Moisture in Head light assembly
My Integra has moisture in the head light assembly on one side. Has any one had this problem?
And if so how do I fix it?
Red 99
It's a 99. . . over 10 years old. I wouldn't be surprised if the headlight wasn't the only place with moisture, no matter what make or model.
You can take apart the headlight, remove the moisture, and reseal it. Of if you don't want to take it apart, wrap it in some cheesecloth, throw it in a bag of silica or uncooked rice in a hot, dry place for a week, then reseal the headlight with some high-temp sealer. But this is a good a time as any to take it apart and clean it. I would also check the rubber bulb boot. . . it's usually the first place to leak moisture in.
