Flashing indicator Low 2 gear
Anyone know what this indicator is referencing? the 2 to the left of the Low gear in the right instrument panel is flashing. Shifting the gear makes no difference
welcome. you might want to indicate what kind of vehicle you're talking about so we can move it to the right forum.
Welcome to CL as a new poster.
It sounds like the transmission had a malfunction/failure of some sort and the car's engine/transmission computer locked it in what is called a "Limp-Home" mode in which the transmission is locked in second gear. That gives you the ability to start up from a stop (with some engine lugging) and drive to the nearest repair shop slowly. That is normal with the "Limp-Home" mode...for the transmission to stay in second.
A technician will probably have to download the malfunction code, inspect the transmission, and maybe do some diagnostic tests to determine the cause of the failure and/or what repairs may be need.
bowen.chau
RX - 1st Gen (1999-2003)
06-02-13 07:58 PM
