GM 6.2L V8 claims most powerful light-duty truck engine title
![](http://hss-prod.hss.aol.com/hss/storage/adam/d7ba86350921c6a954ac405ea6194a01/001-2014-chevrolet-silverado-high-country-1368027039.jpg)
General Motors has officially captured the horsepower crown for mainstream pickup trucks with its 6.2-liter V8. The big mill, available in both the Chevrolet Silverado and GMC Sierra, comes to market with 420 horsepower and 460 pound-feet of torque, handily outdoing its two cross-town competitors, Ram (5.7-liter V8, 395 ponies and 407 lb-ft) and Ford (6.2-liter V8, 411 hp and 434 lb-ft).
The new GM 6.2 will take a bit of an investment, though. Those that want the extra thrust will need to go with either the LTZ or High Country trims from the Chevy, or the SLT and Denali trims from GMC, which are the two highest trim levels for the respective vehicles. Trim levels aside, if you're in the business of towing, GM has you covered. Optioned with the 6.2-liter V8 and the Max Trailering Package, owners will be able to pull 12,000 pounds, a hugely impressive figure.
It's Official: 2014 Silverado and Sierra Deliver Most Power
New Chevrolet, GMC light duty pickups also deliver best towing capacity in class
DETROIT – The 2014 Chevrolet Silverado 1500 and High Country and the GMC Sierra and Sierra Denali 1500, available this fall, with a 6.2L V-8 produces an SAE-certified 420 horsepower (at 5600 rpm) and 460 lb-ft of torque (at 4100 rpm), the most power of any pickup engine and torque of any light duty pickup truck engine.
The 6.2L V-8 available for Silverado LTZ and High Country and Sierra SLT and Denali models also delivers class-leading maximum available trailering capacity of 12,000 pounds when properly equipped.
"Power and towing capacity are fundamental capabilities for full-size pickups," said Jeff Luke, General Motors Executive Chief Engineer for full- and mid-size trucks. "The 2014 Silverado and Sierra deliver unmatched power and towing capability with a host of ingenious driver aids."
The optional Max Trailering Package is available on 2WD and 4WD V-8 crew cab and double cab models and includes:
Trailering package with seven-pin and four-pin connector
Enhanced cooling
Automatic locking rear differential
Heavy-duty 9.75-inch rear axle with 3.73 ratio
Increased-capacity rear leaf springs
Revised shock tuning for increased control
Integrated trailer brake controller.
In addition to the 6.2L V8, Silverado 1500 and Sierra 1500 will offer a 4.3L V-6 SAE-certified at 285 horsepower and 305 lb-ft of torque and a 5.3L V-8 certified at 355 horsepower and 383 lb-ft of torque.
Silverado and Sierra trucks equipped with the 4.3L V-6 will have available towing ratings of up to 7,600 pounds, the highest for any base V-6 in the segment. Silverado and Sierra trucks equipped with the 5.3L V-8 and the max towing package, available later this year, will have towing ratings of up to 11,500 pounds when properly equipped.
All three engines feature direct fuel injection, Active Fuel Management (cylinder deactivation) and continuously variable valve timing, a combination not found in competitor vehicles. The engines also use a compact overhead-valve design and weight-saving components such as aluminum blocks and cylinder heads to reduce mass for additional energy savings.
All three provide the proven power, torque and dependability of a large-displacement engine, seamlessly switching to four-cylinder mode to save fuel during light-load driving. The 5.3L V-8 has EPA-estimated fuel economy of up to 23 mpg highway (2WD models), the best of any V-8 pickup, and better than Ford EcoBoost V-6. .
EPA fuel economy estimates for the 6.2L V-8 will be finalized in the near future.
Enhanced cooling
i guess 'light duty' means you only want to pull a house, and not the space shuttle.
Have a 6.2 in the 2013 Denali and as of right now its one of my fav engines.
Some guys are throwing 402 cam with headers \ ex and throwing down 500hp NA
Engine sounds amazing
Excited to see what Ford has in store for the 2015 F-150
11.0:1 compression
direct injection
cylinder de-activation
regular fuel
http://media.gm.com/media/us/en/gm/n...3-engines.html
Toyota really needs to update their 5.7L if they're serious about staying in the truck market. This is a far more advanced engine that's also putting out more HP/L and TQ/L despite being an OHV 2-valve engine to Toyota's DOHC 4-valver. They're also claiming better mileage than the Ford EcoBoost V6 with the 5.3L V8. Really cool stuff.
direct injection
regular fuel
I have the 09 6.2L and freaking love it. And the sound is amazing bone stock. But I have the Volant CAI and straight exhaust after the Cat and its stupid how good this truck sounds.
This is as interesting as the market will ever get in north america, and will be [maybe] a 3-way tie, once each brand fully investigates their options/market shares.
The dodge diesel will generate a lot of buzz [and has been], since the only option is a 2500HD diesel and that's not a cheap truck. Mind you a lot of those contractors may not necessarily 'need' the 2500-ness they come with so a smaller motor might fit the bill, and if they happen to introduce it quicker than the other two in-house brands, i'd be curious to see how much market share they may set to gain...
11.0:1 compression
direct injection
regular fuel
Toyota really needs to update their 5.7L if they're serious about staying in the truck market. This is a far more advanced engine that's also putting out more HP/L and TQ/L despite being an OHV 2-valve engine to Toyota's DOHC 4-valver. They're also claiming better mileage than the Ford EcoBoost V6 with the 5.3L V8. Really cool stuff.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
direct injection
regular fuel
They might be playing it smart by catering to a niche market amongst the blue collar world, vs. all the base model trucks out there.
Hoovey689
09-18-13 11:54 PM
Hoovey689
08-29-13 04:28 PM
