Help with a US-spec vehicle
I'm looking at a '97 LX 450 which has been imported from Houston, can anyone please run the vin through carfax and check its history?
Thank you
VIN = JT6HJ88J2V0177174
Thank you
In Recovery Mode
Carfax is not really allowed to be discussed here. I cannot run a carfax but I can see the dealership records. Last time it was serviced was 2010. Here ya go.
SERVICE TYPE DATE SERVICE PROVIDER MILEAGE REPAIR # DESCRIPTION
Dealer Reported 07/28/2010 Reliable Lexus 104204 0082726 VERIFY MILES ON ODOMETER AND PERFORM MISSOURI STATE INSPECTION
Dealer Reported 07/28/2010 Reliable Lexus 104204 0082726 MPI FILTER
Dealer Reported 07/28/2010 Reliable Lexus 104204 0082726 DECLINED
Dealer Reported 07/26/2010 Reliable Lexus 104158 0082665 PERFORM LEXUS ENGINE OIL AND FILTER CHANGE USING CASTROL SYNTEC BLEND MOTOR OIL
Dealer Reported 07/26/2010 Reliable Lexus 104158 0082665 BRAKE INSPECTION/ROTATE/BALANCE TIRES
Dealer Reported 07/26/2010 Reliable Lexus 104158 0082665 PERFORM WORLD CLASS INSPECTION
Dealer Reported 09/09/2009 Metro Lexus 98115 0356589 REPLACED MUFFLER AND GASKETS
Dealer Reported 09/09/2009 Metro Lexus 98115 0356589 REPLACED EXHAUST BRACKET AND CUSHIONS
Dealer Reported 06/22/2009 Metro Lexus 97006 0350861 BALANCED ALL FOUR TIRES ALSO NOTE EXHAUST SYSTEM RATTLES AND VIBRATES BUT THERE
Dealer Reported 06/22/2009 Metro Lexus 97006 0350861 PREVIOUSLY INSPECTED FOR SIMILAR CONCERN
Dealer Reported 06/17/2009 Metro Lexus 96937 0350420 TECH REPLACED THE AIR INTAKE HOSE THAT WAS BROKEN AND ALLOWING UNMETERED AIR INT
Dealer Reported 06/17/2009 Metro Lexus 96937 0350420 TECH REPLACED THE DRIVE BELTS THAT ARE CRACKING AND MAKING NOISE
Dealer Reported 06/17/2009 Metro Lexus 96937 0350420 TECH REPLACED THE REAR EXHAUST MANIFOLD AND GASKETS THAT WERE LEAKING
Dealer Reported 06/17/2009 Metro Lexus 96937 0350420 TECH REPLACED THE BANK 1 SENSOR 1 OXYGEN SENSOR THAT WAS AFTERMARKET AND MALFUNC
Dealer Reported 06/17/2009 Metro Lexus 96937 0350420 PHONE INFO
Dealer Reported 07/26/2008 Classic Lexus 89832 0567676 INSPECT BATTERY CHARGE LEVEL
Dealer Reported 07/08/2008 Metro Lexus 89402 0323730 UPON INSPECTION TECH FOUND A SHIFTED BELT IN RIGHT FRT TIRE.MOUNTED/BALANCED NEW
Dealer Reported 05/19/2008 Metro Lexus 88553 0318711 PERFORMED DIAGNOSTICS NO OIL LEAKS CAR DUE FOR OIL CHANGE COULD BE USING SOME OI
Dealer Reported 05/19/2008 Metro Lexus 88553 0318711 BALANCED ALL FOUR TIRES
Dealer Reported 05/19/2008 Metro Lexus 88553 0318711 PERFORM 4 WHEEL ALIGNMENT - ADJUST TO FACTORY SPECIFICATIONS
Dealer Reported 05/19/2008 Metro Lexus 88553 0318711 PERFORMED TUNEUP REPLACED SPARK PLUGS AND DIST CAP AND ROTOR AND COIL WIRE
