Can anyone confirm that a car can be shifted to Neutral when engine is racing up?
#46
Are you guys really risking your cars doing these test?
All you're doing is proving what can be done technically, with your specific car. Do anyone have a prius they want to test for us?
I have four company prius' that I had checked, and my main concern was that in the event they deside to go skynet on my people even If they new exactly what to do, whose to say they'ed even have enough time to apply those steps even. That's more of a concern for me than anything. I'm trying not to worry about it now. Toyota did what they needed to do so....
#47
Lexus Connoisseur
Yes I have tested this on the RX450h. If you haven't see my results check post#30.
Not at all, the trans and main ECM of the car is smart enough to cut off power safely without problems. The test already has been done yesterday. Check this video clip.
#48
I feel like if anything should happen to your company vehicles and your staff don't have enough time to "react" and slow down the car--then the incident won't be that big. The Prius does not accelerate that quickly, and needs time to get up to speed. Even if they were already doing 65mph, to get up to speeds deemed dangerous (which is basically where the Prius runs out of steam anyway)--it would take quite a number of seconds before the issue became "serious."
#49
that's impossible; the transmission shifter is completely independent of any outside control aside from the person moving the shifter. the shifter cable doesn't care how fast teh engine is spinning, it will do whatever the driver makes it do. if you put it in N, it will shift the trans out of gear.
viettho
10-01-07 01:55 PM
