Consumer Reports: Honda CR-Z "Not Recommended"
With all of the problems that Honda has had with automatic transmissions in certain models (ie. late 90's early '00s Accords and Acura TLs), I'm surprised CR still recommended those.
Originally Posted by Fizzboy7
Fizzboy7
For CR not to recommend a Honda... that's pretty heavy. Has this happened before with a Honda model? Just more proof of Honda's steady decline. Still wondering when they will wake up.
The Del Sol, as you note, was indeed worse-than-average in body-integrity issues (and, IMO, it was a poor replacement for the superb CRX). That's because Honda, at that time, had little or no prior experience in designing and building that type of vehicle (T-Tops, semi-convertibles, removable roof panels, etc...). And, it showed in the Del Sol, which was plagued with rattles, squeaks, water-leaks, etc.....around the removable-top panel.
Not really. I've reviewed and driven it. It's actually a very well-built, well-crafted car (one of the best in its class, quality-wise), but with a somewhat under-engineered and rough-running drivetrain that needs some work, so that it can better-compete with Toyota hybrids.
Originally Posted by CTB727
If the AC shut off on me in the Florida heat while stuck in traffic, that would be the #1 deal breaker.
On the CR-Z I reviewed, I remember it having a choice of Normal/Economy modes. I don't specifically remember the A/C cutting off at a stop with the gas-engine on the one I drove. It's possible (but I don't remember for sure) that the A/C cutoff at idle is only in the Eco mode. In fact, many hybrids have A/C compressors that are run by small electric motors, not the regular gas-engine.
Guest
Posts: n/a
^^^ I think Honda has a serious problem b/c those cool 180-200hp cars that were gret in the 1990s and early 2000s would be overpriced and underpowered tons today. I would guess a 200hp CRZ would be a 23k-28k car. That's the price of a 300hp 30mpg highway mustang or camaro. The Genesis coupe also would embarress it.
So they wouldn't even have much of a MPG gain over real RWD sports cars! Unless u just are a Honda nut the K20 wouldn't do much.
That's another reason why the future ft-86 has it's work cut out for it.
I agree that, in powertrain and roadability, the Genesis Coupe, especially the 3.8 Track model, easily smokes the new CR-Z....in fact, its powertrain/chassis enginering, IMO, is comparable to that of a number of BMW 3-series products. But the 3.8 Track model can run over 30K (the one I reviewed was 31K). That's roughly 50% more than what a typical CR-Z would run.
