Low fuel tank is a concern???
I watched this Fox episode a few months ago and I am a bit paranoid now
I am more conscious when I am low on gas now. I recall hearing this problem with older cars, but I assumed this issue was resolved with newer models.
Good Video. I agree with most of it.
There's one other precaution I would also add. Driving with a low tank, when cornering on sharp curves, because of centrifugal force in the curve, can cause the gas level to all run over to one side of the tank or another, briefly uncovering the porting-hole in the tank where the fuel leaves the tank and flows to the fuel pump and injectors (some cars actually have the fuel pump in the tank itself). That means, of course, that the engine could momentarily stall, leasing to a loss of engine-driven features like a hydraulic (not electric) power-steering pump or, if long enough, of the vacuum-reserve for the power-assist to the brakes.
True, but that's not usually not a problem on new or fairly new vehicles. it takes time for the dirt to build up at the bottom of the tank......and that's only if the gas station uses crappy filters of their own built into their gas pumps.
years ago as a teen I was in my dads car with about 1/8 tank of gas and made a u-turn. Bad idea, the car sputtered and died. I walked and bought a 2 gallon gas can and put it in but she wouldn't start....had to have the entire fuel system cleaned out because it had sucked up some crud and blocked the fuel line.
I never let my gas get lower than 1/4 tank anymore....most of the time I'll fill up when it gets just below 1/2.
if you've done this a few times, and if your car still works, and you never run it on empty again..... would the fuel system and pump be good from now on?
or have you already set off a chain of events that will lead to failure sooner or later?
I've been driving for almost 30 years and I almost always wait until the fuel light comes on before I fill up. I have never had a fuel pump fail and never had a clogged fuel filter. I'm sure running the tank low can indeed cause fuel pump failure on occasion, but I'm not worried about it. I have never run the tank completely dry and out of gas though. I've had about 18 cars in my lifetime so far. A few over 150K miles, and most around 100K miles before I sold them.
Didn't have any speakers but followed along with the infograph. The gas light on my IS comes on when the range reads 29-33 miles left before 0. Of course there is usually a 1.5-2 gallon reserve once you hit 0, so in a pinch no worries you can go below E, just I wouldn't make a habit of it.
I used to fill up at about a quarter left, but now I realize that the dummy low fuel light is way too happy to come on. I can drive my car another 50 miles after the light comes on only to see that I fill up 15 so odd gallons of my 17 gallon tank.
but my mother continuously runs her cars down to the last gallon and has been for well over a decade. In fact, she will frequently only pump 4 gallons or so in her large SUV then get back on the road if she's in a hurry. None of her cars have had fuel system-related issues.
qewani1
04-14-09 03:09 PM
