Mazda G-Vectoring: Using Engine To Make Cars Handle Better
Old 06-28-16, 05:34 AM
GFerg
Speaks French in Russian
GFerg's Avatar
Default Mazda G-Vectoring: Using Engine To Make Cars Handle Better
Let’s face it: The current automotive climate breeds lazy drivers (see automatic cruise control, lane-keeping assist, and the decreasing availability of manual transmissions). So it seems incumbent upon us to celebrate genuine advancements that improve a driver’s ability to actually control a car with one’s own appendages, whether going fast on a racetrack or taking the family to the beach. There’s an interesting new one over at Mazda, where the driving forecast is sunny.
The brand from Hiroshima ranks remarkably high on the overall fun-to-drive scale, especially considering its size and resources. The Mazda 3 and the MX-5 Miata reside on the current 10Best Cars list and the Mazda 6 is a previous winner. The company’s SUVs drive like cars, and its interiors deliver visual punch a weight-class above their prices. In short, Mazda cares about making cars that people actually find enjoyable to drive themselves, which is why we flew to Mazda Raceway Laguna Seca, outside of Monterey, California, to go around the track at a mere 30 mph. Mazda wouldn’t even tell us what G-Vectoring Control (GVC), the technology it planned to showcase, actually was before letting us sample it in the 2017-spec Mazda 6.
The day started with laps of an impromptu oval in the parking lot at a blistering 20 mph. An engineer would switch the GVC on and off from the passenger seat. At first, GVC just feels as if it makes the steering a little heftier. But after a few of these cruise-controlled laps while hugging a line of pylons, we realized that turn-in is smoother and rarely did we have to correct our driving line. Watch this video to see the difference, paying attention to the white line on the steering wheel:
But we were still in the dark about what GVC actually does. Given the name, you might expect it to be some kind of torque vectoring, or steering the car by controlling differential torque delivery between the inside and outside wheels in a corner, which is analogous to how tanks turn. But that’s not what GVC is doing. Mazda finally explained that the important part of GVC is the G, or as you see it frequently, g. By closely monitoring the speed of the driver’s steering-wheel inputs, GVC tells the engine to ever-so-slightly reduce torque. This produces an imperceptible deceleration, only 0.05 g in the most extreme cases. (By way of comparison, lifting off the throttle in a typical car results in about 0.20 g of deceleration.) The tiny change generates a small shift in load to the front axle, which tightens everything in the front suspension and steering system, removing compliance in bushings and dampers and resulting in improved steering response. It is remarkable how such a tiny influence can contribute such a dramatic change. Engineers hesitate to quote a lb-ft figure, but they did confirm that GVC reduces engine torque by a single-digit percentage, usually by retarding the timing. At a steady 20 or 30 mph, the 6’s 2.5-liter might be putting out 20 lb-ft, so even 9 percent would be less than 2 lb-ft reduction.
The whole project was eight years in the making and it developed out of an extensive study of how humans move and how, when controlling cars, drivers make similar movements and react to g forces. After proving the concept with an EV—used because electric motors allow ultra-fine control of incremental torque delivery—Mazda had to wait for its range of Skyactive engines to reach the mainstream before developing the technology for production cars. Mazda’s newest engines have granular and rapidly responsive control over torque output. Creating the slight deceleration is one thing, but getting it to happen in a small amount of time—0.05 seconds—so that the driver and passengers wouldn’t notice, is the real key to making GVC appear seamless to occupants.
Essentially, GVC mimics techniques, like “breathing” the throttle or left-foot braking into a corner, that race and rally drivers use to generate more front-wheel grip and get their competition cars to turn, only it’s extremely subtle, never felt or obvious. While going fast is always a hoot, GVC is more of a comfort- and confidence-builder than anything else. It will not improve skidpad grip or shave seconds off of any driver’s fastest lap time.
After explaining what GVC does, Mazda had us lap Mazda Raceway at 30 mph, hugging the inside edge of one corner to stay on the same line while an engineer in the passenger seat switched the GVC system on and off, as we’d been doing before on the parking lot oval. From the driver’s seat, there are fewer corrections needed, particularly when making quick changes in direction, when a driver might otherwise crank in too much steering angle. With GVC at work, you’re less likely to overshoot your steering input because there’s less delay caused by the previously mentioned compliance that’s designed into the front suspension and steering. That compliance is there to improve ride quality and reduce noise (racers often replace the bushings and mounts with stiffer elements to improve responsiveness, trading away comfort in the process). From the passenger seat of a Mazda 6 with GVC, we clearly could see other drivers making fewer small steering corrections. This limits head toss and torso movements significantly for all occupants. Fewer corrections also reduce driver fatigue, again, improving comfort.
Mazda also simulated a narrow-lane construction zone using tall cones and Jersey barriers on Mazda Raceway’s front straight. Many drivers never notice it, but going dead straight requires that they make a lot of little steering corrections. With GVC turned on, these corrections become less extreme and fewer in number, again reducing driver fatigue.
