damn. Ford is killing it. 305hp v6, 31mpg hwy.
#61
#63
Looking at the Accord 26 MPG Hwy and the Accord Hybrid with deactivation 32 MPG. 6 MPG is alot.
#64
DEARBORN, Mich., March 16, 2010 – The 2011 Ford Mustang GT, powered by a new 412-hp 5.0-liter V-8 engine, adds yet another notch to its belt: an EPA rating of 26 mpg highway when equipped with the six-speed manual transmission, giving it the best fuel economy in its class.
“The 2011 Mustang continues to exceed expectations in every category, and these fuel economy numbers are another chapter in an incredible story,” said Derrick Kuzak, Ford’s group vice president, Global Product Development. “To offer this kind of horsepower and class-leading fuel economy in a comfortable, beautiful, tech-savvy and affordable package – it’s really unprecedented.”
With the six-speed manual transmission, Mustang GT coupe is rated at 17 mpg city and
26 highway, while models with the available six-speed automatic achieve 18 mpg city and
25 highway.
The GT’s best in class fuel numbers come on the heels of the Mustang V-6, which just last week cracked the record books as not only the most fuel-efficient Mustang ever, but also the first production car in history to produce 305 horsepower and 31 mpg highway.
Mustang GT is powered by an all-new 5.0-liter double-overhead-camshaft (DOHC) V-8 with a host of advanced features to deliver the combination of power and class-leading fuel economy.
Twin Independent Variable Camshaft Timing (Ti-VCT) adjusts the valvetrain in microseconds depending on driver inputs. A carefully tuned intake and exhaust system ensures free breathing at all engine speeds. And all-aluminum construction results in a lightweight yet durable powerplant.
A pair of new transmissions, both with six forward ratios, also play a large part in making the 2011 Mustang a breakthrough car. Regardless of whether drivers want to shift for themselves or let the car shift for them, they’re treated to carefully chosen gear ratios to maximize fuel economy while still delivering high-horsepower performance
“Mustang powertrain development has reached a point where customers don’t have to choose between fuel efficiency and performance,” says Barb Samardzich, Ford vice president of Global Powertrain Engineering. “Thanks to technologies like Ti-VCT and our six-speed gearboxes, a Mustang driver has the best of both worlds.”
Fuel economy improvements on all Mustang models
Mustang GT shares fuel economy accolades with the new 3.7-liter Mustang V-6 – the first production car ever to offer both 300-plus horsepower and 31 mpg on the highway. Official 2011 EPA fuel economy ratings for the Mustang product line are:
Mustang V-6
•19 mpg city and 31 highway (automatic coupe)
•19 mpg city and 29 highway (manual coupe)
Mustang GT
•18 mpg city and 25 highway (automatic coupe)
•17 mpg city and 26 highway (manual coupe)
In addition to powertrain improvements, upgrades to Mustang’s body and chassis design contribute to its 2011 performance. Examples include:
•New EPAS eliminates the drag of an engine-operated hydraulic power steering pump
•Combined with the new six-speed transmissions, standard 3.31 (manual) and 3.15 (automatic) rear axle ratios provide an ideal blend of relaxed cruising rpm and all-out acceleration
•Aerodynamic improvements include a new front fascia on the Mustang GT, tire spats on the rear wheels, modified underbody shields, a taller air dam and an added rear decklid seal
The 2011 Mustang is built at the AutoAlliance International Plant in Flat Rock, Mich., and goes on sale this spring.
25 highway.
Mustang V-6
Mustang GT
#65
Looks like the manual is down 2 mpg on the highway, not 1. This proves the point of super-tall gearing. 19/29 doesn't sound as nearly as impressive as 19/31.
Let's see, where do I start?
The GS350 RWD, which has a curb weight of 3,704 lbs, gets 19 mpg city, while achieving roughly the same HP and torque as the Mustang.
So roughly equal HP, the GS weighs quite a bit more than the Mustang V6, yet it gets equal city mpg. Sure the highway mpg is lower, but that's because the GS350 doesn't have super-tall gearing. It's fairly short gearing on that car.
The RX350, both FWD and AWD models get 18 mpg city. The RX weighs MUCH more than the Mustang V6, and has a much bigger frontal drag area than the Mustang. Yes, it has roughly 30 HP less, and less highway mpg but the larger drag and weight, once again combined with fairly short gearing on the 6-speed auto make the RX's city economy quite impressive.
There is the Audi S4, which achieves 18 mpg city and 28 mpg highway. This is a car that is heavier than the Mustang V6, achieves quite a bit more power than the Mustang V6, yet gets almost identical city mpg, and highway mpg which is not far off.
A sedan that weighs over 3900 lbs and makes 333 HP while achieving 18 mpg city? Now THAT is impressive.
What about the G37? It weighs more than the Mustang V6 as well, makes 328 HP, and gets 19 mpg city.
The new Sienna V6 gets 18 mpg city, and while it has less power than the 'Stang V6, it has a massive frontal drag area in comparison, and is a much heavier vehicle.
#66
None of the cars you have listed crack the 30 MPG marker and the Mustang does. That's impressive. The GS 26 Hwy, the G37 27 Hwy (25 if you opt for the MT). The Audi 3.0L TSFI is also an impressive engine, which I am sure is the reason that it is being installed in the Toureg and Cayenne hybrids.
#68
It's obvious Ford put the tall gearing on the auto to crack the 30 mpg barrier purely for marketing reasons.
We should not ignore the city mpg number. Highway economy is only part of overall economy.
My post was clearly and specifically talking about the city economy not being impressive at all.
I never disagreed with the highway economy being impressive.
#69
First things first, which is why the leaders have DI and DOHC. DI and DOHC have greater efficiency and performance gains than cylinder deactivation, without creating drivability problems. Certainly for premium car makers, probably not worth it.
#70
performance numbers should be out next monday, when the embargo is lifted.
it's funny. If it weren't for CHEVY killing stang sales, ford probably would've taken forever to come out with upgraded engines.
#71
Guest
Posts: n/a
The GS 350 does offer best automatic acceleration and MPG in multiple tests, the IS 350 as well. This new Mustang seems to do the same for muscle cars. Ford really did a great job I real world results match this.
The Camaro gets great highway MPG too.
The Challenger is MPG challenged
#72
I'm not a fan of that approach, of redesigning a model and carrying over an older engine and powertrain but Ford isn't the only one that does that. The 3GS had the older 3.0 for one year before it got the 3.5 V6.
#73
S4 is impressive, but 3mpg difference in highway is still huge.
it's like me saying Genesis v8 is much heavier than S4, it's a v8, doesn't drink premium, and has 52 more hp(2011 has 385hp), but still gets 17/25 which is 1 less city and 3 less on highway.
now that's impressive.
#74
Guest
Posts: n/a
now that's impressive.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
LexFather
09-08-09 07:51 PM
Stevekil
Hybrid Technology
30
10-14-06 05:15 AM
