View Poll Results: "There's no replacement for displacement."
Agree
26
56.52%
Disagree
19.57%
Neutral (or it depends)
21.74%
No opinion/no comment
2.17%
Voters: 46. You may not vote on this poll
"There's no replacement for displacement." Agree? Disagree?
#61
Especially compare to a pushrod motor. Many turbo 4 set up weight the same as a Chevy small block V8. Just look at all the latest drift car, they are all running LS swap instead of the old turbo 4 that they all had. And why? Displacement!
#63
#64
Maybe I missed your point, because your opinion was pointless (re: Evo) in the first place? Unless, you care to back up your statement?
#65
You win, I don't care anymore. I shouldn't have post in the 1st place. My opinion was pointless, if you think about it, everything in life is pointless.
#66
That's hardly a flat torque curve.
I'll see your 2-liter and raise you another liter.
BMW 3.0L N55 (twin-scroll single turbo), JB4 Stage 2.
http://www.burgertuning.com/N55_Stage2_Jb4.html
Here's an N55 with the following mods on a Mustang Dyno:
jb4 stg2 with iso running Map 5
ar 4 " nocts
bms intake
cpe chargepipe
Compare it to my custom (self) tuned Evo IX w/ intake/exhaust/DP:
My old little 4 banger has more hp and more torque (at almost the same low rpm as well)...
#68
#69
Read what?
Here's the original N55 Mustand Dyno post: http://www.n54tech.com/forums/showthread.php?t=18020
#72
Read what?
I've been giggling at these torque specs for some turbo engines including BMWs advertising maximum torque at only 1250rpm, a completely unrealistic loading situation that's never going to happen in any sort of situation with the cars unless they're being driven stupidly with manual transmissions, and HOW LONG would it take them to reach full torque at only 1250rpm, a minute??
#73
Okay so lets put both on a Dynapack then, tune to about equal power, hold them at specific RPMs, and then time how long it takes each engine to go from completely unspooled to max torque. Slow roll in 4th gear at about 2000rpm, it'll take my 3.0L a few seconds to get up to full boost. What about a 2.0L? What about a 1.0L all at equal power levels? Then compare with a 6.0L NA with no "lag" or turbo to spool at all.
#74
#75
& low rpm torque & durability & reliability & cost
