Ford F-150 engines for 2011 announced, includes EcoBoost V6
The Ford F-150 is getting a lineup of four all-new engines for the 2011 model year that includes two V6s and two V8s. According to Ford, the entire new engine family will be more fuel efficient than the outgoing 4.6-liter and 5.4-liter V8 by at least 20 percent.
The same 3.7-liter V6 and 5.0-liter V8 found in the 2011 Mustang will be available at launch this fall in the F-150, as will the 6.2-liter V8 from the 2011 Super Duty truck. Then, early in 2011, the F-150 will be the first rear-wheel-drive application of the much praised 3.5-liter EcoBoost V6.
The base 3.7-liter V6 will be rated at 300 horsepower and 275 pound-feet of torque while yielding a 6,100-pound towing capacity, which matches the Silverado hybrid. The 3.7 liter will be offered in the XL, XLT and STX trim levels only. The high volume engine is expected to be the new 5.0-liter V8, which you can read more about
Gallery:
http://www.autoblog.com/photos/2011-...gines/#3253017
Trimmed out for truck duty, Ford's 5.0-liter V8 is down a bit in power compared to the Mustang because the intake cams have been re-profiled and the compression ratio lowered to 10.5:1 for better low end torque. In order to meet tougher durability requirements for a truck application, the steel headers of the Mustang have also been replaced with cast-iron exhaust manifolds.
The result is a rating of 360 horsepower at 5,500 rpm and 380 lb-ft of torque, which allows for a trailer tow rating of 9,800 pounds. The 5.0 is claimed to give 50 lb-ft more peak torque and higher torque across its entire range than any of the competitive V8 engines from Chrysler, General Motors, Toyota and Nissan. Unlike the base 3.7-liter V6, the 5.0 will be available in every F-150 trim level except specialty models like the SVT Raptor and Harley-Davidson. Both the 3.7-liter V6 and 5.0-liter V8 engines are also flex-fuel capable in these truck applications.
The optional V8 for the high-end Platinum edition is the 6.2-liter unit that debuted earlier this year in the SVT Raptor and Super Duty. Output of the 6.2 liter remains 411 hp and 434 lb-ft with 11,300 pounds of towing capacity. The 6.2 liter will now also be standard in the SVT Raptor and Harley-Davidson as the previous 5.4-liter V8 goes to the glue factory.
Finally, the 3.5-liter EcoBoost V6 brings turbocharging and direct injection to the truck lineup. The F-150's EcoBoost will be available in every trim level from the XL to Platinum and match the 11,300-pound towing capacity of the 6.2-liter V8 while offering 20 percent better fuel efficiency than the old 5.4-liter V8. The EcoBoost's composite intake manifold has been redesigned from earlier versions and the exhaust manifolds are now cast-iron. The turbochargers have also been revised from the units found on Ford's passenger cars to withstand a truck's tougher duty cycle.
The EcoBoost is expected to have similar power to the 365-hp Taurus SHO with more torque and a torque peak between 2,000 and 2,500 rpm that remains largely flat throughout the operating range. Ford is still finishing the certification of this engine and expects to release power figures in about four to six weeks.
Following Ford's presentation, we were taken to an engine dynamometer lab where an F-150's EcoBoost V6 was set up. The engine was not taken up to full power in front of the media, but we did see it go up to 4,000 rpm where it was held for about 10 minutes with an output of 410 lb-ft and 310 hp. Under those conditions it will hold 16 psi of boost with the turbos spinning at 175,000 rpm and a turbo temperature of 1,700 degrees F.
All of the engines are paired with Ford's upgraded six-speed automatic transmission. Like other truck engines from Ford, these four new units also go through a 400-hour wide-open throttle durability test on a dynamometer that cycles between peak power and peak torque conditions. All of the engines also get 10,000-mile oil change intervals.
