All hail the cartridge filter! 2011 Chevrolet Cruze makes changing oil a breeze
My father's 52 Plymouth with a flathead 6 has a cartridge oil filter conveniently located on top of the engine. 58 year old technology FTW. It also used oil as an air filter. The heavier dirt particle were trapped in a pool of oil similar to a sink trap.
Well, you've got half of it: Cartridge.
Just mounted under a panel on the bottom of the engine
After learning the trick to 'not' making a mess on my first IS350 oil change, its quick and (mostly) painless now.
___________________
My wife's Eos has a top-mounted oil filter (spin on can though). Makes filter changes nice.
___________________
You're talking about one of those little screw-in plugs with a built-in valve that goes into the drain plug hole, right? I've seen those ads, but never tried one myself. Have you found the valve to be durable and leakproof?......that's my main concern. Seems to me that if it were such a simple, foolproof set-up, and would last over time, automakers would dump the traditional metric socket-plugs and make them standard. Technicians and service shops would probably like them because it would shorten oil-change time, eliminate the possibility of stripped threads on the drain-plug hole (that problem is fairly common), and allow them to service more cars every day.
Out of Warranty
The local cop shop's motor pool used those valves for years. It seems changing oil in a police cruiser is done about every 5-7 days, due to 24/7 use and high mileage, with a lot of idling. The grease monkeys down at the motor pool kept cross-threading the drain plugs so often, new pans were becoming a budget line item. That drain valve solved the problem - it's almost impossible to mess up.
http://www.lubricationspecialist.com...FReenAodyW8AKw
Tech Info Resource
Since Blackstone says I can go 14k miles on an oil change, the valve is in the very marginal category, especially since I have a high volume rough vacuum pump I can use to drain from the dipstick tube.
All 2IS have this style filter, and it's dead simple to change it without a big mess. I wish the wife's Scion had a cartridge filter. I've learned to hate the spin-on style filters after the first time I put it on with a torque wrench and had to stab the thing with a screwdriver to get it off.
Welcome to 1990, Chevrolet, glad you could make it. Autoblog, is this the first car you've SEEN in 2 decades?
This is indeed incredibly convenient (I love it on my decade-old BMW), but it's about as far from revolutionary as you can get.
Guest
Posts: n/a
Yeah I also like the new Lexus filter style, cheaper and easier to DIY but it still is under the car and requires me jacking it up/using ramps.
Combine that with an oil extractor, and you could do the entire oil change without even looking at a jack, or getting a single drop of oil on yourself or the floor.