The really difficult part for Mazda is conveying this information to the car-buying public. The finer points of how GVC works will be lost on most customers, which is not really a problem in itself. All they need to understand is that GVC improves an already class-leading steering system, making for a better-driving car. GVC comes standard on both the 2017 Mazda 3 and 6, and we expect to see it proliferate across the rest of the Mazda lineup within a few years. The Mazda MX-5 Miata is one model that may never get GVC because its suspension has less compliance and a lot of anti-lift baked into its geometry. But we have no doubt that Mazda will find other ways to make that car even more fun to drive in the coming years.
http://blog.caranddriver.com/mazdas-...name-suggests/
It’s rare to describe a Mazda as anything but fun to drive, and there’s a reason for it. The company spends a lot of time ensuring that its cars are engaging, enjoyable and anything but numb. And while other automakers look to automate the driving process, Mazda is seeking a way to keep cars solely under the driver’s control.
How We Drive
Mazda explained that how we drive is essentially three steps. The first step is making an input, whether it’s steering, throttle or brakes. The second step is that the car responds to that action, and more often than not, it isn’t 100 percent perfect. As a result, the driver has to make an adjustment, the third step. This is called the feedback loop. Sometimes you have to make big corrections, and depending on the speed of the vehicle, that adjustment may need to be done quickly. Those adjustments may even need finer and smaller inputs afterwards.
The result of all this is an unnatural, back and forth motion on the steering wheel, or jerky acceleration and braking. Sometimes this isn’t very noticeable to the driver, but for other people in the car or objects, it’s easy to see and feel. Additionally, all these extra inputs can reduce the driver’s confidence and connection to the vehicle.
Mazda wants to change all of this. The idea is to reduce the time between input and making an adjustment. They also want the adjustments the driver makes to be smooth and not jerky. And of course, because this is Mazda and not a luxury company, it needs to be done without additional hardware that could make the car heavier.
Introducing G-Vectoring Control (GVC)
They’ve come up with something called G-Vectoring Control. It’s software that can give the driver a good sense of what their initial action resulted in, and then needs a clear and very small adjustment afterwards. It’s also one of the first processes that utilize the engine to enhance handling.
Here’s how it works: when you make your steering input, the car will reduce the engine torque ever so slightly. This shifts the weight to the front wheels, giving them extra grip and a more responsive turn. From there the driver can make their minute adjustments, but if they maintain a steady steering angle, the car will then recover that reduced engine torque, which will shift weight towards the back of the vehicle, which improves stability through the turn.
Does it Work?
The effect is very subtle. We tested it thoroughly in a number of ways and needed to be extra sensitive to what we were doing and how it affected the driving process. As a passenger it was easier to see that the driver was “sawing” the steering wheel less with the system active. As a driver, it was hard to detect a significant difference until we drove the car in situations with limited grip, first wet pavement and then gravel. In those circumstances, it was clearer that the car required fewer inputs to keep steady despite the fear of limited traction. It gives a better sense of confidence behind the wheel, and allows the driver to predict what the car will do with each input.
The engine only limits a small amount of torque, up to 15 lb-ft, which results in a difference of less than 0.01 g of force. It’s not perceptible to the driver in the way that other brake-vectoring systems are. Mazda believes that those other systems are far less natural, while its process is more driver-focused.
Using the Engine to Improve Handling
In fact, Mazda’s system is so unique because it uses engine braking instead of traditional brakes. The reason for that is because brakes are both less predictable and take too long to spring into action. The engine braking happens in about a quarter of a second, a delay that is hard to detect by human standards.
It’s a uniquely Mazda thing to do, using the engine to enhance cornering and driving dynamics. This is the automaker that brings us the “Driving Matters” slogan and adheres to the philosophy of Jinba-Ittai: a feeling of unity between driver and vehicle. The automaker strives to have their cars become an extension of the driver, making them as natural and as fun to drive as possible. This makes sense with the more exciting and sport-focused Mazda MX-5 roadster, but the Japanese automaker wants to make even its mainstream products like the Mazda6 and Mazda3 engaging.
Coming Soon
The Mazda6 will be the first vehicle to get this software, as part of its 2017 Model Year changes. Mazda promises that the rest of the Mazda lineup will get this technology too.
In a time where automakers are investigating self-driving cars, semi-autonomous features and tons of driver assistance systems, Mazda is still introducing enhancements that improve the feeling of driving for the person behind the wheel.
http://www.autoguide.com/auto-news/2...le-better.html
GFerg is offline
Old 06-28-16, 06:29 AM
chikoo
chikoo's Avatar
Wow!
This is awesome. I was always irked by all FWD cars requiring almost continuous steering corrections going around a turn, and RWD requiring some. I finally found the car that does not require any (zero) steering correction once I get into the turn (my e46), and am glad to see Mazda making FWD cars that has one of the best features of a RWD into a FWD. Go Mazda!
chikoo is offline
Old 06-28-16, 11:52 AM
Hoovey689
Hoovey689's Avatar
Glad to see them finish this 8-year long project. I'm always rooting for them!
Hoovey689 is offline
06-27-18 07:35 AM
Quick Reply: Mazda G-Vectoring: Using Engine To Make Cars Handle Better
