Report: Next Range Rover detailed, huge weight loss, 33 mpg!
More info from Autocar:
![](http://cdn.media.autocar.co.uk//Car/LandRover/64101035757506234x155.jpg)
http://www.autocar.co.uk/News/NewsAr...llCars/248675/
A new, lightweight Range Rover featuring a roomier, super-luxury interior and 40mpg fuel economy is due in autumn 2012.
The all-alloy Range Rover will also form the basis of a new Range Rover Sport which, for the first time, will also be offered with a seven-seat interior; that variant will become the successor to the current Discovery.
The new Range Rover models are in the final stages of their engineering definition and the styling of the Range Rover (project L405) will be signed off in the middle of this year.
The new Range Rover will have a similar footprint to today’s car — it grows by around 25mm to a shade under five metres long — so the main change is a lower roofline. That will reduce the Range Rover’s perceived bulk and also cut aerodynamic drag.
Styling and construction
Land Rover’s styling team, led by chief Gerry McGovern, is working with a similar palette of design details to today’s car. So expect an imposing upright nose and horizontal, multi-bar grille, oblong headlights, together with a flat beltline and airy glasshouse, topped by the characteristic floating roof.
The all-new, pressed-alloy platform has given engineers the freedom to create a more spacious interior package. The wheels have been pushed closer to the front and rear corners, extending the wheelbase by around 25mm. Thanks to this gain, the extra 25mm in overall length and internal packaging improvements, the new car will feature much improved rear legroom, up by 125mm.
“The feedback from existing customers was [that they wanted] more rear legroom, so that’s what we’re going to give them,” said one insider. Although the roofline is lower, packaging improvements will ensure similar headroom to today’s Range Rover.
Land Rover’s design team is working on Bentley levels of cabin quality with a harmonious mix of leather, wood and metallic finishes. “The level of workmanship in the interior will really knock out the opposition,” said another well placed insider.
Under the skin, the new alloy bodyshell of riveted pressings has some commonality with Jaguar’s new XJ, although JLR counts the two structures as separate platforms. Similarly, the electrical system is shared between the two.
Alloy construction will bring huge weight benefits. Land Rover is understood to be targeting a kerb weight saving of 450kg, which will cut the new Range Rover down to 2150kg.
Around half that loss is understood to come from the alloy bodyshell, while the other half comes from detailed engineering improvements, lighter components and advanced materials.
Some of the body panels are understood to be made of composite materials, including the front wings and possibly the rear tailgate.
Engines
The new lightweight Range Rover will record some spectacular improvements in economy, C02 and performance.
Two diesel engines will be offered at launch: a 300bhp TDV8 and a 260bhp TDV6, mated to eight-speed ZF gearboxes with stop-start. Petrol V8s will be available soon after. The extra power and lower kerb weight means that the V8 diesel will offer a 0-60mph time of less than 8.0sec and close to 30mpg.
The TDV6 is likely to take over from the V8 as the best-seller thanks to its blend of fuel economy and performance. The target is get the TDV6 under 200g/km of C02, a spectacular figure given that today’s Range Rover is a 300g/km car. Performance should match the outgoing TDV8.
Also due a couple of years after launch is a super-frugal diesel hybrid. After experimenting with capacitors in place of batteries, Land Rover is understood to be taking a more conventional approach. The target is low C02 emissions, possibly of around 170g/km.
Off-road
The new Range Rover will use the world’s first alloy-monocoque 4x4 bodyshell, so much thought has gone into making it rugged enough to survive off road.
With that in mind, Land Rover will mount the front and rear suspensions on tough subframes. They will feed suspension loads into the bodyshell through advanced soft-rubber bushes.
The drivetrain will continue to feature a transfer box and the front and rear axles will be tough enough to survive the worst conditions and abuse that Land Rover’s engineers can chuck at them.
Engines
Off-road
Monocoque is a combination French/Greek term that vaguely means "single-shell". It was first coined (and used) to refer to some early aircraft designs of WW1 vintage. It means that the whole structure, or "shell", can hold its own weight/stresses without any internal or external reinforcements (such as bulkheads). You are correct that it also (basically) refers to modern automotive unibody design....although some unibodies, of course (especially with high-performance cars), have additional bracing inside the shell.....often across the two front struts under the hood. Many convertible unibodies also have additional bracing to deal with potential cowl shake.
Hoovey689
04-03-13 10:53 AM
Hoovey689
07-05-11 10:57 PM
Hoovey689
04-07-11 11:23 AM