While we don't have any official fuel economy numbers yet, we were promised that at least one of the engine options will beat the Chevrolet Silverado Hybrid's EPA rating of 21/22 mpg. And, it will likely cost considerably less.
http://www.autoblog.com/2010/08/11/f...s-ecoboost-v6/
Guest
Posts: n/a
ALL NEW FORD F-150 POWERTRAIN LINEUP DELIVERS BEST-IN-CLASS FUEL ECONOMY, POWER AND CAPABILITY
* The powertrain lineup for the 2011 Ford F-150 features four new truck engines: a 3.7-liter V6, 5.0-liter and 6.2-liter V8s, and a twin-turbocharged EcoBoost™ 3.5-liter
* Headlining the engine lineup is a new twin-turbo EcoBoost engine with Ti-VCT that has been specifically tuned, calibrated and tested for durability and reliability
* Each new engine delivers best-in-class towing and horsepower. The entire 2011 F-150 lineup will be at least 20 percent more fuel efficient than the 2010 F-150 lineup
* Ford is the first and only automaker to equip its entire full-size pickup lineup with fuel-saving six-speed automatic transmissions as standard equipment
DEARBORN, Mich., Aug. 11, 2010 – For the 2011 model year, the Ford F-150 is getting the most extensive powertrain overhaul in the truck's history. The 2011 F-150 has four new truck engines, all coupled to a revised six-speed automatic transmission.
Each engine delivers improved fuel economy, outstanding performance and class-leading capability. This versatile new powertrain lineup enables F-150 customers to choose the engine that best suits their needs.
Available at launch are a 3.7-liter V6 and a 5.0-liter V8, each with fuel-saving and performance-enhancing twin independent variable camshaft timing (Ti-VCT) technology, and a version of the 6.2-liter V8 that is the base engine in the 2011 Ford F-Series Super Duty. A 3.5-liter EcoBoost engine, specially tuned and calibrated for the F-150, will be available in early 2011. Each of the engines offers an unequaled combination of attributes that matter most to F-150 customers: torque, horsepower, fuel economy, performance, durability, reliability and capability. The 2011 F-150 lineup will deliver best-in-class fuel economy. When the 3.5-liter EcoBoost engine joins the lineup, the 2011 F-150 will have up to 20 percent better fuel economy compared with the outgoing 2010 F-150.
"Our new engine lineup allows greater flexibility for customers to select the powertrain choice that best suits their needs," said Barb Samardzich, vice president of Powertrain Engineering. "We are in the midst of a powertrain revolution, with 30 new powertrains over the next two years, and our loyal F-150 customers are the next ones to benefit."
Extensive testing program to ensure truck application
To ensure the highest quality, most reliable engines, Ford engineers studied the warranty history of the outgoing engines and developed testing procedures based on the real-world driving experiences from current F-150 drivers.
Prototype engines underwent a wide range of tests to ensure complete compatibility with truck application and truck durability, with all components and systems passing testing to the equivalent of 150,000 miles. Components such as the exhaust manifolds and the crankshaft (forged steel) were upgraded, piston-cooling jets and oil coolers were added, and engines were specifically calibrated for improved heavy-duty operation and durability in F-150.
"Truck customers demand an engine that delivers outstanding low-speed torque to help tow or move heavy payloads, and sustained high-load, low-speed operation is a key attribute they look for," said Samardzich. "The engine lineup for the 2011 Ford F-150 has been tuned specifically for truck operation needs and optimized for fuel economy. The result is a lineup that delivers class-leading towing and payload capability with outstanding horsepower, torque and fuel economy."
Here are the highlights of each new engine:
3.7-liter four-valve Ti-VCT V6
The 3.7-liter will be the most powerful, capable and fuel-efficient base V6 of any truck in its class. Key attributes include:
* Best-in-class 300 horsepower (estimated) at 6,500 rpm
* 275 lb.-ft. of torque at 4,500 rpm
* Class-leading fuel economy
* Best-in-class 6,100 pounds maximum trailer tow
* Ti-VCT creates precise, variable timing control of both the intake and exhaust camshafts to optimize power, performance and fuel economy
* E85 flex fuel capability
* Piston-cooling jets, which squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions
* Forged-steel crankshaft for improved durability
* Built at Cleveland Engine Plant
The 3.7-liter V6 powering the base 2011 F-150 is the latest application of the award-winning Duratec® V6 engine, with additional technology and upgrades for truck application. In particular, more work was done on the bottom end of the engine, a strong point of all Duratec V6 engines.
