I get emails from Toyota about this service periodically and d I'm very curious. I want to try it but worried that it's just "snake oil". But for just $70 bucks, I may give it a try.
Has anyone tried it and can share their experience? Is the A/C colder? Did you really notice an improvement in mpg?
Here's a description of what it is below...
What is ArcticBlast and how does it work?
ArcticBlast is an eco-friendly product specifically designed to improve the refrigerant already installed in your vehicle. By improving the refrigerant you make the entire air conditioning system more efficient giving you faster cooling, greater comfort and even lower fuel consumption.
Platinum Performance
Colder air - The performance of air conditioning in a vehicle is measured by how cold it gets. As outside temperatures rise, many systems struggle to keep up. ArcticBlast will give you the coldest air possible, every time even on the hottest days. Faster cooling - The faster your vehicle cools down the sooner you become comfortable, and thats important to you and your passengers. Within seconds a system treated with ArcticBlast produces cold crisp air, giving you the fastest cool down possible. In side by side tests, vehicles treated with ArcticBlast cooled down significantly faster than untreated vehicles.
ArcticBlast Technology:
ArcticBlast has the technology, guaranteed to improve both the performance and efficiency of the air conditioning system in your vehicle.
Automotive professionals around the world recommend ArcticBlast because it really works.
The modified refrigerant will use less energy, produce colder air temperatures and save you money. ArcticBlast is absorbed into the refrigerant improving thermal efficiency.
ArcticBlast truly gives you the perfect blend of performance and efficiency.
Unlike traditional vehicles most Hybrid EVs use an electric driven compressor for the air conditioning. On some of these vehicles air conditioning can consume as much as 48% of available battery power and result in reduced electric range. ArcticBlast can reduce energy demand by the electric compressor resulting in extended vehicle range.
ArcticBlast can help you reduce your carbon footprint.
I read about this or a similar additive that was supposed to make the AC colder about 2 years ago but read some comments from people who used it and said the felt no difference, I think I read a couple people saying it screwed up their AC system which is what I would be worried about putting a product in a complex AC system that may not be designed to reliably handle cooler temps then stock. I also remember some saying they use a special refrigerant not widely available that some commercial AC shops have access too for cooler are but it was like over $100 for a little can if you could even get a hold of it.
I would wait for some real world reviews and long term durability before putting that in your AC system.
In my old 2007 Mazda3 with a weak a/c system I was having it evacuated/recharged anyway so I decided to use some stuff called 'Ice32' that they guaranteed it to lower the a/c temp at the vents...it did but just a couple of degrees, not the dramatically colder air I was hoping for.
I heard it's good to get the a/c system completely evacuated and re-charged every so often.
With the pressure on the manufacturers to improve fuel mileage, I tend to believe they'd be using this already if better mileage was as easy as an a/c compressor additive. I'd avoid it.
