2jz swap runs lean under boost
Hello
I have just installed an Aristo "JDM" 2jzgte into my 92 mk3 Supra,I went single turbo"t67" with 3 inch exhaust,3 inch intercooler and pipes. 440 cc inj
the problem I am having is this.
if I just drive normal little or no load I run at 14.5 which is perfect,
if I let off it goes rich as low as 10.0, the problem is when I go into BOOST
while under pressure 10 PSI max, it goes lean if I ease into it, if I stomp on it it will run rich??? WTF, Has anyone run into this issue?
It's very noticable sometimes I actually feel a noticible Bog.
also does anyone know what 3 wire oxygen sensor I can buy "screw on type" ?
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
lemmiewink
Performance & Maintenance
03-05-09 05:45 PM
