Wider tires, sidewall height, and ride quality
I've had my wheels for about a year and a half and I'm ready for a change. The original wheels are 215/60/R16, mine are 225/45/R18. I can honestly say that ride quality is excellent, at 29 PSI. At 32 PSI it is still good but noticeably firmer (though the same could be said if you ran a 16" tire at 32 PSI). However, there is a greater risk of wheel damage running at a lower PSI.
![Wider tires, sidewall height, and ride quality-uwcyzbu.png](https://www.clublexus.com/forums/attachments/car-chat/498550d1683164658t-wider-tires-sidewall-height-and-ride-quality-uwcyzbu.png)
For my next set of wheels, I'm thinking of going 17". The standard size for 17" fitment (and the one used on 05 and later models of the ES) is 215/55/17, which will be the closest match for speedometer accuracy. I don't mind it being off 2 or 3 percent, though, if it means a better ride quality. My question is, would the extra .21 inches of extra sidewall of the 225 contribute to better absorption of vibration or would the 225's extra .4 inches in width offset the effect of any sidewall increase? Thanks.
extra width, more noise. extra height, better absorbtion/comfort.
All else equal, extra width not only means more road noise, but less traction on wet/slick roads and MORE traction on dry ones....especially with high-performance tires. That's because a wider tire, according to the laws of physics, spreads its weight (and the weight of the car above it) out over a wider area of the tread, lessening the amount of grip per square inch of tire-tread surface on slippery surfaces (more so than on dry ones, where the rubber grips more), although the type of rubber/silicone tread compound used can help minimize this. That's why the best winter tires are often relatively tall and narrow.....and why RWD ultra-wide tire cars ike the Dodge Viper and Corvette can be virtually useless in the winter.
One more thing to take into account with low-profile tires is that, all else equal, you will have less impact-protection for both the tire and the wheel if you hit a sharp bump or pothole. Tire shops do an amazing amount of buisness each year replacing wheels and low-profile tires from rough-road damage.
I would highly recommend anyone interested in this topic to read these two articles:
http://grassrootsmotorsports.com/articles/speed-holes/
http://www.caranddriver.com/features...d-tires-tested
Interestingly there was no measureable difference in dB between 15" and 18". The VW Golf measured 70dB for most of the readings at 70mph. I have a professional dB meter and my ES measures between a low of 61.6 and mid 60s without nearby traffic, depending on the road.
I was only wondering whether the extra width of 225 would outweigh the slight extra amount of sidewall, since 215/55/17 already has a lot of tire flex. Noise isn't a concern, only ride. Any thoughts?
Thanks.
I posted that for a reason.
A lot of people today simply judge tires/wheels by their looks and/or how much they fill up the wheel-wells. Huge wheels and wide/thin rubber-band tires today are considered "cool" , but many potential buyers don't really know (or don't stop and think about) what they are actually getting.
Thanks.
A lot of people today simply judge tires/wheels by their looks and/or how much they fill up the wheel-wells. Huge wheels and wide/thin rubber-band tires today are considered "cool" , but many potential buyers don't really know (or don't stop and think about) what they are actually getting. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
So make sure you select softer tire, not hard one... that will also influence it. If you select fatter tire but also harder one, then you are back to square 1, or worse.
On the combination of frost-damaged roads and low-profile tires, though, there's potentially more to worry about than just a noisy/unpleasant ride. Because of the thinness of the sidewalls, a tire/wheel impact with a sharp bump or pothole-rim could lead to tire failure or a cracked alloy wheel.
