you .
LiCelsior is offline
Old 04-15-09, 08:44 AM
trukn1
NELOC Mod
trukn1's Avatar
Congrads Joe.
trukn1 is offline
JHutch1986
05-16-19 02:31 PM
ReeM
Suspension and Brakes
11-22-16 07:10 PM
o2 jockey
Suspension
02-22-08 10:48 AM
CyberSC4
06-02-07 03:43 PM
Quick Reply: Air Suspension report