"This is a well-designed engine with a massive amount of attention to detail around the block and the structure of the block," said Jim Mazuchowski, V6 engines program manager. "This attention to the stiffness and rigidity of the bottom end, how the engine is fastened with four-bolt mains and two side bolts, enhances durability and NVH (noise, vibration and harshness)."
Other enhancements for durability include a forged-steel crankshaft, cast-iron exhaust manifolds and a die-cast aluminum oil pan, which supports a 10,000-mile interval for oil changes. The design of the cylinder bore and piston rings has been optimized for efficient lubrication.
In addition to engine durability, Ti-VCT leads a host of technologies that increase overall engine efficiency. Ti-VCT's precise and variable control of the intake and exhaust camshafts optimizes performance and fuel economy. The piston squirters enable faster engine warm-up, and the polished buckets reduce friction, which aids fuel economy.
5.0-liter four-valve dual-overhead-camshaft Ti-VCT V8
The 5.0-liter V8 in the 2011 F-150 offers many class bests compared with competitors' entry-level V8s, including:
* Best-in-class 360 horsepower at 5,500 rpm and 380 lb.-ft. of torque at 4,250 rpm
* Best-in-class 9,800 pounds maximum trailer tow
* New strengthened block and new cylinder head optimized for performance and enhanced cooling
* Unique intake camshafts, combined with Ti-VCT, composite intake manifold and optimized compression ratio for improved low-speed torque and towing capability
* Forged-steel crank and all-new oil cooler enhance durability
* Built at Essex Engine Plant; Windsor, Ontario
While this 5.0-liter V8 engine is similar to the one powering the 2011 Mustang GT, it has several important differences to optimize it for the harsh duty cycle truck customers demand. First, the camshafts were tuned to improve low-speed torque, which is key to truck customers. Also, the 10.5:1 compression ratio was optimized to reduce knock tendency at lower engine speeds while towing.
The hardware added to the 5.0 specifically for F-150 includes: an additional oil cooler, which helps extend the life of the oil to 10,000-mile intervals; foam covers for the fuel injectors to reduce NVH; and cast exhaust manifolds for improved durability. The new aluminum block is 70 pounds lighter than the 5.4-liter V8, which aids fuel economy and improves handling. The engine's forged-steel crankshaft also ensures durability.
"This engine uses proven technology to deliver a great combination of low-speed torque and fuel economy with the durability F-150 customers demand," said Mike Harrison, V8 engine programs manager.
6.2-liter two-valve single-overhead-camshaft V8
The 6.2-liter V8 is a premium engine offering on the 2011 F-150, with an expanded offering to F-150 SVT Raptor and other specialty applications. Its attributes include:
* Best-in-class 411 horsepower at 5,500 rpm and 434 lb.-ft. of torque at 4,500 rpm
* Best-in-class 11,300 pounds maximum trailer tow
* Competitive fuel economy
* Durability of race-proven components and technology showcased in November 2008 when a 6.2-liter Raptor R not only survived the grueling Baja 1000, it earned a podium finish. The same engine went on to complete every mile of the 2009 Best in the Desert series
* Utilizes a large bore and shorter stroke. This approach to creating power has its roots in storied Ford racing engines. The large bore allows for larger intake and exhaust valves for improved engine airflow, and the short stroke allows higher engine speed for increased horsepower
* Because of the large bore size, two spark plugs per cylinder are used to more efficiently burn the fuel-air mixture in the combustion chamber, enabling better fuel economy and increased engine torque. The twin plugs also help the engine maintain a smooth, stable idle
* Built at Romeo (Mich.) Engine Plant
The 6.2-liter V8, standard on the 2011 F-Series Super Duty, is uniquely tuned for the F-150 with a special cam profile. The engine will be standard on the 2011 F-150 SVT Raptor and other specialty applications, and pumps out up to 411 horsepower and 434 lb.-ft. of torque – making the F-150 the most powerful truck in its class.
"This engine has tons of torque, and already has been proved in the field with both the F-150 SVT Raptor and Super Duty," said Harrison.
