Damages due to under carriage collision LS460
Old 01-13-15, 08:18 PM
mcmayer
mcmayer's Avatar
Post Damages due to under carriage collision LS460
What is everyone's experience in going over something and damaging the under the car (undercarriage) of Lexus LS460/LS600. I have a 2008 LS600HL. The engine cradle got damaged, and there is frame damage. What are other items I should be aware of. Which areas of the car and body usually are affected by this kind of collision.
mcmayer is offline
Old 01-13-15, 08:53 PM
mmarshall's Avatar
Welcome to CL as a new poster.
What exactly did you hit with the LS that damaged it?....or don't you know? The LS600HL, of course, being a hybrid, has different components (and generally more of them) in the engine-cradle than the regular LS460.
mmarshall is offline
Old 01-13-15, 10:34 PM
I8ABMR
I8ABMR's Avatar
damn. I had an LS460 before my ISF and they ride relatively high. The damage you describe sounds serious. Did you go over a curb or something very large ?
I8ABMR is offline
Old 01-14-15, 06:08 AM
baddis es
baddis es's Avatar
Originally Posted by mcmayer
What is everyone's experience in going over something and damaging the under the car (under carriage) of Lexus LS460/LS600. I have a 2008 LS600HL. The engine cradle got damaged, and there is frame damage. What are other items I should be aware of. Which areas of the car and body usually are affected by this kind of collision.
fuel lines run under the carriage, unsure if any electrical seeing that yours is the 600h...I'd take it into a Lexus dealer to inspect, the couple to few hundred dolalrs they'll charge to provide an estimate on what needs fixing is worth more than trial/error in hopes you got everything corrected on your own (outside the dealer).
baddis es is offline
Old 01-14-15, 08:41 AM
mcmayer
mcmayer's Avatar
I drove over a divider. The compact affected the body as well.
Are there diagrams on how the force gets distributed on under carriage collision. The bumper did not get damaged and the airbags did not open.
mcmayer is offline
Old 01-14-15, 08:51 AM
mmarshall's Avatar
Probably not, because no two scrapes are necessarily exactly alike.
I agree with baddis es. Take it to a reputable Lexus or independent shop and get it inspected. Also, depending on how just much of the undercarriage you actually scraped over the divider, have them look for any damage to the exhaust pipes, catalytic converter, drive shaft, universal joints, rear differential, and any other exposed components underneath.
Old 01-14-15, 09:06 AM
mcmayer
mcmayer's Avatar
Thank you
Does Lexus or others have studies on front end collision at different speeds or impact points, and how the force affects the frame and body?
mcmayer is offline
Old 01-14-15, 10:14 AM
Received 2,428 Likes on 1,591 Posts
probably not that they've published.
sorry to hear about your car, but not quite sure what you're trying to accomplish. are you trying to get informed before going to a body shop so you can evaluate whether a quote is reasonable?
why not just file an insurance claim to get it fixed regardless?
bitkahuna is offline
Owczar
08-13-17 03:02 PM
vanbay
05-31-17 02:03 AM
daryll40
06-25-11 06:14 AM
salman_198
04-05-08 08:47 PM
Quick Reply: Damages due to under carriage collision LS460
