Use your A/C compressor regularly.
We are starting to get some current and up-to-date automotive AC information on this thread, a good thing.
Obviously in the last 10-15 years AC compressor failures are extremely rare. These modern AC systems are very reliable and robust.
I can report on one AC compressor failure dating back to a 1996 JGC (a SUV I sold to a family member in early 2001), the AC compressor failed at about 140K miles but not while I owned the vehicle. Otherwise I've experienced zero AC failures in the dozens of vehicles owned.
Good point....if that is indeed the case. There may (?) be a way to easily disconect a hybrid battery-pack, but I'm not aware of any (and I'll defer to you on that, since you own a hybrid). A hybrid battery-pack, though, holds a lot more power than a conventional gas-engine battery....seems like it would take a lot longer to discharge it under parasitic-drain conditions while parked.
Porsche cars are often garage queens used mostly in fair weather conditions. So they will often sit for weeks at a time in garages during mediocre weather. A battery maintainer helps (a OEM battery charger that plugs into ciggie lighter plug), but even using that I found the batteries lasted about 4 years.
I'm not especially diligent. I do not use my compressor for weeks at a time during the colder months. I use my auto climate control systems manually most of the time with manual use/control of the AC button. "Computers in my cars" are not "diligent about using the compressors".
My vehicle ownership experiences and use of AC is not uncommon these days. I think you started a good thread with the usual common knowledge out there, and now we have others chiming in with current/relevant/useful/updated information related to the automotive AC systems of today.
No, I don't play soccer!
Might not be too recent, the compressor was replaced on my '99 RX300 in August '03. It was less than 5 years old and about 50K on the odometer. The first symptom was the flashing A/C light/hot air followed soon after by a completely inoperable instrument panel. The repair was over $500 for a remanufactured compressor. I had the extended warranty so I was covered. Didn't even have to pay the deductible. Everything worked well for the next month. I don't know what happened beyond that because I traded it in for the 330 I had ordered before the A/C failed.
Mike, is the compressor on your GS450h electronic or belt driven?...just curious as the Prius is electronic.
12-12-12 09:07 AM
