NHTSA dotting Toyota's i's on Prius Brakes
Originally Posted by AB
2009 has not been a good year for Toyota. After getting its first full-year loss in seven decades, it faced its biggest-ever safety recall over unintended acceleration caused by floor mats and/or throttle control software. Now, as the year draws to a close, a new potential problem has sprung up. This time around, the issue is related to the braking system on the latest Prius, which debuted early this year.
The problem, which has been reported to National Highway Traffic Safety Administration (NHTSA) by several dozen drivers, relates to a loss of deceleration when transitioning from regenerative braking to friction braking. At this time, NHTSA has not opened a full investigation but it is monitoring the situation.
This is actually quite a complicated issue, and it highlights one of the reasons why it takes automakers so long to bring cars to market. Read on after the jump for some discussion on what might be happening.
![](http://www.blogcdn.com/green.autoblog.com/media/2009/10/toyota-prius-red.jpg)
Originally Posted by The Detroit Bureau
Hybrids and EVs actually have two different braking mechanisms. In addition to the traditional hydraulic friction braking system that's been used most of the past century, they also employ regenerative braking to convert kinetic energy back to electrical energy to charge the battery. A problem arises, however, in that there is only one control mechanism: the brake pedal. As a result, electronics and complex hydraulics are used to blend the amount of braking from the two systems to provide net deceleration proportional to the amount of pressure the driver applies to the pedal.
This would all be fine if the behavior of both systems was completely predictable. In that case both could be modeled mathematically, and the estimated torque from each could be calculated. Unfortunately, the friction brakes in particular can exhibit significant variability caused by wear, humidity, temperature and numerous other factors. Control and calibration engineers spend tens of thousands of man-hours testing and developing the systems in an attempt to ensure that they behave predictably and consistently over the life of the vehicle and under different operating conditions.
The problem reportedly being experienced in the new Prius relates to an apparent loss of deceleration when the brakes transition from regen to friction braking. Having worked on the controls for similar braking systems in a previous life as an engineer, I can say from experience that this is not an uncommon problem. Typically, it occurs when the friction brakes are producing less torque than the model predicts.
A number of things could cause this. The most basic is the brake linings, which could have less friction than expected. In this case, the control algorithm should be able to learn and compensate. The problem could also be related to the pressure sensors in the hydraulic unit that are part of the closed-loop control. Sensors can have erroneous signals or drift over time and temperature. Again, there are mechanisms to correct for this but they're not perfect. Not being familiar with the specifics of the Prius system, we can only speculate about what has changed in the new version.
There's another possibility based on the information in the reports. Apparently, at least some of the owners experienced the perceived loss of deceleration after hitting a bump or pothole. When we reviewed the Prius, we noted that its newly-revised suspension setup seemed to handle larger road imperfections well, but it was a bit over-damped on small sharp inputs. This could cause the tire to lose adhesion with the road in this case, and thus start to exhibit slip. The brake system could be detecting this sudden increase in wheel deceleration (as opposed to vehicle deceleration) and responding by proactively reducing brake torque in an attempt to prevent impending wheel lock and the need for full-blown ABS control.
If (and we stress IF) this is being done too aggressively, it could explain what drivers are feeling. We never experienced any such behavior when we drove the Prius, but we wouldn't rule it out under the right conditions. If you own a third-generation Prius and have experienced anything like this, let us -- and, more importantly, NHTSA and your Toyota dealer -- know. It may not be a real problem, but if it is, Toyota will need as many data points as possible in order to properly diagnose and fix it.
Here is another article in the MSNBC site:
http://www.msnbc.msn.com/id/34611930/ns/business-autos/
Toyota must have change something they shouldnt have since they have been using regenerative braking for years with no problem.
Only difference now is that Toyota is under attack from all sides.
Tech Info Resource
My Scion tC did this after I put wider tires, stiffer coilovers, and stiffer sway bars on it. I nearly drove through an intersection because the pavement I was trying to stop on was about a 3" washboard. The tires would only contact the tops of the bumps because the suspension was too stiff to allow the tires to drop into the bottoms of the bumps. The ABS was kicking on every time the wheels left the pavement, so when the tire regained traction, the brakes were not being applied. My stopping distance increased to more than 4 times what it should have been, and I nearly went into the intersection on a red light. It was one of those moments where the advice I'd heard from a chassis tuner stuck in my head: stiffer != better, it's just stiffer and might actually be worse.
The description of this problem sounds a lot like what I experienced. Yes, I did soften up the damping on my Tein SSCs immediately after this event. It helped some, but not enough.
![](https://www.clublexus.com/forums/members/lobuxracer-albums-scion-tc-picture1957-img-0003websize.jpg)
in this case, it is protecting hybrid system (as slippage in the system can brake powersplitting device that is center of the system)... however the thing is that if you apply brakes to make stop, there is no delay, mechanical brakes will apply.
and in fact, they have improved it in Gen3 - traction control in gen2 was ruthless, it was common complaint with Gen 2 that during winter, TC/VSC would not allow any slipping thats crucial for getting the vehicle out of trouble (even driveway)... apperantly, it has been much improved in gen3.
i never noticed neither of these in my prius, but i live in warmer climate.
LexBrett
10-16-15 06:42 AM
