Forget the EPA- Consumer Guide Auto gives it's real world MPG numbers
#31
http://www.honda-accord-guide.com/Accord_Hybrid.html
The revised ratings are 25 City, 33 Highway and a 28 Average.
Cylinder deactivation only means that the "deactivated" cylinders are not getting fuel. They are still moving and going through a compression cycle, so when you have lets say 300hp 8 cylinder engine running on 4 cylinder, it means that the other 4 cylinders are spinning a 150hp compressor. It just adds complexity and additional wear and tear on one bank of cylinders, injectors, spark plugs, etc.
http://www.greencarcongress.com/2005...ands_depl.html
#32
Originally Posted by Och
Cylinder deactivation is completely useless, if anything it does more harm then good. The Accord hybrid was rated under old EPA system.
Yada, yada, yada, I've been reading about this technology for a while, and no, I have not read one article about premature engine failure in today's vehicles with this technology.
#33
Och makes some good points here, SLegacy. True, it won't necessarily lead to engine failure, but the same amount of work still has to be done, no matter how many cylinders are getting or not getting fuel. The fewer cylinders that are powering the vehicle, the harder each one has to work. As I pointed out in my last post, the laws of physics aren't changed, but simply redistributed among fewer cylinders.
#34
Find me the proof that says that the redistribution of work on to fewer cylinders has been detrimental to a vehicle's maintence. Otherwise, the point is moot.
From my search I have found no such data saying that a vehicle such as the Odyssey, which is available with the same 6 cylinder engine with or without VCM, requires more maintaining with the VCM equipped model.
#35
Well, we were talking about mileage (or, at least I was), not necessarily maintenance. I said earlier that it would not necessarily lead to engine failure, but the extra work that the non-deactivated cylinders had to do to make up for the idle ones prevented much of a real savings in fuel. We've seen this in both the Chrysler Hemi and some Honda V6's that have the feature. And Och was not saying that engines would necessarily fail prematurely, either.....like me, he said only that the engine's friction and pumping loads created some extra work.
#36
Im not saying it would fall prematurely, but I am saying that cylinder deactivation system itself is completely useless, and if anything, its just another system that could potentially fail.
As far as maintenance, it produces uneven load and uneven temperature, and can cause uneven wear on cylinders, injectors and spark plugs. Not something I would want.
#37
2. They don't fail. These aren't the 8-6-4 engines of the 80s. DOD has been around for awhile now and doing just fine.
#39
This is what I've been saying for the longest time, these new "clean" diesels are nowhere near as efficient as the traditional diesels, they also have a complicated emissions system that will be unreliable and expensive to repair, and the low sulfur diesel doesn't have the lubricants of traditional fuel diesel, so these engines will wear out faster.
We have averaged 26 mpg for the 8000 km that we have driven it. Yes, that's combined. On the highway we get anywhere from 33 mpg, if actually driving the speed limit (rarely...lol), to around 29 mpg if we're pushing it a little harder. Overall, amazing for a bigger, heavy SUV.
When you factor in the cost of diesel it's a no brainer. We pay on average 25 cents per liter less than premium gas for premium diesel. Our premium diesel is only 3 cents per liter more than the regular low sulfur diesel and will help prevent all of the concerns you mentioned.
http://www.shell.ca/home/content/ca-...sel_about.html
I see similar numbers on the highway, but we won't talk about what the real world number looks like when it's pushed hard.
#41
My experience is similar to yours with IS350, but I think our driving conditions are more suburban than hardcore inner city driving like NYC, SF, etc.
#42
You can't even compare NYC driving with SF, because NYC is mostly flat and SF has very steep hills that put more of a stress on engine, transmission, and brakes.
Itsuki_23
09-15-05 10:25 PM
