damn. Ford is killing it. 305hp v6, 31mpg hwy.
#46
Guest
Posts: n/a
For example in this ONE test it got 29 MPG average. What makes this any more legit than complaining about another test?
As a fan of the car I will wait until we hear from owners over "time" so we can measure it up.
#47
name other cars that are special or exceptional.
#48
That's why I noted in the parentheses that it was a hypothesis that IF Toyota/Lexus had dropped that 3.5L V6 in a lighter car (Supra?) 5 years ago they would've been able to achieve 19/31 then already. So in that sense 19/31 on a 300+hp 3350lbs car isn't special today technology-wise, but kudos to Ford of course for actually making one.
#49
#50
#51
Yes, you're correct. Good catch.
That was an obvious typo on my part.....an unintended one. I meant, like you noted, the other way around.
I should have caught that one, as I used to write about auto fuel-economy techniques.
A rich mixture does more than just lower average fuel mileage. All else equal, It lowers combustion temperature in the cylinder, lessens the likehood of spark knock/detonation, and allows the use of lower-octane fuel, but also increases the load on the catalytic converter, produces sulfur smell in the exhaust, and increases the likehood of carbon deposits on the spark plugs and valves.
#52
You can correct me if I'm wrong, but Ford, though, to my knowledge, has (yet) to produce a variable-displacement, cylinder-shutdown system like Chrysler did with the non-SRT Hemi.
#55
Eeeeeeeeessssswww, Chrysler variable-displacement application is on an outdated pushrod iron block antiquated engine, why bother. Hardly a noteworth accomplishment compared to Ford's strides in performance and fuel-saving technology. Yep, Chrysler never got the memo.
#56
I suspect, though, that Chrysler will get the memo, sooner or later, and start work on a smaller-displacement turbo powerplant.
#57
So few companies use a technology that could go along way saving oil. On average, a Honda saves 2 MPGs when shutting down to 3 or 4 cylinders. 2 MPG doesn't seem like much, but when selling thousands of units each year it could really add up.
#58
Seems to be two different approaches to two different engines. The Hemi gets a lot of buyers, though. It has turned out to be an extremely popular engine, antiquated or not, and is offered in a lot of different Dodge/Chrysler/Jeep products.
#59
and this opinion from someone who owned a honda and two acuras way back.
#60