3.5-liter Ti-VCT EcoBoost
The 3.5-liter EcoBoost is a premium engine offering available after launch with power comparable to a naturally aspirated V8 and projected class-leading fuel economy. Its attributes include:
* Fuel economy improves up to 20 percent versus 2010 model year F-150 5.4-liter V8
* Improved intake and exhaust camshafts optimized for improved fuel economy and performance
* Cast exhaust manifolds for heavy-duty operation and durability
* Improved manifold and cylinder heads for improved performance
* Direct-acting mechanical bucket (DAMB) valvetrain with polished buckets to reduce friction and improve fuel economy
Transmission features customer-driven enhancements
Ford Motor Company is the first and only manufacturer to equip its entire full-size pickup truck lineup with fuel-saving six-speed automatic transmissions as standard.
For the first time, a six-speed automatic transmission is standard in F-150 on all engines. Several available enhancements have been added to the proven 6R80 transmission to help F-150 customers tow more easily, including SelectShift with both progressive range select and manual functions.
Progressive range select allows the customer to reduce the range of available gears while in Drive. When the customer taps down into range select mode, the display shows the available gears and highlights the current gear state. This feature allows the driver to limit the use of upper gears when heavily loaded or while towing on grades.
With SelectShift, customers can get full manual function by pulling the shift lever into "M" for manual mode and then select the gear desired by pressing the "+" button for upshifts or the "-" button for downshifts. The control system will hold that gear for a full manual transmission feel.
The new engines for the Ford F-150 follow the all-new engine lineup for the 2011 Ford F-Series Super Duty introduced earlier this year and highlighted by the 6.7-liter Power Stroke® V8 turbocharged diesel, which delivers best-in-class torque, horsepower and fuel economy.
"The new powertrain lineup for the 2011 F-150 will provide a wide range of choices to customers to suit their needs, each tested for maximum durability and reliability with outstanding fuel economy," said Samardzich.
Repost !!!
https://www.clublexus.com/forums/car...oboost-v6.html
But to comment, what a great line-up of engines for the F-150. Each you heart out Chevy
Extremely impressive engine lineup. Way to go Ford! In one move, Ford has gone from an average engine lineup to THE BEST engine lineup for any truck. Your move GM and Toyota.
I do agree a Powerstroke in the F150 is needed. If Ford did that, the competition would be sent back to the drawing board.
Thing is the market would be very small for those that would be willing to pay more for the diesel. Many people seeking the diesel also need the increased towing and payload so they go hand and hand and will justify spending the extra 6-7-8k for a diesel setup.
Would many people pay 4k more for a small diesel over 6.2?
I like the idea, just not sure they could do the volume.
Super Moderator
This is very unlikely, as the existing Powerstroke is already an uncharacteristically small engine for its manufacturer (Navistar), and Ford has been in repeated contract disputes with them. It would surprise me if both parties would embark on designing a completely new, smaller version.
Another great move for Ford. Glad I bought stock in them.
Some thoughts.
Is the 6.2L really neccessary? At this point wouldn't you buy a diesel?
Honda, GM, and Chrysler have been utilizing cyclinder deactivation. Interesting that Ford and Toyota never have.
2010 Ratings:
4.6L, RWD
4AT:15/19
6AT: 15/21
4.6L, 4WD
4AT: 14/18
6AT: 14/20
I'd be intersted in a 2.0L Ecoboost base model. There are plenty of buyers who buy a truck only to have a truck, not for utility. With 240 ft. lbs of torque that is plenty for such purposes. Afterall, this about what older models (though lighter I realize) put down with far less HP and through far inferior transmissions.
Some thoughts.
2010 Ratings:
4.6L, RWD
4AT:15/19
6AT: 15/21
4.6L, 4WD
4AT: 14/18
6AT: 14/20
People that buy diesels usually do keep them a long time, everyone else not so much.
With diesel prices no longer lower then reg in many places and mpg dropping because of emissions it is a hard sell unless you want to keep the truck 150k+ miles or just plan need the power.
You spec out a fully loaded truck with a diesel you are well over 50k, many people will just save the 6-7k if they do not need it.
Super Moderator
You're right, starting next year the PowerStroke is actually a Ford-designed and -built engine. So ignore my point above about contract disputes. Still seems like a smaller (~4.5L?) diesel would be a relatively limited-demand item, and thus not worth investing the R&D in.
Guest
Posts: n/a
Repost !!!
