Is my tire patchable?
looks like it's worth a shot at patching to me because it doesn't look like it's damaging the sidewall material itself / structurally.
That looks to me like it's just far enough away from the sidewall to be patchable. Make sure, though, if they take the tire off the rim to patch it from the inside that they remount it and balance it correctly. I did a whole thread on just the subject of proper mount/balance recently. Make sure, also, that the shop knows how to properly replace the tire-pressure sensor.....that can be difficult, and not al shops know how to do that. If they don't have to take the tire off the rim, of course, that won't be much of an issue.
Update: I went to Discount tires to see if they could patch it, and they said the nail puncture occurred at the curvature region and they would not be able to patch it.
However, they were willing to sell me a used, but newer identical spec tire to my current hankook v12 tire. Price out of the door, including mounting/balancing came out to be $70.
I ended up buying the tire, but not sure if I got tricked haha. Guess it's too late for me to change my mind now, but I'm just curious to see if they were lying when they said the tire was unpatchable:
This is what the inside of the tire looked like, you can see the bump where the nail was removed:
![](http://i1349.photobucket.com/albums/p745/UnEdgeUCated/IMG_1460_zps5187e670.jpg)
Also, did they mount/balance it properly and install the tire pressure sensor correctly? If so, you won't have any shimmies/vibrations in the steering wheel or car structure, and the warning light for the tire-sensor will come on momentarily (with the other warning lights) when the ignition is first turned on and then go off in a couple of seconds. If not...time for a trip back to the shop.
sounds like discount tire treated you right.
The pursuit of F
I was the go-to guy for difficult or unusual tire repairs before I recently retired. We would not normally have repaired this tire. There are RMA (Rubber Manufacturers Association) guidelines for acceptable repairs and this tire is well outside those guidelines. Repairs outside those guidelines leaves the dealer exposed to too much potential liability.
I would on occasion do a repair like this anyway. It is a difficult repair because of that very curved area you have to buff to the correct smoothness. Done correctly, a repair will work fine. In 35 years, I knew only a very few people I would trust to do this correctly.
The scary part of even a good repair on or too close to the sidewall is if that tire is ever run very low or flat again, the repair can be heated and abraded to the point of failure. Once any tire has been run soft or flat long enough, the liner can become soft and tacky making any more repairs impossible.