Dealer Reported 05/19/2008 Metro Lexus 88553 0318711 CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE P
Dealer Reported 12/18/2007 Metro Lexus 83921 0306229 TECH INSPECTED AND FOUND THE FRONT POWER STEERING COOLER LINES ROTTED OUT CAUSIN
Dealer Reported 12/18/2007 Metro Lexus 83921 0306229 INFO
Dealer Reported 12/18/2007 Metro Lexus 83921 0306229 TECH LUBED THE DRIVERS DOOR RUN CHANNEL SEAL. IT IS OPERATING SMOOTHLY AT THIS T
Dealer Reported 10/19/2007 Metro Lexus 83251 0301203 CHANGE ENGINE OIL AND FILTER, CHECK/ADJUST ALL FLUID LEVELS, CHECK/ADJUST TIRE P
Dealer Reported 10/19/2007 Metro Lexus 83251 0301203 TECH REPORTS REPLACED ANTENNA MOTOR ASM
Dealer Reported 03/21/2007 Metro Lexus 79886 0282045 TECH INSPECTED AND FOUND THE O2 SENSOR GASKET LEAKING. TECH REPLACED
Dealer Reported 03/21/2007 Metro Lexus 79886 0282045 INFO
Dealer Reported 01/02/2007 Metro Lexus 78589 0275603 80,000 MILES -OR- 70 MONTH MAINTENANCE SERVICE
Dealer Reported 01/02/2007 Metro Lexus 78589 0275603 TECH REPORTS VEHICLE DOES NOT HAVE A/C FILTER, DID PERFORM A/C FRIGI CLEAN
Dealer Reported 01/02/2007 Metro Lexus 78589 0275603 INFO
Dealer Reported 05/03/2006 Metro Lexus 75206 0254561 REPLACED A/C CONDENSOR AND RECHARGED A/C SYSTEM
Dealer Reported 05/03/2006 Metro Lexus 75206 0254561 REPLACED FRT BRAKE PADS RESURFACED FRT ROTORS AND REPACKED BEARINGS
Dealer Reported 05/03/2006 Metro Lexus 75206 0254561 CHANGE ENGINE OIL AND FILTER,CHECK/ADJUST ALL FLUID LEVELS,CHECK/ADJUST TIRE PRE
Dealer Reported 05/03/2006 Metro Lexus 75206 0254561 REPLACED LEFT SIDE MARKER BULB
Dealer Reported 05/03/2006 Metro Lexus 75206 0254561 R/R FREED UP EMERGENCY BRAKES AND REPLACED RUSTY BRACKET
Dealer Reported 03/31/2006 Metro Lexus 74876 0251984 TECH REPLACED BANK ONE SENSOR 2 OXYGEN SENSOR---RE-TESTED AND FOUND NO OTHER COD
Dealer Reported 03/31/2006 Metro Lexus 74876 0251984 TECH PERFORM THROTTLE INDUCTION VALVE CLEANING SERVICE
Dealer Reported 05/06/2005 Metro Lexus 67222 0221758 60,000 MILES OR 4 YEAR SERVICE CHANGE ENGINE OIL AND FILTER CHANGE BRAKE FLUID R
Dealer Reported 05/06/2005 Metro Lexus 67222 0221758 CUSTOMER PAY PORTION OF RUNNING BOARD REPLACEMENT, CUSTOMER PAY PORTION $ 371.23
Dealer Reported 05/06/2005 Metro Lexus 67222 0221758 R&R RIGHT REAR TAILIGHT BULB
Dealer Reported 05/06/2005 Metro Lexus 67222 0221758 WARRANTY/GOODWILL PORTION OF RUNNING BOARD REPLACEMENT. SPLIT COST WITH CUSTOMER
Dealer Reported 05/06/2005 Metro Lexus 67222 0221758 TECH REPORTS CODE FROM EGR. CUSTOMER DECLINED REPAIR @ THIS TIME, WILL WAIT FOR
Dealer Reported 05/06/2005 Metro Lexus 67222 0221758 MISC APPT NOTE
