View Poll Results: Gas station
Shell
30.95%
76
0%
Chevron
35.71%
Costco
14.29%
Doesn't matter
16.67%
Anything
2.38%
Voters: 42. You may not vote on this poll
Gas station
Old 10-06-11, 06:01 PM
rkyat
rkyat's Avatar
Primarily BP, as it closest to my house. If im out i try to find a station thats not too shady looking. Also use premium majority of the time. I dunno if its all in my head, but when using regular my car doesnt feel the same.
rkyat is offline
Old 10-06-11, 06:44 PM
RXSF
RXSF's Avatar
My parents always put Chevron in their cars. We never mixed fuels as a child. So now, that is what I do too
RXSF is offline
Old 10-06-11, 09:13 PM
T0ked
T0ked's Avatar
Sunergy. It's a private station that is about 3 blocks from me. Consistently about 10 cents cheaper than anything around me. Funny thing is, a tanker was filling the station's tanks. The side of the tank was blank, but the small sticker on the back of the tank had exxon/mobil on it. Probably same fuel. Been using it for 3 years without any issues.
T0ked is offline
Old 10-06-11, 09:53 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,982 Likes on 2,410 Posts
All the stations get all the same base stock. Each brand adds its own additive packages (or not). The only thing that's important - it needs to be uncontaminated and the right octane. The brand really and truly does not matter nearly as much as they would like us to believe.
lobuxracer is offline
Old 10-06-11, 10:05 PM
gengar
gengar's Avatar
Wikipedia article: "Top Tier Detergent Gasoline"
I just use Shell.
gengar is offline
Old 10-06-11, 10:18 PM
VIPG35
VIPG35's Avatar
Chevron and Shell for me
VIPG35 is offline
Old 10-06-11, 10:28 PM
SaintNexus
SaintNexus's Avatar
Good Economy with money for Great Gas: Chevron
Bad Economy with no money for Cheap Gas: Arco.
Arco for the longest time. Will start doing Chevron in a year or so, hopefully.
SaintNexus is offline
Old 10-06-11, 10:32 PM
edgeucated
edgeucated's Avatar
I used mobil when im at home because its close. Now that i moved out for college, I use chevon because its close. However, I still think its best to just switch around, that way you get all the different additives from different gas stations to clean your car.
edgeucated is offline
Old 10-06-11, 10:51 PM
Vroomin350
Vroomin350's Avatar
Used to use BP religiously specially when they had that 8gallon gift card game made some $$$ back
Now, w.e is in my way. Here in Miami shells tend to be more expensive though the other day a shell was ridiculously cheap @$3.55/gallon for premium.
Vroomin350 is offline
Old 10-07-11, 02:51 AM
rkyat
rkyat's Avatar
Originally Posted by meowCat
If I'm not mistaken, those Genesis engines benefit from higher octane fuel. Works find on regular unleaded but with premium of 92 octane or higher you get hp and tq increase.
So i've read. Just never had a definitive answer, lol.
rkyat is offline
Old 10-07-11, 07:11 AM
Lil4X
Out of Warranty
Lil4X's Avatar
So long as it will flow and burn, today's gasoline engines will run on almost any grade of gas. I was told about ten years ago that while my RX would run just fine on regular, that the ECM was set up to default to premium. While torque and hp were probably close, sometimes the engine would stumble on hard acceleration as the knock sensors yanked back the timing to accommodate the lower octane fuel. It didn't do any harm to the engine, but you got a smoother transition to full throttle with premium.
Lil4X is offline
Old 10-07-11, 07:14 AM
Joeb427
Joeb427's Avatar
No Chevron here so it's Shell 93 V-Power.
Joeb427 is offline
Old 10-07-11, 07:50 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Same here, Shell V-Power.
kitlz is offline
Old 10-07-11, 08:08 AM
GSteg
GSteg's Avatar
BINGO.
All this additive package stuff is nonsense because the concentration level is so low that it has negligible effect on the engine. Hell, I've pulled out my injectors and had it tested. They were semi-clogged, and that's with the car using Chevron its entire life.
A bottle of fuel cleaner, preferably one with high concentration of PEA, will do far more cleaning than a tankful of top tier 1 gasoline.
GSteg is offline
Old 10-07-11, 08:09 AM
Lexmex
Super Moderator
Lexmex's Avatar
Of the ones you mentioned, Chevron. However, our V8 4Runner gets Shell. I also really like Sunoco.
Lexmex is offline
Quick Reply: Gas station
