Patent application shows BMW working on seven-speed manual
As a guy who drives a 6MT, I can't see much benefit from the 7th. Particularly with a manual clutch system, it quickly approaches a point where the additional acceleration provided by the closer gear ratios is offset by the additional time required to shift. My car is only a 2.5L and I don't want my gears even closer than they are. If anything I'd like 6th gear spaced farther out. Unless BMW plans to start making cars with a narrower power band than the S2000 it just seems silly. Maybe they need Autobahn passing gears? Eh, let them build it. It should at least be a fun engineering project.
Haha anyways, I just read a bit on the patent application of BMW and so far, here's what their thinking so-far.
http://www.worldcarfans.com/11206074...igns-uncovered
Aside from that BMW also thought of a second application mating retaining H-manual shifting functionality........but this time using "SHIFT BY WIRE" technology.
So such a prospect would still feature tradition H-manual shifting......but this time, due to "Shift By Wire" technology, there won't be any clutch pedal.
I imagine something like this would be easier for beginner drivers and learners who have a hard time using 1st and reverse gears especially on uphills (where throttle modulation is required between clutch and gas/accelerator pedals).
Something like that.
What are your thoughts guys?
BMW's design proposal acknowledges that automated transmissions have a clear advantage in terms of efficiency due to their wider range of gear ratios. However, BMW is looking to bring the manual transmission up to par by adding 7, 8 or even 9 gears. In doing so, safety problems have emergeg such as incorrect gear selection which causes the engine to over-rev or stall. BMW's solution is to use a gear shift mechanism that only allows shifts that are within an allowed range to be executed. Technically speaking, this would be implemented by having the shifter gates surrounded by a magnetorheologic or electrorheologic fluid. Monitored by various sensors, a magnetic field or electric voltage applied to the fluid would change its viscosity, physically preventing or allowing certain gears to be engaged.
"The technology can be used on a traditional manual transmission with up to 8 gears. The driver rows his own gears as usual (and uses a clutch pedal), but the computerized shifting module described above allows the driver to shift into proper gears while blocking dangerous gears, thus avoiding mechanical over-revs (the "money shift") for a manual transmission with so many gears," according to the design proposal.
BMW also envisions this technology for a second application called "Shift by Wire." Combining the best of both worlds, Shift by Wire completely omits the clutch pedal. Think of it as an SMG sequential gear box but with the traditionally gated manual gear shift lever possibly up to 9 speeds.
I love the money shift-blocking gate for the 3-pedal manual. I think it's a great idea and would buy a 7-8 speed manual with it.
An SMG with an H-pattern seems to me to combine the negatives of both transmission types. You lose the optional automation and shift paddles of a traditional SMG, but don't get any of the advantages that a clutch pedal provides. Do not want.
05-06-17 01:30 AM
