which wears out a tire faster?
Old 08-13-10 | 11:36 PM
Fizzboy7's Avatar
Fizzboy7
Default which wears out a tire faster?
What would wear out a tire faster? Mostly street driving or mostly highway driving? I would think with street driving, you'd be scraping off the outter edges faster with sharper turns. With highway driving, the bounce from high speed bumps would "squish" the tire harder and and cause accelerated wear from the bending. Or maybe they are somehow equal? So what do you all think?
Old 08-14-10 | 01:30 AM
lighthalo's Avatar
lighthalo
definitely street driving wears a tire faster because you have turning, braking, and accelerating, all three of which are the causes of tire wear (assuming same car,tires,and proper size and alignment)
Old 08-14-10 | 03:21 AM
Jetfire's Avatar
Jetfire
Royale with cheese
city driving.
there's very little tire wear from highway.
Old 08-14-10 | 05:46 AM
IS350jet's Avatar
IS350jet
Yep, street driving. Believe it or not, 85% of normal tire wear comes from two things, stopping, and going. The other 15% is turns.
Old 08-14-10 | 07:48 AM
mmarshall's Avatar
In general, bad wheel alignment and improper PSIs wear out a tire quicker than anything else. But, given proper tire pressure and caster/camber/toe settings within specs, stop-and-go driving will generally wear out tires quicker than steady highway miles, especially at with moderate highway speeds that do not excessively heat up the tire (that's one reason why tires have speed ratings). There's one exception to highway driving.......if you are on a twisty highway with lots of sharp curves (the typical "sports-car" road), and you tend to corner sharply or do aggressive driving. That, of course, wears out the edges of the front tires quickly.
Also, all other things equal, if the tires are not rotated properly, a FWD car, being comparatively nose-heavy, will wear out front tires more rapidly than an AWD or RWD car will. And coarse/porous road surfaces, with higher tire friction and rolling resistance, will generally wear out tires faster than smoother ones.
Old 08-14-10 | 03:15 PM
<VENOM>'s Avatar
<VENOM>
Street driving but it also has to do with the car, car weight, the type of tire and the area, hot vs cold and how much and how long
Old 08-15-10 | 01:42 PM
what wears out tires are braking and turning. so yes, urban/city driving (or twisty country roads) wear tires VASTLY more than highway driving.
Old 08-16-10 | 12:53 PM
LexFather
Guest
Posts: n/a
Unless your Highway driving is going 250mph like the Veyron...then your tires last maybe 30 minutes
Old 08-16-10 | 01:37 PM
IS350jet's Avatar
IS350jet
Originally Posted by Jeremy Clarkson
At 250 mph the tires on the Veyron will only last about 15 minutes. That's okay, though, because the fuel tank will be empty in 12
I love that quote.
PatDowdNC
04-16-23 07:36 PM
richard203
09-15-15 11:44 PM
Teal Sc400
Performance & Maintenance
05-17-09 02:34 PM
KoSC300
Wheels, Tires & Brakes Forum
05-19-08 06:33 AM
purebliss
04-09-05 03:51 PM
