Why did Honda kill its best performance engine?
Exactly. This is what I was referring to. While the industry is leaning more toward turbo four cylinders to gain on all ends, Acura is dumping theirs. What needed to be done was refine and improve the current RDX engine. It had all the potential to give good power and efficiency.
Most shoppers of cross overs or SUV's don't usually look for performance. The fact that it got only 20 mpg (or less) was what IMO killed this engine. The whole idea of a turbo 4 over a V6 in an application like this would usually be to get better fuel economy. They didn't deliver.
It was not the engine that got bad fuel economy. It was the vehicle it was in. A 4000lb, awd, taller CUV is not going to get good fuel economy no matter what engine you put in it. In a lower more aerodynamic sedan that weighed 500lbs less without awd it will have got decent to good fuel economy and would have been a blast to drive. It is a shame and a real waste they never tried to put it in a coupe or sedan which is the type of vehicle that power plant was most suited for. I test drove one and it is powerful, fun, and holds the road really well. They missed a big opportunity by not putting it in a sedan/coupe.
Guest
Posts: n/a
It was not the engine that got bad fuel economy. It was the vehicle it was in. A 4000lb, awd, taller CUV is not going to get good fuel economy no matter what engine you put in it. In a lower more aerodynamic sedan that weighed 500lbs less without awd it will have got decent to good fuel economy and would have been a blast to drive. .
RDX
Curb weight, lb (kg)
FWD 3743 (1698) -
AWD 3942 (1788)
RDX FWD 19 / 24 / 21
RDX SH-AWD17 / 22 / 19
So the FWD model is not 4000 lbs and still gets crap MPG considering its low weight and small size. The AWD model is near 4000 lbs and gets crappier MPG. r.
To compare
Their own MDX gets
Combined-18
16
City
21
A MDX weighs between 4600-4700 lbs. A whopping one less MPG.
So it has nothing to do with weight. Its an engine that just got terrible MPG.
Lets compare some more
An Audi Q7, which is much much larger gets 18 MPG combined, 1 less
A Chevy Tahoe, another much larger vehicle, with a V-8, gets 17 MPG combined, a whopping 2 less than the RDX AWD.
etc etc
So as we can see the RDX gets FE on par with vehicles two sizes up.
A 4500 lbs RX 450h gets 31 MPG average. So much for the weight penalty.
A RX 350 AWD, a vehicle the next class up gets 20 MPG average and the FWD 21 MPG.
A 4500lbs AWD X5 gets 19 MPG, same as the RDX AWD.
etc etc..
Had nothing to do with weight as we can clearly see it just guzzles gas.
RDX
FWD 3743 (1698) -
AWD 3942 (1788)
To compare
Their own MDX gets
Combined-18
16
City
21
Lets compare some more![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
etc etc
So as we can see the RDX gets FE on par with vehicles two sizes up.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
A 4500 lbs RX 450h gets 31 MPG average. So much for the weight penalty.![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
etc etc..
FWD 3743 (1698) -
AWD 3942 (1788)
To compare
Their own MDX gets
Combined-18
16
City
21
etc etc
etc etc..
True and Premium gas.
