How to ship wheels and tires?
I have someone interested in buying my wheels and tires. And they are all mounted and ready to go. How do I package them so they won't get damaged? Do I need to buy some special box? What are the dimensions? What should the weight be? I am sending G-spyders 18x8 times 4 with Michelin Alpin winter tires.
I have 3 sets of wheels in my closet up stairs and I just sit on them because I am afraid of even trying to sell them and ship them. seems like a huge pain in the ***. I am actually thinking of giving the 19" wheels I have to a tech at work. He just got an 02 Acura TL type S and the 19" Axis Hagen wheels will look dope.
I know that FedEx ships wheels and tires as I get my tire deliveries from them when I order from Tire Rack. I think the first idea was the best. Cardboard cutout followed by a plastic bag followed by a big box. Make sure to let the air out as it's excess weight. Just be forewarned... It's not going to be cheap. Best bet would be to go to the processing center to ship it. The usually stock more supplies for such requests over their retail stores.
The best way is to dismount the tires and ship them separate from the rims. Tires need no packaging, just a label. You can visqueen them if you want.
Each rim should have the face covered with a bonnet, bagged, then double boxed. First find a box that fits each rim closely, then put 2 boxed rims in a single box. This method gives you more protection, and is also cheaper since you now have only 2 packages for 4 rims.
You may find everything you need at your local rim dealer, or dig through his dumpster after hours!
Use the circular cardboard pieces to protect the centers as suggested in a previous post. Also, use cling wrap around the wheels and you should be fine. I just had some delivered to me that way with no problems. Fedex was @ $55 each wheel/tire fully inflated (19x9 & 19x12.5)
Good luck...
Good luck...
I know that FedEx ships wheels and tires as I get my tire deliveries from them when I order from Tire Rack. I think the first idea was the best. Cardboard cutout followed by a plastic bag followed by a big box. Make sure to let the air out as it's excess weight. Just be forewarned... It's not going to be cheap. Best bet would be to go to the processing center to ship it. The usually stock more supplies for such requests over their retail stores.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
i would keep the tires on. they can protect the barrel of the wheels. plus you have fewer boxes, so it's cheaper. total weight is the same whether you separate the tires or not
Nikon
01-09-15 09:45 AM
FBTO
Wheels and Tires Classifieds
18
11-17-09 08:21 PM
FBTO
04-23-09 10:34 AM
gs300haltech
28
01-26-05 06:18 AM
