Cheap oil used by Lexus dealership in Indianapolis
Additive packages are different on the cheaper vs expensive name brand synthetic oils.
10K is the interval.I'd trust a long interval with a brand name oil.
According to the bobistheoilguy.com forum,Toyota 0w20 is a great oil formulated for Toyota by Exxon/Mobil with extra moly additive at around $6.50 a qt.
Dealer pays less.
I do my own oil changes but with the cost of a dealer oil change and filter,I would like have a premium brand oil.
A dealer saving a dollar on oil?
What other things too?
Dealer pays less.
Except the sludge problem wasn't due to the oil itself. It's due to the owners not changing the oil on time. Which all goes back to the interval. It's much more important than the brand of oil used. Using "Mobil" or any other established brand will not prevent sludge to occur.
If the oil sludge problem was due to the owners not changing the oil on time as Toyota would like to suggest, then there would be many other make and models of cars with the same sludge problems. The fact that certain year and make of Toyota engine is more likely to have the oil sludge problem than other engines suggest that it is more like a design problem with the engine itself breaking down the oil faster than it should. Toyota settle the 3.5 million dollar law suit because many owners have proof of timely maintenance and yet still have the oil sludge problem. Knowing all of this, why would anybody still have to put in cheap oil for their Lexus.
As far as your last sentence, that is very foolish to assume the oil the OP use is 'cheap.' Unknown brand does not necessarily equate to poor performance. I come from a research background so unless I absolutely know it's crap, it's ignorant to assume it's cheap quality. I guess these big name companies have a monopoly on brand loyalty.
If I were Lexus, I would use an expensive well know popular oil brand, then charge 10X the cost for it. It seems this is what the owners of luxury cars want. They don't seem to care about what is adequate, but what is the "Best" for their engine and are willing to pay for it. The dealership might as well make money of of them. I for one generally change my own oil so I don't really care what oil the dealer uses or charges for an oil change service.
Yes, the oil have to meet Lexus standard and it's not come in the plastic bottle as seen at Walmart either.
All engines are sensitive to brand of oil, if no, Lexus would require certain oil spec. If Harsher means soccer moms driving their RX300 on dirt roads, then it should be fine if these owners change their oil every 4000 to 5000 miles. There are many other brand of engine that does not develope oil sludge just because owner change the oil every 4000-5000 miles instead of 3000.
I dont think I am foolish use a name brand oil. Until these no name brand can prove to me that it is as good as the name brand, I will continue to the brands I trust.
I have preferences for my own oil on high performance / heavier duty motors and I simply bring my own oil in with me. Otherwise I'm fine with what the dealer uses.
at the end of the day you guys are flying above the point.... dealer still charges what they would charge if they used mobil 1/castrol/etc... but instead your getting "minimum requirement" oil... I am not ok with that....
on another note...
Why should I change my oil 1,500 miles earlier just because toyota couldnt get the engine right ? I am not saying the oil that dealership is using is a POS but I am saying the least they can do is make it up by babying the engines their engineers couldnt
on another note...
You're paying for exactly what you're getting - an oil change with the oil the dealer buys. As the dealer rep above said you want the other oil, we'll get it for you. And I suspect you'll pay extra for it.
I'd be fine with the dealer oil for my LS (no matter what they get) but I'd bring my own with me for my old GS.
On your other note, the sludge issue was primarily when owners went beyond (and in many cases well beyond) the recommended service intervals. No one said anything about changing it earlier, except folks who want to baby their engines or someone on a heavier duty cycle. Having different duty cycles / recommended service intervals is standard practice for every car I've owned, from various makers. It isn't just a Lexus thing.
No not really. Look into any manual and see what the recommended oil is. You won't find a brand because it's nonsense to suggest one over the other. What they require is the oil of the correct weight, API certification, and it's category (SM, SL, etc). If the engines are sensitive to the brand of oil, then Toyota would have already have a list of what to use and what not to use. You cannot argue that the brand matters, but also mention that Toyota cannot suggest one.
There have been oil analysis done that shows even 'cheap' oil like the Chevron or Walmart's SuperTech do well of protecting the engine. Practically any API certified oil will have your engine running for a long time and it all comes down to maintenance. These 'certain' type of oil that Toyota requires is nothing special. Mobil, Castrol, etc do not have monopoly on the certification.
The requirement that Toyota sets out their Lexus vehicles is no stricter than the one for a Toyota Corolla. You can always try a different dealership, but I don't see Tom Wood Lexus doing anything wrong. If they went with a non-API certified oil, then that's an issue you can complain about.
What I really was trying to say was that given scenario 1) Of using no name brand oil that meets certification and changing it out every 3-4K miles, or 2) Using name brand oil and prolonging its oil change well past its proper interval change, I would opt for scenario 1. That said, proper oil change interval to me is not when the book says to, but when the oil is broken down and no longer doings its job. How do you find out? Oil analysis. I don 't have the time to send my oil out, so I generally just go with what others who have send their oil out for analysis and have what I feel is similar driving style and conditions is I do and copy their interval change, with maybe being a little on the conservative side as well.
Even Jiffy Lube will use API certified oil, that doesnt mean I will take my Lexus there for an oil change. Bottom line is, if I take my car to a Lexus dealer, I expect that dealer to use oem Lexus parts and fluids, if I want to use generic part and fluids, I will take it to a Jiffy Lube.
I am not saying all non-oem brand oil are inferior, but why take the chance when you dont have yo.
What's the problem if it meets and/or exceeds OEM specifications? I'm going to put more faith in Tom Wood Lexus who has done the research on the oils and has more first hand experience with the results of the using the oil since they are the ones that see the cars that use their product on a daily basis.
